Question about GE Blenders
GE 17-Piece Single Serve Rocket Blender parts
Cracked ninja blender
Maybe you'd find your answer a little quicker if you posted your question somewhere besides the refrigerator forum.
Feb 05, 2014 | NINJA Blender with Single Serve Accs BL660
Ninja proffessional bl660 blender single serve not working but regular blender is
That is not SUBTLE...!!!
Go with the REAL BLENDER... I've never heard so much
horrible complaints... even from RALPH NADER...
(In my very humble opinion)...
Where there's complaints (tons of them)..
There's trouble.
The whining about ninja's here is quite amazing!!
Jan 31, 2014 | NINJA Blender with Single Serve Accs BL660
My ninja base single serve button is always on, even with nothing attached and it can run with no attachment. I cannot use anything but the single serve.
read your owner manual section troubleshooting. However you must test the control board fro defective, but test the main switch for defective use the multimeter for continuity and replace it
God bless you
Nov 04, 2013 | Euro-Pro Ninja Kitchen System 1200...
Ninja 1100 single serve cup will not come off. it is stuck
I was just having the same problem and looking for a solution...then I found it myself by accident. By pulling up on the cup and then trying to turn it came off pretty easily. I was trying to push down, which seemed to make it tighter.
Jun 21, 2013 | Back to Basics 600 Smoothie Plus Work Top...
Unable to fit. Cup into base of rocket blender
I had this exact same problem and was scratching my head why would that happen all of a sudden. After taking it completely apart (which I didn't need to), I realized in the end that the cup rim was stuck at the bottom of the blender base. It looked like a part of the base what got me confused the first place. The base of the blender is flat with no ridges around; check if this is the same problem with yours.
Jun 10, 2013 | Bella Cucina 13330 Rocket Blender
How do i make a triangle shape tool
take a metal coat hanger and bend it to the size you need it to be...
Mar 24, 2013 | GE Single Serve Blender
G E single serve blender 898695-- need replacement parts
sure, amazon is best place for searching parts... take a look Healthy Blend of Power Precision and Value. enjoy
Jan 19, 2013 | GE Blenders
The jar of the ge single serve blender got struck. How to fix it
Most likely the problem is caused because the base is not screwed all the way on to the jar. This could be from just not turning it on all the way or it could loosen while running. Make sure the base is tightly closed before putting is into the power unit. To remove it you can lubricate the tabs with some vegetable oil and then force it. GE service suggested that. I have heard of two people joining forces to get it off without apparently damaging it but no guaranty's. If you have the reciept it should have a two year warranty, at least mine does.
Dec 01, 2010 | GE Blenders
Blenders Logo
Top GE Blenders Experts
Pamela Leach
Pamela Leach
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a GE Blender Expert? Answer questions, earn points and help others
