Question about Sony KP-46WT510 46" Rear Projection HDTV
How to remove red cables from "tower" on rear of board?
I'm working on fixing my convergence problem, but am having trouble removing the two red cables on the rear of the board.  One is larger in diameter and goes to the HV board (where the other 3 large red cables go).  The other one is smaller and I can't see where it goes.
What is the best way to remove these cables so I can get the board out and replace my convergence ICs?
    Problem Solver:
  • 18 Answers
Don't!! the red cables are the high voltage and focus lines. damage to these will disable the set! However, the board can be removed far enough to facilitate repair without removing these cables. They are usually held in place by plastic loops. release both cable from each loop they go through pull free from chassis brackets. the smaller one goes to the focus block in the front of the set (behind the speaker grill)
Posted on Jan 04, 2009
No picture or sound with a red flashing power light. Have replaced the convergence IC's but no change (do not have the chirpint sound). Removed main power board & green LED does not light up
On that model the conv IC is usually not the solution. I believe its the blown capacitor problem with is an easy fix. Check the site www.TvRepairKits.com for a repair kit.
Apr 11, 2012 | Hitachi 53UWX10B 53" Rear Projection...
When i turned on the tv the convergence was way off.I was able to fix the red and blue but the green cross hair has moved 2 inches over and in the middle the is wavy please let me know if there is a way to...
If auto convergence does not work in the menu then replace the convergence ICs and check resistors around it. You can take the grill off the front and access the convergence board fron the front. Its a small board to the right and it is removable. Do auto convergence again after replacement.
Mar 25, 2010 | JVC AV-56WP30 56" Rear Projection...
Can not align red even though convergence board WS-55819
Did you replace the center board with the STK-392-570 chips or the Digital convergence board mounted on it?
98% of the time if you have a convergence problem it is on the center board---the small board on the left under the metal shield box stores and controls the convergence of this set.
WHICH DID YOU REPLACE?
I am here to help----I have fixed hundreds of Mitsubishi sets with convergence troubles.
Regards, SD TECH
Oct 28, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Green projection light not alligning with red and blue. Flash focus will not bring them back. Sony Rear Projection KP-48S70
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Note:The convergence/defletion/power board (the one the IC's are on) of this model is on the left hand side (when facing the back of set) also check for blown pico fuses when replacing the convergence IC's The best way to replace the IC's resistors and possibly fuses is to remove the entire board.
Oct 19, 2009 | Sony KP-48S70 48" Rear Projection...
My tv is showing ghosts images but i have cable. how do i fix this?
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
Oct 11, 2009 | Sony KP-57HW40 57" Rear Projection...
Red color is not aligned
Oct 02, 2009 | Hitachi 43FWX20B 43" Rear Projection...
57HX81 projection tv,color is mostly red and picture is double.
This is a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$300
Sep 28, 2009 | Toshiba 57H81 57" Rear Projection...
Removing the JK07132-A convergence board
Unplug TV from ac outlet for few hours, this will discharge caps in circuit boards and you can take out desired board after unplugging connectors.
Always Be Careful while doing repair in TV.
Dec 26, 2008 | Hitachi 53UDX10B 53" Rear Projection...
KP-46WT510 Sony, locating boards?
I have the same model tv, with the same problem... convergence ICs were shot.  As you look into the back of the tv, the ICs are located on the backside of the large heat sinks on the tan board.  The pico fuses are directly under the heat sinks.
Removing the board is fairly easy with the exception of removing the red cables at the rear left side of the board.  You have to exert a lot of force to pull them out (they go into the grey tower looking thing) but they do come out.
I recommend taking pictures of the board before removing, and then make sure you label each connector you pull off the board.  There are six screws to remove as well.
Check with Sonny and Barry at this site.  They gave excellent directions and have a convergence repair kit for your model tv. http://servicemanuals.vstore.ca/index.php/cName/convergence-repair-kits
Dec 25, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence
Remove the front grill. There are 2 screws on each corner accesable from the rear and 2 screws inside the front door. Push down on the grill and it will unsnap. Remove the pressboard coverplate . You should see the convergence board, it is about 12" long with a big aluminum heat sink. The board can be removed by pressing on the tabs that hold it down. Be sure to mark and unplug the molex connectors from the board. One of the connectors has to be unplugged from the chassis because it is fixed to the board. Once removed you can easily get to the IC`s mounted to the heat sink. Check for any burned resistors near the IC`s.( 2.2 ohm likes to burn) The convergence can be done through the customer menu using the remote. There is no special formatting necessary. Use the number pad to navagate and the select key to change red & blue.
Nov 06, 2007 | JVC AV-48WP74 48" Rear Projection...
Sony KP-46WT510 46" Rear Projection HDTV Logo
60 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
