Question about Symphonic WV806 DVD Player/VCR
I cannot program the vcr to record i just do not know how to I can play tapes or wath the disk but cannot recore
    Sergeant:
    Champion:
  • 247 Answers
Go to this website and download the instruction manual for your vcr/dvd player:
http://www.nodevice.com/user_manual/Funai/tv_dvd_vcr/wv806.html
in there it will tell you how program your remote. if you have any more question feel free to ask them.
please remember to rate this.
thanks
tom
Posted on Jan 04, 2009
Make sure the tv is on channel 3, and the vcr also on channel 3 -if trying to record from cable or satalite. then make sure tape is rewound all the way. do a test by hitting record on vcr. let it record for a few minutes. rewind it, then just hit play. Dont change any channels until you are ready to record the program of choice. After this test. And recording is successful. Rewind the tape again. And change the channel to your choice. Hit record at time of or go into menu of your vcr and set up a time to record shows.
Some good news v c r will now play , after playing a head cleaning tape but will not recored could this because the new goodmans digital box has takenover control because i can not get any stations with...
You don't specify what make the VCR is! Could it be an analogue machine? And if you are in the UK all the analogue stations have been switched off! So there's no signal! For the VCR to operate you need to connect it to a second digital box and record the box signal via a scart lead with the video set to AV setting. Some digital boxes have two tuners and will put out a signal for both the TV and VCR.
Jan 01, 2013 | Televison & Video
Can the sansui vcr/dvd combo record vcr tapes to a dvd?
No, the DVD section only plays DVDs, to record VCR tapes to DVD you need a ripping device that digitalize audio and video (convert step) and then transfer to DVD specifications this data to disk (record step). The easiest way to do this is using a USB video capture adapter connected to your PC with a DVD recorder drive installed, the software to do this commonly comes as a bonus in the setup disk of the adapter.
Mar 17, 2011 | Sansui VRDVD4001 DVD Player/VCR
Can a Go Video 3140 make a dvd disk copy from vcr tapes
Yes,read ur manual intructional book how to hook up the tv, VCR/DVD sides togother so it all link up.Play a VCR tape one side and record a DVD disc another side.
Nov 08, 2010 | GoVideo Go Video DVD/VCR Combo
I am attempting to record from a VCR tape to
I have a Magnavox MWR20V6 and I am attempting to record a Tv show but when I play it back the recording is just black.
Jan 15, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
How do I record my vhs tapes to Disk
I have done a lot of dubbing on my machine. First make sure the DVD is formatted. When you put in a new disc it should ask you if you want to initialize. Once that is done, switch to VCR mode. push play on the VCR then push the DUB button on the front of the machine. I hope it helps.
Mar 02, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Burn dvd from vhs
i'm assuming you have a vcr to play your vhs tapes, just plug your audio/video cord from your vcr(out), plug into the audio/video vc10(in), start playing vcr and press rec botton whenever you want to start to record. make sure you can only use dvd+r. choose the quality for the length of time, at the end press 'function' to finalize the disc, then you are done.
Sep 06, 2008 | Sony VRD-VC10 DVD±RW Dual Layer...
Will not time recor with tv off
no need to switch on the t.v for timer recording.inform the model number of the vcr.
Apr 03, 2008 | Televison & Video
I have a Sony SLV-EZ717
It sounds like the taped program was recorded on a different speed. The other VCR that you are playing the taped program may not have the speed needed to play it correctly.
Next time when you record a program try to make sure you use a speed that will be compatible on both VCRs.
For example a tape that last 120 minutes, using the different speeds will give the following recording times.
SP means "Standard Play" >>>> 2 hours
LP means " Long Play" >>>>> 4 hours
ELP means " Extra Long Play" 8 hours
Older VCRs have all the 3 speeds but newer ones only have SP and ELP.
Hope this helps.
Jan 25, 2008 | Sony SLV-N750 VHS/S-VHS playback VCR
Tapes not playing
Hey do the tapes play at all? sometimes some tapes recorded
on other machines won't play on others. maybe you need to adjust the tracking on the VCR you are playing it on. If the tape
was recorded on a VCR that is misaligned it might not play back
on another VCR. Also the tape may have been recorded on a
super VHS VCR in et (extended definition) mode if so they won't play on just any VCR. If the picture looks scrambled like a
premium channel on analog cable then it's probably recorded in et.
and if its recorded on super VHS tape it may eject out of your VCR.
They don't make these S-VHS vcrs anymore but people still
have them around. There is also Digital VHS they're not
compatible with VHS either. A VHS recorded in et mode will
play on some more expensive vcrs it should say so on the box
or instructions.
Nov 14, 2007 | RCA VR634HF VHS VCR
Symphonic WV806 DVD Player/VCR Logo
109 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
Henry  Thomas
Henry Thomas
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
