Question about Vizio L32 32 in. LCD HDTV
No signal my vizio will turn on,"no signal" appears then turns off by itself after 2 seconds.
  • courtney881 Jan 04, 2009
    mt tv is doing the exact same thing this morning
  • me_yeow Jan 13, 2009
    I have this problem. It was working fine. I was going through the inputs (ex:hdmi1, hdmi2, av1, av2) when suddenly no signal pops up and it starts turning itself off. I have had it unplugged for about a month. Everytime I plug it in and try again it shows a blue screen that says no signal at the top and shuts back down. Only had the thing a little over a year. Mines a 37 inch.
Mine did the same was on rgb...didn't have ability to plug in computer to tv as suggested previously and I kept trying to hit input button on side of tv after turning tv on..didn't work but when I pushed input button before turning on tv when i turned on tv input screen was up and was able to move input to hdmi...everything works now.
Posted on Oct 03, 2009
Turn your power button on the one on the side of your tv before it turns off press the input button on the side of your tv and hold it down until it goes to the tv on that list .
Posted on Aug 05, 2009
This is because its in RGB mode which makes it a computer monitor. Hook your computer to the Tv so it gets a signal then you can change it back to TV mode
Posted on Feb 08, 2009
  • 362 Answers
Have you recently changed any of the inputs (dvd, cable box)?
Posted on Jan 08, 2009
3 Suggested Answers
  • 24 Answers
SOURCE: Have a Vizio VX37L that when it is turned the
It's probably indicating a problem.
Posted on Apr 02, 2010
  • 11361 Answers
SOURCE: 47" vizio turns off by
It may have dying power supply due to bad caps or the main board is bad, it will require in-depth troubleshooting.
When the picture cuts out, see if the backlights are still on.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps.
Or, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jul 04, 2011
Just bought a vizio, the tv turns on real pixelated but fixes itself in 15 seoncds
If I have trouble with a brand new TV I always take it back and am sure to get another brand entirely. Personally I've had good luck with LG, SEIKI, and Samsung.
Jan 06, 2015 | Vizio Televison & Video
Television syas no signal and wont come on
Usually when VGA or PC input selected TV come on, says NO SIGNAL, and turn itself off. After turnin on you have few seconds to change tv input.
Jan 12, 2011 | Vizio L32 32 in. LCD HDTV
The tv had blue screen briefly showing "no signal" then turns off. ... and I am getting the same blue screen-no signal.
If your television is displaying a blue screen or no signal message and then turning off, your TV may be at an inactive input. Here's how you can get back to watching your TV:
1. Powering on your TV and press the INPUT button on the VIZIO remote control repeatedly until a picture re-appears.
2. If this does not work, try again but press the button slower this time.
I got this off the vizio website.
Feb 21, 2010 | Vizio GV42L 42 in. LCD Television
TV says lost signal and turns itself off
Unplug the TV from Wall, wait a bit and plug back in. Should be reset.
Feb 09, 2010 | Vizio L42HDTV 42 in. LCD Television
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Jan 24, 2010 | Vizio VX37L Television
Turn on tv - tv says no signal, then turns itself off . vizio flat panel
i turn on my flat screen lcd television and it just says no signal
Jan 09, 2010 | Vizio VW42LF 42 in. LCD HDTV
While trying to change channels, my t.v. displayed ''no signal'' and then shut itself off. Now, when I turn it on, it says no signal and turns itself off after a few seconds.
Turn the television on and as soon as the screen turns on repeatily press the input button or change the input to whatever input you are using from a source device. As long as you change it to anything other than RGB.
Your television is essentially a big computer monitor with multiple inputs and a tuner. When using your computer and shutting it down the monitor will go in a power save mode. You don't need to shut off your monitor due to this power saving mode. When you power up your computer your monitor automatically turn on.
With the VIZIO and the RGB (computer) input the television will act just like a computer monitor. When you have a computer connected it will power down automatically when you shut off your computer. When you turn your computer on the VIZIO will automatically come out of standby mode. This is through RGB only.
This is normal operation for the VIZIO but can see confusing when nothing is connected to the RGB input. If you change your television input to RGB it will sense no signal on the input and will go into standby mode after about 5 - 10 seconds. If you were to send a signal to the television through RGB it would automatically kick on.
Apr 05, 2009 | Vizio L37 Television
42 in lcd vizio "no signal"
if the TV have a no signal sign which means most of the important part is missing. Try checking your connections. The best way is to hook up a dvd player using AV input (the yellow, red and white). make sure that you turn the device on and whatever input you connected the device to is selected. if your TV is a P50HDM model, the TV will shut itself off after a short period without and input connected.
Sep 08, 2008 | Vizio P50HDTV10A 50 in. Plasma HDTV
42 inch LCD Vizio. "no signal"
Just hold down the input button on the right side of the tv. This is the bottom one. So,
With the tv off,
press and hold the bottom button (input)
when the tv turns on, and you see the input menu
release and press the button to put the tv into a mode that works!
Apr 15, 2008 | Vizio GV42L 42 in. LCD Television
Vizio L32 32 in. LCD HDTV Logo
1,004 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
