Question about NEC MultiSync 1920NX 19" LCD Monitor
Screen and colors too bright
Hello everyone, my NEC MultiSync LCD1920NX screen and colors are too bright. when compared side-by-side with my crt monitor, the colors on my crt are what they should be. Is my NEC MultiSync LCD1920NX suppose to be like that? Thank you for any help you can provide.
  • 3 more comments
  • jim tran May 19, 2007
    Thank you cramsvik. Your tip did help. My screen looks better. I forgot to add that I am using windows xp and my video card is ati 9600 pro. I also have one more question. When I play a full screen game, all the settings I set on my desktop went back to their original settings, and the screen is once again bright (like a layer of fog). Thanks again cramsvik.
  • jim tran May 25, 2007
    Thank you cramsvik for taking your time helping me out. I believe my lcd is a little broken. Yesterday when I was surfing the net, my lcd screen blinked and it got darker but looks great! when I set all the settings to original (same as the crt). This blink i believe is similar to when a crt has a problem displaying red for example, and then blink all of a sudden and display the red color making the screen color looks like what it should be. Thanks again cramsvik for taking your time to help me.
  • Anna0110 May 11, 2008
    My computer is too bright. I clicked the buttons on the monitor and I have made my Brightness 0 and my Contrast 0. My computer is still way too bright. If you know any solution or suggestion that could fix this problem it would be greatly appreciated.
    Thank-you.
  • ricklita Mar 30, 2009
    My screen is too bright all of a sudden. The words are all washed out. Adjusting the monitor does not work. No viruses detected. Help?
  • Anonymous Apr 05, 2009
    My laptop screen just changed colors and now the lcd is way to bright
    I tried to calibrate but it didnt work. Also when  i restart the computer the colors are right but then after everything properly loads it goes back to bright.
    New Friend:
My laptop's screen color is too faint..compared to my desktop..i can't even see the actual color of something...the laptop shows it's brown..but in my desktop it's Red
Posted on Mar 20, 2013
    Scholar:
  • 121 Answers
CRT and LCD will look different when compared side by side. Is your CRT calibrated, or are they right in the sense that they are what you are used to? Also Anyway, you can adjust the colors and light levels from the menu on your screen, and depending on your operating system and graphics adapter you should be able to make adjustments there, too. For windows XP, right click your desktop and select properties->Settings->Advanced. There might be a color management tab. Also, there might be software to help you do this already installed. Look for a program group with the name of your Graphics adapter manufacturer. Very often ATI or nVidia. A few resources to help calibrate: http://desktoppub.about.com/od/visualmonitor/Visual_Monitor_Calibration_Tests.htm http://desktoppub.about.com/od/visualmonitor/Visual_Monitor_Calibration_Tests.htm
Posted on May 18, 2007
  • Christian Ramsvik May 20, 2007
    If you change the settings on the screen itself, I find it strange that playing a game changes it. If you chenge the settings from XP, a game might alter those settings.
    If this happens every time, you might see if there are "profiles" that you can save. That way you can just select that profile instead of adjusting every setting manually.
Sorry to say, but I'm having the same problem. If it doesn't change when you press the Fn key and the hollow/right arrow sunshine, then, I doubt there's anything you can do.
Posted on Feb 18, 2011
Hi, NEC P221 W multisync has increasinly been displaying fine vertical cyan and magenta lines, most evident on white areas and grey areas respectively.
Your monitor is no longer in production but there might be some support for it. Go here to see what's available: Product Support You might need to upgrade.
Jul 28, 2017 | NEC MultiSync FE950 (White) 19" CRT...
How to increase brightness of my monitor i put it
Hi, you can try this; in a clear area of the Desktop screen (right)) click, once the desktop window open, click on Personalize, next click on Display Settings. You can adjust the brightness by by doing the following: On the resolution scale adjust from Low>High; you can do this until you are satisfied with the view. In the (Colors) drop box, click the down (Arrow), and choose the "Highest" color (16bits>32bits) etc. Next click to open the (Advance)) settings, click on the (List All Modes) button, once the window open choose the (Highest) settings: example (1366 by 768, True Color (32bit), 60 Hertz. Remember to click the "Apply", and "OK" buttons after each selection or change. "Hope this helps' Ya"
Jan 29, 2010 | NEC MultiSync FE700 17" CRT Monitor
NEC multiSync 1700V as external monitor for Notebook Toshiba U205, Operating System Window Vista Home Premium. It displays only part (80%) of the picture compared with notebook's monitor.
Hi, if the 17 inch lcd screen is not a widescreen then the problem with the screen is possibly nothing more than the aspect ratio or resolution, which ever way you wanna look at it. All laptops have a widescreen type of ratio, so you will have to be either willing to change the resolution when you switch screens or setup different profiles, which you should beable to do through control panel, appearance and then personalization, you will then have access to it.
Nov 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Bright yellow
hi everyone i have the some yelow problem with CANON lv s3... any ideas where can i found this blue lcd polarizer...e-mail me sugestions jonasjhony84@hotmail.com
May 12, 2008 | NEC MultiSync VT480 Multimedia Projector
On-Screen menu keeps showing
My screan is too bright how do I adjust to make it toned and more comfortable to use
I have A NEC MultiSync LS15
Feb 15, 2008 | Computers & Internet
Nec 700 crt
Not a solution at all, but I'll post that I have a NEC MultiSync FE700 monitor that I purchased back in 2001, and have I been using the monitor since that time. Lately the monitor has been showing signs of 'acting up'. I read on the Internet that CRT monitors generally have a working life of about six years. It may be, depending on years of use, that the monitors are just reaching the end of their life.
Oct 20, 2007 | NEC MultiSync FE700 17" CRT Monitor
NEC MultiSync 1920NX 19" LCD Monitor Logo
11,084 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
