Question about VTech Communications Lands Phones
Screen is blank.everything works normally.
My second handset is fine.but when it comes to my first hand set,it is working properly except the blank screen .nothing has ever happened to it.even battery looks fine.is there any unlock code for that. thanks for your support.
  • 152 Answers
SOURCE: Hand sets do not seem to work
Press and hold the sync button on the Nintendo Wii remote. While holding the sync button, go over to the Nintendo Wii, and and press and hold the sync button. Wait for a few seconds, and then test the Nintendo Wii remote.
Posted on Dec 21, 2007
  • 45 Answers
SOURCE: Zebra 140 thermal printer
Hello, mmgarcia10.
I've dealt with Zebra 140's for a lot of years. It's best to start with the easy fixes, so please don't take offense if I ask you to check obvious probelms.
I'm assuming you use a ribbon (as opposed to direct thermal paper). When replacing ribbon, it's easy to slide the spool on facing the wrong way.
Can you verify that the ribbon is loaded with the ink facing down? The back of the ribbon is probably shiny and should face up. The ink side is dull and ink can probably be scraped off by your fingernail. The ribbon on the spindle should unwind clockwise, not counter-clockwise. If you're familiar with cleaning the printhead, this would be a good time; if not skip the cleaning for now to avoid damage.
If the ribbon was loaded OK, the next thing I'd check is the printhead pressure. The are two posts with thumbscrews located above the printhead. The thumbscrews press against springs that in turn apply a small amount of pressure to the printhead. Each post has two thumbsrews that can be tightened toword each other to lock the position. Labels and ribbons can be a little tricky to load, and sometimes these posts can slide to the side by mistake. A good rule of thumb is to position these above the left and right sides of the label. Don't apply too much pressure, or the printhead will wear out faster, and printheads are exensive. If one side prints light and one side dark, give the light side a little more pressure.
If the labels still don't print, turn the printer off and then on (to reset the main board).
I can't remember if the Z140 can print a configuration page or test print if you hold down the Feed button while turning on the power. It's so easy it's worth a try. I know you can print one by navigating through the front panel. If the label doesn't print, it's probably a hardware problem. I've never seen a ribbon cable work loose from a printhead, but if you can find the connector, you can jiggle it a little and press it in to try to reseat the pins.
If the config page prints but labels from your software don't, you could check the darkness setting in you software, and also in the printer driver (right click the printer name, and choose something like Printing Preferences). There's also a darkness setting stored in the printer that can be set through the front panel, but this is often over-ridden by label software.
Hope this helps,
Label_Guy
Posted on Oct 02, 2008
SOURCE: lights come on but nothing shows its black.lens looks good
older model night owl monocular,it has been stored for awhile..new batteries lights work but nothing shows except black..lens looks good not grey but has a blue tint..what could have happened while in storage..been in a case.. worked fine when put in storage
Posted on Apr 01, 2009
  • 788 Answers
SOURCE: blank HP w1907
If the power light does not turn color and stay's green on startup, it is not a power problem. It is most likely the inverter. If the unit is in warranty, send it out ASAP. Contact HP customer care by email and have the issue logged in.
If in warranty, they will send you a box by FedX second day and have repaired.
This is a 19" monitor and will not be worth paying for repairs if not in warranty.
Posted on Sep 03, 2009
Testimonial: "I am very happy that this guru was able to concisely evaluate the problem from the information provided. "
SOURCE: Own model KX-TG6031CM. Handset display is lit up
need access code to retrieve messages for kx-tg6031cm panasonic phone
Posted on Feb 20, 2010
Got two handsets the second handset shows nothing on the screen is this normal?
no -- hand sets show what number handset it is time and date
check the battery for the second set
if it is charging then there should be a red light on the set
Apr 21, 2015 | Uniden Cordless Phone
My nokia 3600 slide screen kept blank.all of it works fine except the screen
If everything is fine except your screen, bring it to a technician and have them check first the flex wire.
If your flex is fine then the last thing will be your LCD. have it replace
Nov 04, 2009 | Nokia 3600 slide Cellular Phone
I can hear caller on handset but they cannot hear me?
We just had the same problem with our AT&T 2462 hand sets. They simultaneously stopped transmitting, and though we could hear the caller, no one could hear us on the other end of the line. We unplugged the base from the power source, took the batteries out of the hand sets, waited 20 seconds, then plugged everything back in and they worked just fine. Hope this helps.
May 03, 2009 | AT&T E2562 Cordless Phone
Uniden Cordless handset
we purchased the uninden 3 pack bundle they worked fine when installed now one handset will light up but the screen comes up blank and the handset won't work also if this can be corrected i would like to know how to purchase one extra hand set and charger
Sep 30, 2008 | Uniden DECT 6.0 Cordless Telephone...
Screen
if evrything ok in your fone except the screen(LCD). the problem is your LCD maybe its just a lose contact or or the LCd is broken maybe it can help to you ^_^
Sep 27, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Searching....
The problem of searching.....
After trying all the technician's suggestions had failed; I disconnected the base to return it to the store for replacement. Then I decided to try disconnecting and reconnecting power and phone line, placed handset back on base and the phone reset itself and is working fine...
Recap:
Disconnect power and phone line from base for about 30 seconds and reconnect both power and phone line to base and place handset back on base; it should reset...
Linda
May 05, 2008 | Uniden DECT 6.0 Cordless Telephone...
Vtech M6896 phones do not work
Step 1: Press and hold FIND HANDSET on the main telephone base for 10 seconds.
Step 2: When the IN USE light starts to flash, release the FIND HANDSET button.
Step 3: Press and release FIND HANDSET again. The IN USE light will turn off and in a few seconds, all handsets will be de-registered.
Step 4: All handsets will show NOT REGISTERED.
To register a handset (register 1 handset at a time):
Step 1: Place the handset in the base unit or a charger that is connected to a power outlet. If PRESS FIND HNDST 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and place in base or charger again.
Step 2: On the telephone base, press and hold FIND HANDSET for four seconds. Release FIND HANDSET once the IN USE light comes on.
After a while the handset will emit a series of tones, the newly registered handset will be assigned the lowest extension number not previously assigned to another system handset (1-4) when successfully registered. Repeat Steps 1 and 2 if the handset does not successfully register to the telephone base within two minutes.
Jan 18, 2008 | Vtech mi6896 Trio Cordless Phone
Disfunctional Handset
has the secondary handset ever worked. Reason I ask is that it happened to me with a new addtl handset and the problem was that I did not remove the small piece of paper between the handset and the battery which caused only distorted figures to display on the LCD of the handset.
Nov 22, 2007 | Vtech VT 2461 Cordless Phone
Blank screen
So you can see images that are on the card from previous taking but not new? Just to confirm - this is an optical SLR? With a mirror that flips up when you press the button - is that right? If so it souns like to mirror is not going up. Can you hear it go up? Come back
Jun 17, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Lands Phones Logo
16 people viewed this question
Top VTech Communications Lands Phones Experts
Bill Boyd
 Grubhead
Grubhead
k24674
Are you a VTech Communications Lands Phone Expert? Answer questions, earn points and help others
