Question about Samsung Computers & Internet
How to open a samsung syncmaster 2233rz - Samsung Computers & Internet
When i come back to my sync master 2233rz monitor after leaving it alone for atleast an hour, half of the screen goes bezerk and the only way i can fix it is by restarting my system , please tell me what i...
Hook a spare monitor to your computer, if okay! the problem is in the SynMaster, but if both show the same it indicates a video graphics card problem in the computer, Hook your SyncMaster to the computer and change the video cord from the computer to the monitor just to be sure. If no change! it is time to replace the monitor "the LCD panel is defective" not cost effective to repair.
Mar 23, 2012 | Samsung SyncMaster 2233RZ 22 inch 3D LCD...
All of a sudden my 2233rz stopped powering on. Screen just went black midway through browsing...checked the kettle lead, it's fine. All cables are fine. Any suggestions?
Hi Kevin,
First of all, thank you for posting your question here at Fixya.com.
My first advice is to ensure that your AC source(outlet) is live. Try to plug it in to a known working outlet to confirm that the power source is not the issue. If you are using a surge protector/AVR, try to directly plug the monitor's plug to the outlet.
If you confirmed that the AC source is not the problem, then this is an indication that the fault is inside the unit. You have to check first the power supply board's fuse. Check its continuity, if it has a continuity, then the fault is on the voltage regulator circuitry and/or other circuitry on this board, I would advice you to replaced the entire power supply board. Click it here for the replacement.
If you found it open, you have to replaced it with same current(ampere) ratings and then try to power on the unit again. You are lucky if the replacement fuse resolve the issue. Sometimes fuse fail due to voltage surge/flactuation, aging however if the new fuse didn't resolve the issue, then you have to replaced the entire power supply board.
Also, check if your unit is under warranty period, avail it because the manufacturer will fix it for free. Opening the rear cover will void the warranty.
Hope I helped you.
Have a nice day!
Good luck and take care!
Kind Regards,
Mjsazon
Dec 10, 2011 | Samsung SyncMaster 2233RZ 22 inch 3D LCD...
I am all of a sudden getting fuzziness of everything on the screen
this manual may help.http://www.manualowl.com/p/Samsung/2233RZ/Manual/47064.by chance do you have the driver for your monitor install.
Jul 20, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
SyncMaster 203B (Black) LCD Monitor: Monitor will not stay on (Samsung Syncmaster 203B)...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 16, 2010 | Samsung SyncMaster 203B LCD Monitor
How do you open up Samsung LCD 740N monitor?
This monitor contains a latches to open. Its recommended that you use suitable tools and service manual.
If the unit is in warranty its recommended that unit to be serviced by service Engineer.
Dec 21, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Trouble with Samsung 2233RZ
The same to me
I think the monitor is broken
Sep 06, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
How to open monitor samsung syncmaster 753s?
"Don't kill yourself just to save some bucks"
Here are the instructions:
http://www.josepino.com/?open-samsung-back-cover
Aug 11, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Syncmaster 214T
http://s807.photobucket.com/albums/yy352/budm/Samsung%20Syncmaster%20214T/
Replaced all those caps (not hte big on in the primary circuts) with PANSONIC FM or FC series from DIGKEY.COM
May 15, 2008 | Samsung SyncMaster 214T 21.3" LCD Monitor
Computers & Internet Logo
140 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
