Question about LG WM Washing Machines
Lg wm1832cw machine
What sensor are you talking about?
    Top Expert:
  • LG Master
  • 9,472 Answers
Who?
Posted on Nov 02, 2012
4 Suggested Answers
  • 99 Answers
SOURCE: noisy on spin cycle LG WM1832CW
this is joyce
Go to lg.com and download your manuel put in your model #
thanks
joyce
Posted on Feb 07, 2009
MNTECH
  • 1543 Answers
SOURCE: lg washing machine wm1832cw door is locked with
This is most likely due to non-pump out of the water. It could be a plugged filter or a bad pump motor. First thing to do is to get a pan or bucket and open the big screw filter behind the access door at the lower left on front of the machine. All the water will come pouring out, so be ready. Machine will probably unlock on it's own then. (if it is still plugged in) If not, you can take the top off by removing the screws on the bottom of the plastic clips at the back of the washers top. Now, standing in front of the machine, use the palms of your hands to sharply push the top back about an inch, then lift the top off. With machine unplugged, you can reach down to manually relaese the door lock.
Posted on Jun 08, 2010
SOURCE: I neet o replace drain pump on a LG wm1832cw model
its not easy, but you'll have to lay the washer on its back and take off the crate like bottom panel. Discontect all the hoses. Disconnect the electrical line going to the pump. If you can, try and seperate the pump motor from the housing by unscrewing two screws on the housing, which will seperate the motor from the housing, If you cant get to it, I actually broke the screws on the drain filter housing to get it loose. I secured it back with the other front loading screw and some gorilla glue, shouldnt be a problem. I should at least get another 6 years out of this pump. Good luck.
Posted on Jul 10, 2010
My LG WM1832CW has no error codes it will agitate but won't spin or pump water,so far I changed the sensor assembly and rotor assembly
Why did you change the sensor & rotor assembly? Did you test them first and found them to be faulty or are you just randomly guessing. If it doesn't pump the water out it will not spin. It has to be empty before spinning can start. So you probably have a drain pump fault. Start by checking if there is a blockage in the pump or hoses.
May 13, 2017 | LG Washing Machines
Lg wm1832cw de error occurs when starting the washing. after multiple tries, it might start
It is a door lock error caused by bad door lock switch or if your door is very hard to swing closed because the hinge is corroded, then the hinge could be causing the door lock to error.
Jan 04, 2014 | LG WM-2277HW Front Load Washer
LG wm1832cw filling slowly
The water valves might be going bad, or there is a clog in the hoses. Also check the water pressure going into the washer.
Dec 03, 2009 | LG Washing Machines
Washer will not spin LG Washer WM1832CW
1. Open back of the washing machine and control panel. Locate two wire harness coming out of main motor and main board. Check the wires for any cuts and harnesses for any corrosion. Fix the cuts and sand the corrosion to fix the issue.
2. Check the windings on the motor by pulling 3-wire connector from main board. Check resistance between each of 3 pairs using multi meter. The resistance should be 8-15 ohms. If one or more pair has no resistance reading then the winding is burned. Replace the rotor winding.
Rotor windings can be ordered from here: http://www.repairclinic.com/SSPartDetail.aspx?s=t-wm1832cw-%3d%3di1266809&PartID=1266809
3. If windings are fine then the hall sensor or speed sensor or motor sensor or sensor assembly needs to be replaced. The hall sensor sits on the inside of the rotor winding. Hall sensor has 4 wire connector attached. To remove the hall sensor: Open the outrunner or magnetic rotor from the motor first. Remove a big bolt at the center of the motor by holding the magnetic rotor. Once bolt is removed, the magnetic rotor can be removed by simply pulling it straight out. You may have to wiggle it a bit. Now remove a screw holding a wire going to hall sensor towrds bottom left of the winding. Now remove six inside bolts holding rotor windings to the drum body. The rotor windings are heavy so be careful while removing the bolts. Remove two wire connectors from the rotor windings and pull out the windings. Lay the rotor windings flat facing connector side up. Remove the hall sensor by praying out tabs.
Hall sensor can be ordered from here: http://www.repairclinic.com/SSPartDetail.aspx?s=t-wm1832cw-%3d%3di1268238&PartID=1268238
Jul 14, 2009 | Washing Machines
Noisy on spin cycle LG WM1832CW
this is joyce
thanks
joyce
Feb 07, 2009 | LG WM-1832C Front Load Washer
LG WM1832CW Drain Pump
i drained it first with the pull out hose in the access panel on the bottom left. i tilted the washer back to remove it from the bottom.
Jun 17, 2008 | LG WM-1832C Front Load Washer
LG WM1812CW PROBLEM
Just had this same problem on my LG wm1832CW machine. Sensor assembly was replaced and all is well..
Simple and fairly inexpensive to replace.
Oct 28, 2007 | LG WM1812C Front Load Washer
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
