Question about LG enV VX9900 Cellular Phone
How do you dismantle the end of the charger?
I have the env and it wont charge. can i dismantle any verizon charger then connect it to the env charger or do i have to use the env charger?
  • tacos4boo Jan 04, 2009
    i ment then connect it to the env battery*
    there are four little rectangle boxes that i hook the two wire up to. i do the black to the negative and the white to the positive right? and also do i put them on all four or just the two outside or just the two inside?HELP!
  • 51 Answers
Absolutely not. You must use the LG charger, or you might get an improper amount of current into the phone and toast it.
Posted on Jan 04, 2009
Just bought new Envy 3 and it wont charge. Tried
Will it charge in the car from a car charger and did they test it at the store before they gave you a new one. I heard that they have had problems with the new ones having a defect with the chargers. That they had the wrong homechargers in the boxes.
Jul 22, 2009 | LG enV VX9900 Cellular Phone
Wont charge
your charging port is loosely connected to *********** board. You need to go to a repair shop and get it fixed.
Apr 18, 2009 | Verizon Communications LG enV Cell Phone -...
Ive put my phone on the charge, but it isnt charging, whats the problem? my env cell phone isnt charging when i put it in the charger
Your port could be messed up or it could be the charger. Take it in to verizon and they will look at it for free.
Dec 15, 2008 | LG enV VX9900 Cellular Phone
My daughter's LG EnV charging port
You can get a charger at factorydirectcellular.com. The link is
http://www.factorydirectcellular.com/home/universal/universal-battery-only-charger.htm
The charger charges the battery independent of the phone. It is the only one I have found and it works GREAT. I had a couple issues at first but the rep, Matt, bent over backwards to resolve them. I would recommend this charger and company to anybody. The charger is a universal charger and will charge other cell phone batteries as well. The only con is that it does take a little longer to charge than using the port.
Sep 06, 2008 | LG enV VX9900 Cellular Phone
My enV will not charge!
Hey i think i just figured out the problem to all the port charging issues for the envy and envy 2 phones with verizon. its not the phones, its the charger cord! the part that goes into the phone. it gets pulled out over time from pulling the cord out of the phone all the time. get a pair of pliers. grab the end and push the metal end of the cord against somthing hard, push it back in so it is at the appropriate depth. this should make it charge properly again!
Jul 17, 2008 | LG enV VX9900 Cellular Phone
Won't Charge- Is there anything I can do?
well i dont have any long term ansa but here is a short term one while you find a new charger.
Take the charger and dismantle the end that plugs into fone. you should have 2 wires a black & white or black & red. Leave the blobs of solder on the end of the wires as this helps. Leave the wall socket end of charger in tact.
Take your battery out of fone. As with a normal battery you will see a (+) and (-) sign on it. Attach the black or darkest wire to the negative (-) metal square on the battery and the white or lightest wire (maybe red) to the positive (+) metal square on the battery (after trial & error i found a clothes peg to be the best form of attaching it). Leave attached for 15 minutes and this will give you around an hours usage when you put the battery back in the fone. If you leave it overnight then it will be on all day.
Basically you are making the circuit without the fone which bypasses your pin problem. Any charger will work with any fone as the charging components are in the wall end. Just make sure the voltage is compatible ie, 5v fone charger replacing 5v charger etc. Although majority of chargers are 5v.
I know this works cos i did it to mine last nite as i needed to ansa my emails. Really simple but a little drastic like i said but if the pin connector is broke anyway wot you got to lose?? I am a girl so if i can do it anyone can lol!!
Only drawback is you cant use the fone while it is charging unless you have 2 batteries and you use one while the other charges which is what i am doing. In fact i might not buy a new charger lol, i dont need one now ive found this method works.
Happy charging!! Hope this helps! Gail-michelle
Jun 14, 2008 | LG enV VX9900 Cellular Phone
Broken charger port
i have the same problem with my enV my friend stripped the wires to my charger at the part where you plug it into the phone so now to charge my phone i tape the red wire to the positive on the battery and the black wire to the negitive there will be a shiny metal goldish color thing (there like 4 lil gold bars) on your battery that looks like this --> (negative) | | | | (positive) | - | | | + | tape the wires on the outside were the symbols are - and + and try not to let it toch the middle bars on the battery or it wont work and dont cover the little bars up with tape put the battery back in the phone making sure the wires dont move to much and it should charge sometimes you got tape the battery onto the phone to make sure it doesnt pop out but its what i do and it saves you money on having to go buy a whole new one or if you know someone with the same phone give them your battery to charge it :)
Apr 18, 2008 | LG enV VX9900 Cellular Phone
Lg env
it's so frustrating!
Apr 11, 2008 | LG enV VX9900 Cellular Phone
My phone just turned off on me and won't turn back on
The red "Pwr End" button both inside and outside is how you turn it on or off.
Sounds like you need a trip to the Verizon store or call Verizon
Dec 11, 2007 | LG enV VX9900 Cellular Phone
Charging
sounds like there is something stuck in your phone or a piece of your charger broke. You can try and buy a new charger or bring your phone to verizon to check it out
Aug 21, 2007 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
147 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
