Question about Panasonic TC-P50XT50 50" Class Smart TV VIERA XT Series 3D Plasma HDTV
Panasonic power cut, i plugged in my digital box to the extension main whilst the tv was on. then my tv just blew. i just do not know what to do, and i have checked the fuse, and it seems fine. i tried turning it on ad connecting other sockets and extensions... yet nothing - not even a red light.
  • 28 Answers
Powerboard should do the job.
Found it here by searching the model :
http://digipartsdirect.com/searchProduct.php?mainSearch=TC-P50XT50
Posted on Feb 09, 2015
  • 127 Answers
For that to happen you may have an electrical phase problem.
Maybe you just overload
When that happens will blow the fuses or the power supply.
Replace the power supply Module
Posted on Nov 01, 2012
skotkolr
  • 558 Answers
SOURCE: funai 32 inch plasma tv
bad components on the power board needs to have service tech look into blown capacitors or transformer on the power board inside the tv.
Posted on May 28, 2008
  • 718 Answers
SOURCE: Panasonic 32 inch LCD TV will not turn on-red light flashing
The number of flashes is an error code. Count the number of flash. It looks like one of the boards in your set is failing intermittently. Panasonic codes for a guide as a starting point. Exact board STILL has to be verified;
One Blink: One blink of the power LED indicates a problem in the inverter circuit located on the LCD panel. The inverter board is not to be repaired in the field. Therefore a replacement is required.
Three Blinks: Three blinks of the power LED indicates an over-current or over-voltage condition in one of the DC supplies of the AP board. The AP board is repairable. Therefore the use of an ohmmeter and peak-hold-voltmeter is required to determine the cause of the shutdown. An over-voltage condition is definitely a defect of the AP board. An over-current condition may be due to a short circuit located in the AP board, A board, or the LCD panel.
Five, Seven, or Eight Blinks: The A board is responsible for five, seven or eight blinks of the power LED. The MAIN +3.3V, MAIN +5V, and MAIN +9V sources are all produced on the A board. The detection input pins of the MPU, IC1100, monitor for their presence.
Four or Six Blinks: The AP board is responsible for four or six blinks of the power LED. The DTV9V, and SUB_5V sources are produced on the AP board. The MPU IC1100 monitors for their presence when the unit is connected to AC Power. A short or open circuit on the A board may also be responsible for their absence.
Nine Blinks: Nine blinks of the power LED is due a short circuit in the audio output circuit (s) of the unit. The audio output circuit is located on the A board. Confirm the status of the speakers. If defective, perform a replacement. If ok, replace the A board.
Ten Blinks: Ten blinks of the power LED indicates a malfunction of IC4200, the frame converter. This IC resides on the A board. Therefore ten blinks of the power LED requires the replacement of the A board.
Posted on Feb 11, 2009
  • 187 Answers
SOURCE: panasonic TH-42PX75U won't turn on
Your powerboard is damaged, and need to be replaced.
Sometimes it appear the TV is working again with no problem but it is only a matter of time for the board to get completely damaged.
Posted on May 30, 2009
SOURCE: My panasonic 42" plasma wont turn on, but the power light blinks
With this symptom, it is impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what is wrong, sometimes it may indicate the "Area" in your case it is the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of anly a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one. So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else.
Posted on Apr 17, 2010
  • 8457 Answers
SOURCE: plasma 50 inches dont turn on
The power supply board is dead.Tries the websites like Shopjimmy.com,Ebay.com to buy the refurbish power supply board for the replacement.
Posted on Jun 22, 2010
David the problem started when i was mounting the the glow plug timer under the bonnet i the shorted the wrench i was working with on the power supply to the main fuse box. the main fuse blew up.
Very strange. I can't think of any part or wire in common to these items. You are saying left turn signals and locks from remote? So locks work from switches inside car?
Mar 01, 2016 | Cars & Trucks
Panasonic TH37PX80B tv won t turn on
Probable power supply failure.
Apr 02, 2014 | Televison & Video
Line access code
To dial an outside (exchange) line you can either dial 9 followed by the number you want to reach or press a pre-programmed key on your handset that saves you from adding the digit 9. The access is normally assigned when your system is installed. Programming of the system can only be done from the first main extension on the system it is normally extension 20 or 21 (the extension that will work if there is a mains power failure), called the default extension. Some systems use different digits either 8 or 7 but the normal is 9. The digit 8 is normally used to pick up a ringing call from another extension. Should you need more help let me know :-) And of course I'd be grateful if you mark my advice accordingly if you have found it useful, thank you.
Sep 29, 2013 | Panasonic KX-T7730 Corded Phone
Hello I've have got a Panasonic TH-50px80u No power I remove the rear pannel and used a volt-Ohm meter to meter the two t8ah fuses they were both open i replace, they aga
Replacing and configuring a main power board to a Plasma display is not a simple job as you thinks. With only a multimeter, you can't do anything. It is a skilled work. Contact any experienced service technician. If you wish to get more details about the repair process of plasma displays, check this link. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Jan 29, 2013 | Panasonic Viera TH-50PZ80U Plasma TV
Panasonic viera wont turn on after power surge
My panasonic 42 inch does this if the power goes out or tv is unplugged prior to powering the tv off first. I unplug the power from the wall wait 2-4 days max then when I plug it back in the tv comes right back on with no problems. Don't know why I have to wait so long to plug it back in
Oct 30, 2012 | Panasonic TC L42E50 - 42" VIERA E50 Series...
Blue screen only on TV after lightning stike. Blew the digital box dead. Is TV repairable
yes but it will be expensive :( there is nothing that cant be fixed :DD bud
Sep 24, 2010 | Televison & Video
My Panasonic CT-27SC14 tv won't turn on. worked fine last night. The cable box does but nothing happens with the tv..whether I use the remote or the power button. Unplugged it from the power source and...
hi,disconated from AC main. if you know bit of repairing tv and soldering? this what to look for main power board. 1 x dry joints 2 x leaky capacitors just remember when changing cap's make sure to use the 105' and same value.
Feb 04, 2010 | Panasonic CT-27SC14 27" TV
I have static on all three handsets yet the landline has none
sorry dont know if it was sent so i will do it again, i had same problem on a network and was advised to cut out the yellow resister in bt point ( only if a trailing socket NOT the main bt incoming socket), also have you got broad band modem ? if this is not on incoming bt socket this can cause problems? dont plug it in a extension lead use a proper cable and box on wall and plug modem direct into socket with no adsl filter ! next plug all your telephones into bt sockets through the adsl filters make sure you havent got to many phones plugged in this inclueds sky box which is a phone ?and needs adsl filter ? hope this helps leighton
Feb 05, 2009 | Panasonic KX-TG1033S Cordless Phone
Power
It sounds like a mother board problem since you upgraded the bios and got different results. Try plugging in the adapter and warming it up. Will the computer run without the battery? that will also let you know if it's the battery.
My initial thought was that your AC adapter may have a heat problem or failing after a while. Wrap it in plastic and put it in ice and see if it lasts longer. If you have the same problem there are other issues going on in the computer power system.
Sep 11, 2008 | Compaq Computers & Internet
Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Jan 12, 2008 | Panasonic CT-32G11 32" TV
Panasonic TC-P50XT50 50" Class Smart TV VIERA XT Series 3D Plasma HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
