Sony dvd receiver model no HDC-DZ290K display push power protector
Dear sir my sony dvd receiver model hcd-dz290k display push power protector pls give me solution thanks utsav electrotech
  • 336 Answers
SOURCE: Sony product Home theater Model
Needs repair either a output ic or a diode near one of the outputs most often takes care of it. Not a job for a diy-er.
Posted on Jan 28, 2011
dmftrucker
  • 1922 Answers
SOURCE: IT DISPLAYS PROTECTOR PUSH POWER
its in standby, try it again, if it does it repeatedly theres a problem in the switching power supply not letting it power-up to save components
Posted on Oct 18, 2009
dunnbiker
  • 8546 Answers
SOURCE: sir i have a problem
You mean SONY, right?
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Jan 19, 2011
  • 64 Answers
SOURCE: sony home theater model no
Check the speaker connection. One of them has a shortcircuit. Try to disconect all of them and power on the device. See what is happen. If starts corectly check the speaker cable. Conect one by one and power up the receiver after each connection. When you get the error again check the last conected cable. These receivers have a protection system against shortcircuits. That is puting your device in that error.
Posted on Jan 27, 2011
dunnbiker
  • 8546 Answers
SOURCE: WHEN THE POWER IS TURN
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Jul 13, 2011
My Sony home theater DZ290K had a push power protection on the display screen how can I fix it?
The "PROTECT" and "PUSH POWER" messages will flash alternately when the protective device of the amplifier has been activated because a strong signal was input, or if there is a short-circuit detected. Press the POWER button on the unit to turn off the system, and check the following items after "STANDBY" disappears.
1) Are the + and - speaker cords short-circuited?
2) Are you using only the specified speakers?.
3) Is anything blocking the ventilation holes of the system?
You may also refer to the following link for additional troubleshooting steps.
PROTECT and PUSH POWER flash alternately on the amplifier screen
Aug 26, 2015 | Sony Audio Players & Recorders
DAV-DZ290K SHOWS PUSH POWER PROTECTOR
I solved sony push protect power , please wait and difficult fault , contact 09883596400 only kolkata.
Oct 06, 2014 | Sony DAV-S300 System
Model home theater system DAV-DZ290K push power protector
R3562 10 k Ohm chip resistor faulty leading to shut down due to faulty power detection
Oct 19, 2011 | Audio Players & Recorders
My sony Home Theatre DAV-DZ290K, is not functioning properly. The DVD drive opens back again immediately after closing it with a CD or DVD. The display would show us "CLOSE" and then instantly...
okay just plug it out from the current outlet let it stand for one hour then plug back in if that does not remedy problem then your motor is bad or the ic that controls the open and close circuit.have a tech look if my remedy does not work..sometimes plug in and out do the fix cause all the set wants is to reset itself.
Sep 13, 2011 | Audio Players & Recorders
Sony product Home theater Model HCD-HDX265 , it is not turned on after standby it display PUSH POWER PROTECTOR
Jan 28, 2011 | Audio Players & Recorders
I have Home Theater Sony DAV- DZ151Kb. Display Push Power and then PROTECTOR. I need Help
Push power protect message appears when home theater got problem in amplifier output section and any output amplifier chip becomes bad, receiver set protection mode and refuse to power up to avoid further damage in circuit board.
It is very hard for novice to troubleshoot what output chip is defective out of six amplifier output ICs in unit, check by professional is needed to solve this issue.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Jan 14, 2011 | Sony Audio Players & Recorders
When I turn on my Home Theater Sony Model hcd-hdx576wf this message appears, "protector, push power". what I can do?
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
1. Check the speaker wires and speakers for proper connections.
2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
Dec 17, 2010 | Sony Televison & Video
Oct 18, 2009 | Sony DAV-DX375 System
120 people viewed this question
 Grubhead
Grubhead
