Question about Brunton Sport & Outdoor - Others
Brunton Storm lighter repair
My Brunton Storm (waterproof) lighter is working intermittently. takes multiple attempts to light. sometimes coil glows, sometimes it doesn't. sometimes it glows but doesn't ignite. who can repair this lighter as Brunton does not produce or support them any more?
Controlfrk
  • 304 Answers
SOURCE: My dryer doesn't produce heat. the coil ignites
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. In your machine, it appears Amana doesn't sell the coils as a separate item and the whole valve needs to be replaced. The part number is Y504091.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires or death by asphyxiation.
At front, remove 2 screws near floor at the bottom of the lower front panel. Pull bottom of panel toward you and down. The gas valve should now be accessible on the left. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Reverse process to re-assemble.
Posted on Sep 17, 2009
SOURCE: glow ignitor works, but no flame ignites. ohmed out gas valve coil with wires disconnected = OL is it my coil?
You have a bad flame sensor. Replace it.
Posted on Sep 18, 2009
aexl
  • 212 Answers
SOURCE: I lost the bottom cap
Hi there! The only place that will sell Brunton Helios parts is Brunton itself. You can get in touch with them through numbers on this page -> http://www.bruntonoutdoor.com/contact.php. They may not support the product any more, as it is legacy. I would try contacting them first, and then check out second hand stores and pawn shops for a new one. Good luck! Alex
Posted on Jul 05, 2011
  • 910 Answers
SOURCE: Unable to use either the oven or the broiler of
Can you smell or hear gas when you try and ignite the oven or broiler?
Posted on Jul 09, 2011
  • 4736 Answers
SOURCE: I have a Kenmore Quantum
The problem you're having is related to the OPD Valve in the Propane Tank. But, it is solvable by following the instructions below.
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling and thanks for choosing FixYa.
Posted on Aug 09, 2011
Panasonic Stereo Colour TV Model TX - 76PW10A Has frequent intermittent problem of no sound. Typically takes multiple tries to get sound working. Sometimes nothing comes on. Sometimes sound will...
i think there are no problem with your tv sum wire is missing it place
did u put headphone to TV sumtime if u plug a headphone in tv headphone jack again u short out your problem
Oct 19, 2008 | Panasonic Televison & Video
Playstation 3 does not turn on...
If it s Green, then YELLOW not a lighter shade of green, then red, then you my friend have got the YLOD (Yellow Light Of Death). there are multiple fixes for this. I myself have suffered the YLOD. This fix here is the most popular. Please be careful when attempting this type of fix as you could damage your system further. WARNING!!!!! This method should only be attempted by those familiar with the inner workings of a PC or equivalent. This should not be attempted by those with little to experience with micro electronics. WARNING!!!!!
I take no responsibility for anyone trying this method to repair the YLOD nor does the creator of the video or YouTube.
Dec 03, 2009 | Sony Playstation 3 (PS3) Console
No picture on startup and random remote cntrl functions stop working
Common problem on this set is the main board p/n AGF33761101. However, you might try a 'quick fix' mod on this set which involves locating and bypassing components.
I do think that the replacement board just have these 4 coils bypassed on them already, so you might be able to save some $$$ if you're electronics-savvy by removing and discarding coils l4010, l4011, l4012 and l4203... then jump the solder pads they were on with small bits of wire, making very sure not to short to ground. Good luck!
May 18, 2009 | LG 32LC7D Television
Blackberry Storm Screen
 There is a Blackberry Repair Guide that shows how to open a Blackberry 8900 Javelin and the storm is very similar. Check for any loose connections inside, otherwise you may need a new screen. Once it is open it's as easy as taking the broken screen off the front assembly and installing a new one, the parts are available on ebay. There are also third party blackberry repair services that will do this for you if you aren't covered under any other warranties.
Apr 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
Cigarette Lighter Pulled Out
The part that Pulled out Should Screw into the Part that is still in the Car.
Jan 21, 2009 | 1999 Mitsubishi Eclipse
JVM2050 Doesn't cook food sometimes
Not the magnetron if intermittent. Probably a bad smartboard. Easy to replace if you know the basic precautions to take.
Mar 05, 2008 | GE JVM2050 Microwave Oven
One control button not working
Attempting to repair the buttom will compromise the units waterproof integrity. Contact magellans service dept.
Oct 24, 2007 | Magellan eXplorist 400 GPS Receiver
Sport & Outdoor - Others Logo
94 people viewed this question
Top Brunton Sport & Outdoor - Others Experts
Are you a Brunton Sport and Outdoor - Other Expert? Answer questions, earn points and help others
