Question about Sewing Machines
How do I lower the feed dogs on the Victoria sewing machine
SewTechWayne
  • 186 Answers
SOURCE: Raising and Lowering the feed dog on Janome 4900 MC
These machines are known to have this problem. The feed lift cam has a groove worn in it that won't allow the feed dogs to come back up. It is on the lower shaft and needs to be replaced. You can get the feed dogs back up by taking off the needle plate and lifting them up manually while turning the hand wheel. They should stay up until you drop them again.
Some people will not replace the cam and live with it.
good luck!
Posted on Feb 08, 2009
  • 3 Answers
SOURCE: Dropping Feed dogs on kenmore model 19233
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Posted on Mar 07, 2009
SOURCE: feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
Posted on May 01, 2009
  • 13 Answers
SOURCE: How to Drop Feed Dogs on Sewing Machine...
On many machines you tilt the machine back on its hinges to see the underside and there you will find a thumbscrew to lower the feed dogs...you also need to be sure that your machine is capable of having its feed dogs lowered...not all machines can do this!
Posted on Aug 28, 2009
madelinesalo
  • 59 Answers
SOURCE: machine runs only in reverse and feed dogs go up and down
adjust the wheel of your machine
Posted on Apr 03, 2010
How do I raise the feed dogs in a Brother LS2125 sewing machine as they seem to be lowered?
Perhaps you will find the answer here:
LS 2125 2125i 2129 United States Brother Solutions Center
FWIW, the manual indicates that your feed dogs do not lower. Instead, you are provided with an accessory that covers the feed dogs when you wish to use the machine without feed dogs.
Jan 15, 2017 | Brother LS-2125 Mechanical Sewing Machine
How do I lower the feed dogs on this machine
Joyce, Some machines do not have adjustable feed dogs. Do a Google search your make and model# manual or how to lower feed dogs. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How do raise or lower the feed dogs Brother
Tutorial Adjusting Feed Dog Height and Position ABC Sewing Machine
What Are Sewing Machine Feed Dogs and How Do they Work
Aug 23, 2016 | Sewing Machines
How do i lower the feed dog for free motion sewing??
Oooh, consult your owner's manual. Frequently, industrial machines are limited in their capabilities so your machine may not have the feed dog lowering ability. Some other domestic machines without the capability can use a plate to cover the feed dogs while free motion quilting, but that probably wouldn't be a good thing to try if your machine is not made for sewing without the feed dogs in use.
Nov 05, 2015 | Juki DDL-5550 Industrial Straight Stitch...
I have a singer touch & see sewing machine, I need to change for quilting but there are no visible switches to lower the metal times under the foot.CAN ANYONE HELP I'M ON A DEAD LINE. THANKS,
I don't know this machine but in most machines the feed dogs are normally lowered from a switch beside the bobbin case behind the door of the bobbin case.
Jun 14, 2015 | Singer Sewing Machines
Janome 3050 feed dogs wont come back up
Dropping the Feed Dog
The feed dog can be lowered with the drop-feed lever for sewing on buttons etc.
  • Shift the drop-feed lever to the right to lower the feed dog.
  • Shift the lever to the left to raise the feed dog, it will return to the up position when the machine is started.
NOTE:The feed dog should be in the up position for regular sewing. Turn the handwheel toward you to check if the feed dog comes up after setting the lever in the up position
JANOME DC 3050 User Manual Page 9
May 24, 2015 | Janome Sewing Machines
How do I lower the feed dog on a Brother LX3125?
Look on the back of the machine near the feed dogs for a lever to lower them.
If there is none then you need a feed dog cover (or darning plate) that goes over the needle plate.
good luck!
Feb 23, 2015 | Brother LX3125 Sewing Machine
Feed dog on singer m756 won't pop up
If this is a combo embroidery and sewing machine, the feed dogs have a switch to raise or lower them. If this is just a sewing machine, your feed dog linkage may be broken.
Jul 15, 2014 | Singer Sewing Machines
Lower feed dogs
had a quick look at the manual for this at www.singer.com and I'd say your machine doesn't have the function to lower the feed dogs, many don't. It shows a darning plate which goes over the feed dogs to sew on buttons so if you are wanting to do free motion embroidery or similar, then use this plate to cover up the feed dogs.
Oct 10, 2013 | Singer 1507
Aug 25, 2009 | Janome Memory Craft 5700
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Dec 31, 2007 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
