Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Kenmore Refrigerator: Freezer not freezing
Freezer not freezing all the time.
Cleaned coils and now ok for awhile.
Please advise
    Sergeant:
  • 311 Answers
A blocked condenser can cause a warm up situation,and after youve done this you have to wait 24 hours before making desision on out come.but other possiables are condenser fan motor slow,its fan blade dirty.defrost problem,frost on back frezer panel can be a sign of issue.evap fan moving air slow[inside fan]run time,is it running enough[thermostat controls that]if all those ok could be restriction in sealed system,that where the freon curcit.if moisture,or particles they can get caught in the cap tube[small tube to create persure so then freon expans to a gas]that should give you a few ideas.God bless ,tom
Posted on Jan 04, 2009
  • Thomas Malailua
    Thomas Malailua Jan 06, 2009
    please rememb er to help me with my ratings,thank you
Kenmore elite coldspot model 106.74219400 freezes in the fridge never gets above 5 or 10 degrees and it never shuts off.
there is a flap in the refrigerator side usually near or behind the light bulb the freezer side is thermostatically controlled with the compressor being controlled. On the refrigerator side the cold air comes from the freezer side. when this flap is open the refrigerator will cool continuously, Check the flap or the duct assembly
here is an illustration of the part
http://www.repairclinic.com/Kenmore-Refrigerator-Model-10674219400-ID-927868-Duct-Venting-Parts
Apr 14, 2013 | Kenmore Refrigerators
AMANA SIDE BY SIDE refrigerator/freezer . Freezer freezes intermitently, and then stuff thaws. Cleaned the botton coils, didn't help. unplugged and re-booted. didn't help
HI.intermitent faults r allways abit problematic .but run through some basics ok?1-after defrosted freezer works ok?2-how long for.if ok then all u can do is change defrost timer and t/stat one at the time or together.clean condensig unit thoroughly.good luck.ali
Jul 05, 2012 | Amana Refrigerators
Kenmore 596.58642890 not cooling. Compressor is working. Fan is working. Coils are clean. We completely cleaned everything and turned it back on around 12:30 today. Temperature is only down to 60...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 21, 2011 | Kenmore 53082 / 53084 Side by Side...
21' bottom freezer kenmore refrigerator-no ice maker-the fridge is super cold and freezes all my vegetables and fruit. We have cleaned the coils, cleaned the fridge, and it just keeps freezing. Fridge is...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 02, 2009 | Kenmore 21.0 cu. ft. Bottom Freezer...
Refrigerator not cool, freezer ok
Either the freezer continues to freeze up (most likely due to low refrigerant, due to a leak), or there is an obstruction between the freezer and the refrigerator (refrigerators get their cooling from the freezer).
Given that it works after you defrost it, I'm going with low gas. Call a professional to see if the leak can be fixed. If the unit is more than 10 years old, just get a new one.
Aug 22, 2009 | Kenmore Refrigerators
We have an older refrigerator
Does your freezer have a auto defrost mode? If so, the components to this may have failed. If not, when is the last time the freezer was defrosted? You may have to manually defrost in order to get proper freezer function.
Let us know the results if this works.
Aug 28, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore Refrigerator-Freezer top
install a defrost drain tube heater call sears for a part number have the model handy befor calling
Apr 21, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Kenmore side by side refrigerator model 106.56532400
Thanks for taking this question.
Kenmore 22 cft side by side does not have air circulation. Freezer is cold at the bottom (ranges 5-45 deg from bottom to top). Refrigerator section is 30- 60 deg from bottom to top. Thermostat is good; compressor is working; no ice deposit on the evaporator coils; condenser coils have been cleaned; defrost heater is working. I do not feel the air draft I used to notice whenever opened refrigerator door. Is it possible that the air recirculation fan not operating. Location of this fan in the refrigerator? Regards, Prem
Feb 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer is freezing up.
Have a look at your door seals - if they're not airtight, the fridge will just suck in water vapour and freeze it. A.
Mar 25, 2007 | Kenmore 64522 Top Freezer Refrigerator
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
