Question about MSI MS-U135DX-1679ZA Netbook
I have no volume on my MSI note pad i have opened the volume controller in the control panel but it will not allow me to alter the volume it stays on zero how can i get some volume
I have no volume opened volume controller in control panel it stays on zero and will not allow me to alter it to max
2 Suggested Answers
SOURCE: can,t find driver for ethernet controller
u can find all u need here: http://www.clubic.com/telecharger-pilote-23094-0-msi-845pe-max-l.html
Posted on Jan 27, 2010
How do I alter the volume though the tv not the control
If the volume level can't be adjusted with the front panel control of the TV; the micro-switches at its front panel should be checked and replaced. Contact any service technician.
Feb 19, 2015 | Polaroid Televison & Video
Volume stays at 100 i try to turn it down and goes back up
Does this TV have a touch-pad on the TV for the channel/volume/on-off control of the TV? If it does, I would suspect that this board has a problem that is keeping the volume+ function stuck on.
Mar 21, 2014 | Element Televison & Video
How to use Sino Spa spa controller pad
controls operate the pump to circulate the water..there are controls for bubbles and an air pump to increase the volume of the bubbles..and a setting to run the tub slower to allow heating of the water..
Dec 18, 2013 | Pool & Spa
Where is volume control on dell laptop
Hi there! this might work :)
1.Click once on the speaker icon in the lower right corner of the laptop screen on the task bar to open the volume control.
2.Click and hold the slider control with the left mouse button or the left button on the touch pad, then drag the control higher to increase the volume on the built-in speakers.
3.Click the "Start" or Microsoft flag button in the lower left corner to access the Dell's Control Panel. Click twice on the Control Panel.
4.Click "Hardware and Sound" then click "Adjust System Volume" under the "Sound" listings.
5.Click and drag the slider control to adjust the sound level, then click the "X" box in the upper right corner to close the application.
Sep 30, 2011 | Dell Tablets & eReaders
I have no sound , i am useing onboard sound on the msi p4m900m3 mainboard
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Sep 30, 2011 | MSI P4M900M3-L Motherboard
Hi im using ms-7312 ver.1.0 motherboard newly formatted by sound is not coming pls help me
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 29, 2011 | MSI K9MM-V Motherboard
MY CONTROLLER WILL NOT CHANGE PROGRAM OR ADJUST VOLUME
Carefully open the remote controller unit and look inside for possible failure of the carbon pads or the remote control PCB tracks.So first of all open to clean the padds and the pcb then check specially on the volume controller pads, use old pads to be stuck on or carbon dots that are available for repairing remote controllers.Repeat this for the program pads. If the fault does not clear then look into the PCB section of the volume tracks and program tracks and use a carbon pen to make the tracks prominent. Hope this works. Good day
Aug 11, 2010 | Bose Wave Music System Remote
Help Anyone??
Hi there Grusm,
It seems from what you have wriiten, your recording setttings have gone back to playing mode on your computer. Try the followings see if it sorts the problems you are having:-
  • Click Twice or so on the speaker on the right hand side of START manu at the bottom right hand. A speaker volume control panel will open up displaying volume control,wave,sw synth,phone line,Aux volume,video volume, mic volume,line In and audio in.
  • Make sure on the bottom of this panel volume is not ticked muted. if it is untick it.
  • On the top Manu you Options and Help. Click on Options
  • Select properties and Click on it, when it opens up change the setting from Playback to Recording by clicking in the round ring in front of the Recording sign. once you done that you can select the controls on the volume control panel to your requirement. Keep this volume panel minimise it while you are recording the sound, so if it needs altering you have it there infront of you at the bottom on the start manu. I hope this helped.
Jan 06, 2008 | Adobe Audition 1.5
Lighting the oven
Control Lockout (on some models)
Your control will allow you to lock out the
touch pads so they cannot be activated when
touched or cleaning the glass panel.
To lock the controls:
Touch the 9 and 0 touch pads at the
same time for 3 seconds until the
control beeps twice. The display will
show LOC continuously and the time
of day if not blacked out.
NOTE: All cooking and timing functions will be
cancelled when locking out the control.
To unlock the control, touch the
9 and 0 touch pads at the same time
for 3 seconds until the control beeps
twice, and LOC will be removed from
the display.
NOTE: Some models have a Control Lockout
pad. Touch and hold it for 3 seconds to
lock/unlock.
Gas/Control Lockout (on some models)
surface burners, oven burners and control
panel so they cannot be activated.
To lock/unlock the controls:
Turn all surface burners off.
Touch and hold the Gas/Control
Lockout pad for 3 seconds until the
display shows LOC ON.
To unlock the control, touch and hold the
Gas/Control Lockout pad for 3 seconds
until the display shows LOC OFF.
When this feature is on and the touch pads
are touched, the control will beep and the
display will show LOC ON.
 The control lockout mode affects all
controls. No controls will work when this
feature is activated.
 The adjustment will be retained in memory
after a power failure.
Nov 30, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
MSI MS-U135DX-1679ZA Netbook Logo
22 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
