Question about Packard Bell Computers & Internet
How to check for short or replace
Can i replace with another motherboard
  • Packard Bell Master
  • 32,281 Answers
Very difficult to trace the short. I suggest you install a new motherboard.
All motherboard manufacturers have standard mounting holes, select a well known brand such as Gigabyte, MSI, etc.
Posted on Nov 02, 2012
I have a mother board i use to replace the fuse but it always exploding
A fuse is meant to blow before a component blows as a safety mechanism. If it's constantly blowing that means you have a short somewhere. Check the capacitors for obvious bulging or leaks and replace anything that looks like it's shorting. If you can't figure it out you need a new motherboard
Mar 17, 2014 | Computers & Internet
Dead
Hi
THe most common beeps that you will encounter 95% of the time in repairing PC's are:
1 beep - computer ok
continous beeps / long beeps - memory error
continous short beeps - bios boot block/corrupted bios
1 long beep followed by 3 short beeps - video card error
or this might help
you can check out this list
AMI BIOS
1 short - Computer ok
2 short - RAM failure
3 short - Parity RAM failure
4 short - System timer failure
5 short - Motherboard failure
6 short - Keyboard controller error
7 short - CPU failure
8 short - Video RAM failure
9 short - ROM BIOS error
10 short - CMOS read/write error
11 short - Cache RAM error
1 short, 3 long - Memory failure
1 short, 8 long - Video adapter failure
Check board/chipset makers website for more infomation.
AWARD BIOS
1 long - Memory error
1 long, 2 short - Video error
1 long, 3 short - Video failure
Continuous beeps - Memory or video failure
note that AWARD relies on motherboard manufacturers to develop their own beep codes - the above are only their own internal codes. You will need to refer to your own manual for an explanation of precise codes.
Standard IBM beep codes.
No beep - Power supply or motherboard failure
1 short - System is ok
2 short - POST error (code displayed on screen)
Repeating short - Motherboard failure
1 long, 1 short - Motherboard failure
1 long, 2 short - Video display adapter failure
1 long, 3 short - Video display adapter error
3 long - Keyboard error
Pheonix beep codes
1-1-3 CMOS memory failure
1-1-4 BIOS failure
1-2-1 System timer error
1-2-2 Motherboard error
1-2-3 Motherboard error
1-3-1 Motherboard error
1-4-1 Motherboard error
1-4-2 Memory error
2-x-x Memory failure (any number of other beeps)
3-1-x Chipset error (any number of other beeps)
3-2-4 Keyboard controller error
3-3-4 Video adapter failure
4-2-4 Expansion card failure
4-3-4 Time of day clock failure
4-4-1 Serial port error
4-4-2 Parallel port error
4-4-3 Math co-processor error
pls rate as fixya if it helps. thanks
Jul 04, 2008 | Acer Aspire 5100 Notebook
Power on, but immediately goes off. cpu fan starts, then stop. power lights remains on, battery light as well. possible issue, processor may be bad.
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your computer hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and to have an end so any faulty leads will end up with a computer error
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the central processing unit
make sure you have enough RAM and the ram modules are securely seated with no dust in the sockets
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
hope this help you
Aug 20, 2011 | Gateway CX2618 Motherboard 104892 -...
POST
try removing the small button cell on *********** board and replacing it after say a minute or so. maybe your system will boot up.
Mar 01, 2010 | Intel Motherboard
KT4V MS-6712 VER:1.0 AMI BIOS beeps (2 very short, then 8 very short,multiple)
CHECK MEMORY CARD ( RAM), MAYBE ITS GONE..., TRY TO REPLACE WITH ANOTHER MEMORY CARD
Jun 27, 2009 | Intel Motherboard
Intel D915GVW whose VGA chip get short
if the only vga chip gone short, use an add on vga card for display. otherwise use the same board for the processor you have.
Jan 09, 2009 | Intel D845GVSR Motherboard
Bios problem
Standard Original IBM POST Error Codes1 short beep Normal POST - system is ok
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps 3270 keyboard card
PCHELL.COM Newsletter
If you would have read my E-book on Internet Security, you may not have ended up in PCHELL. Join the PCHELL.com mailing list and receive your free E-book now.
Name:
Email:
Tools for Removing Spyware, Adware, and Malware
PC HELL
Other Pages
Spyware/Adware Removal Help
MSBlast.exe Worm Removal
Welchia (Dllhost.exe and SVCHost.exe) Worm Removal
Uninstall McAfee Instructions
Uninstall Norton Instructions
Uninstall Avast Instructions
Uninstall AVG Instructions
Uninstall Antivir Instructions
How to Manually Run the Microsoft Malicious Software Removal Tool
Bloodhound.Exploit.6 Virus Removal
MyDoom Virus Removal
MiMail.C Virus Removal
Swen Worm Virus Removal
SoBig.F Worm Removal
Dumaru Virus Removal
BugBear.B Worm Removal
SoBig.E Worm Removal
Pop Up Ad Removal Info
KAK Worm Removal
MiMail.A Worm Removal
W95.MTX Virus Removal
Snow White Virus Removal
BadTrans Trojan Removal
Wininit Virus (Bymer Trojan)
Happy99 Worm Removal
VBS Netlog Worm Removal
Pretty Park Worm Removal
Sasser Worm Virus Removal
Backdoor SDBot.H Trojan Removal
VBS.Loveletter Help
Computer Security Information
Back Orifice Information
PC HELL Main Page
IBM POST Diagnostic Code Descriptions
100 - 199 System Board
200 - 299 Memory
300 - 399 Keyboard
400 - 499 Monochrome Display
500 - 599 Color/Graphics Display
600 - 699 Floppy-disk drive and/or Adapter
700 - 799 Math Coprocessor
900 - 999 Parallel Printer Port
1000 - 1099 Alternate Printer Adapter
1100 - 1299 Asynchronous Communication Device, Adapter, or Port
1300 - 1399 Game Port
1400 - 1499 Color/Graphics Printer
1500 - 1599 Synchronous Communication Device, Adapter, or Port
1700 - 1799 Hard Drive and/or Adapter
1800 - 1899 Expansion Unit (XT)
2000 - 2199 Bisynchronous Communication Adapter
2400 - 2599 EGA system-board Video (MCA)
3000 - 3199 LAN Adapter
4800 - 4999 Internal Modem
7000 - 7099 Phoenix BIOS Chips
7300 - 7399 3.5" Disk Drive
8900 - 8999 MIDI Adapter
11200 - 11299 SCSI Adapter
21000 - 21099 SCSI Fixed Disk and Controller
21500 - 21599 SCSI CD-ROM System
AMI BIOS Beep Codes
 1 Short Beep One beep is good! Everything is ok, that is if you see things on the screen. If you don't see anything, check your monitor and video card first. Is everything connected? If they seem fine, your motherboard has some bad chips on it. First reset the SIMM's and reboot. If it does the same thing, one of the memory chips on the motherboard are bad, and you most likely need to get another motherboard since these chips are soldered on.
2 Short Beeps Your computer has memory problems. First check video. If video is working, you'll see an error message. If not, you have a parity error in your first 64K of memory. First check your SIMM's. Reseat them and reboot. If this doesn't do it, the memory chips may be bad. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard.
3 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above.
4 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above. It could also be a bad timer
5 Short Beeps Your motherboard is complaining. Try reseating the memory and rebooting. If that doesn't help, you should consider another motherboard. You could probably get away with just replacing the CPU, but that's not too cost-effective. Its just time to upgrade!
6 Short Beeps The chip on your motherboard that controls your keyboard (A20 gate) isn't working. First try another keyboard. If it doesn't help, reseat the chip that controls the keyboard, if it isn't soldered in. If it still beeps, replace the chip if possible. Replace the motherboard if it is soldered in.
7 Short Beeps Your CPU broke overnight. Its no good. Either replace the CPU, or buy another motherboard.
8 Short Beeps Your video card isn't working. Make sure it is seated well in the bus. If it still beeps, either the whole card is bad or the memory on it is. Best bet is to install another video card.
9 Short Beeps Your BIOS is bad. Reseat or Replace the BIOS.
10 Short Beeps Your problem lies deep inside the CMOS. All chips associated with the CMOS will likely have to be replaced. Your best bet is to get a new motherboard.
11 Short Beeps Your problem is in the Cache Memory chips on the motherboard. Reseat or Replace these chips.
1 Long, 3 Short Beeps You've probably just added memory to the motherboard since this is a conventional or extended memory failure. Generally this is caused by a memory chip that is not seated properly. Reseat the memory chips.
1 Long, 8 Short Beeps Display / retrace test failed. Reseat the video card.
Oct 18, 2008 | Computers & Internet
Display problem
The most common beeps that you will encounter 95% of the time in repairing PC's are:
or this might help
AMI BIOS
AWARD BIOS
Pheonix beep codes
1-1-4 BIOS failure
1-4-2 Memory error
the vga board has failed, its a very common problem in acer laptops, you can get a replacement part from www.acerparts.com im not sure if they ship into us but for europe thats where I get my parts.
my acers vga failed two times, ones within warranty and 12months after that, I have to say that acer products are really bad quality, I'm not sure about the latest models but from what I've seen the vga chipsets have real issues with the motherboards and keep failing over and over again.
I have not looked inside your model but the vga is either integrated into the motherboard = that means the repair will cost the whole motherboard, better to buy a new one.
if your model has a removeable vga like mine does, then you can consider changeing it to a new one. contact acer parts.
One of the covers in the bottom is the memory, one is network and last one I don't remember.
here are the contact details if your acer is out of warranty
http://www.acerparts.com/contact_us.php
The parts for your model are at http://www.acerparts.com/index.php?cPath=561_562_1064
you will have to contact acer parts directly, it may be that the vga is build into the motherboard or then the vga parts are not listed.
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Jul 29, 2008 | Acer Aspire 5570-2758 Notebook
Mother baord beep sounds
Which model? Are the beeps 1 long, 2 short, 1 short, or just continuously short? Continuously = RAM needs checked and/or replaced (you can download either Memtest or the Microsoft Memory Diagnostics CD's to check it) 1 long and 2 short or 1 long, 3 short = VGA card needs checked
May 29, 2008 | Intel Motherboard
Pentium 4
the motherboard and the power box should be replaced. you hade a short and the power box went out and the mother board shorted out as well. If you replace the mother board you will see. This happens alot to people. Check out the numbers on the board at type it in the web and find out what kind you have. you can find motherboards cheap on ebay.
Dec 15, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Computers & Internet Logo
148 people viewed this question
Top Packard Bell Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Tony
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
