Question about Kenmore 24032\24036 Top Load Washer
Need to remove front of washer
Need to slide front off machine to check belts
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of your unit? Look under the lid for the model.
Posted on Nov 02, 2012
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: washer top
The following link should give you the steps necessary to remove the exterior washer casing to inspect the interior:
http://www.fixya.com/support/r397092-replacing_water_pump
The instructions are for replacing the washer pump, but the steps to gain access to the interior are the same. If the leak is coming from the FRONT of the washer, check the pump and drain hoses for loose connections. If the pump is leaking, it is not repairable (sealed unit) and must be replaced. If the leak is coming from UNDER THE WASH TUB, this is a symptm of a leaking tub seal, or cracked tub. This requires removal of the wash basket to replace either part. If the leak is coming from the SIDE of the wash tub after it starts to fill, check the air dome hose to ensure it is still attached and not leaking. This is a small air hose that connects to the side of the wash tub and runs to your pressure switch. It sometimes becomes loose or disconnected and leaks. If the leak is coming from the BACK of the washer, check the fill hoses and water inlet valve hoses. I hope you find this information helpful. If you need further assistance, please let me know.
Posted on Oct 19, 2008
How to acces washer belt assembly
Remove screws at bottom of front panel. slide front panel down to remove and gain access to machine
Nov 21, 2013 | Kenmore 98702 Stacked Washer/Dryer
How do I replace the moter belt
Hi
Use screwdrivers to remove the screws in the rear access panel of the washer and then pull off the panel.Locate the pump coupling, which is the rubber part that connects the motor to the water pump, and unscrew the clamps securing it to the motor. Once the coupling is removed, tension is removed from the belt.Slide the belt off of the pulley assemblies and slide the new belt in its stead. Reattach the coupling with the mounting clamps and check the tension on the belt. You should be able to wiggle the belt a bit, but not more than an inch or so.Close the access panel and turn on the machine. Run it through a cycle while observing it to see how it handles the belt change.
Also check the bellow link :-
http://www.ehow.com/how_5545267_replace-ge-washer-belt.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 02, 2011 | GE WSXH208A Front Load Washer
I need to know how to replace the belt
hello,
intruction
Front load washers are convenient and easy to use. They offer the convenience of extra capacity and tend to wash clothes a little better than their top loading counterparts. Sometimes, however, the belt that drives the drum will break and need to be replaced. Replacing a drive belt on front load washers is not that difficult and can be performed by many home mechanics.
  • Use the screwdrivers to remove the screws in the rear access panel of the washer and then pull off the panel.
  • 2
  • 3
  • 4 Close the access panel and turn on the machine. Run it through a cycle while observing it to see how it handles the belt change.
  • TIPS
    Be sure to unplug the washing machine before beginning to work on it. thnak and thanks for using fixya.
    Sep 30, 2010 | Whirlpool LHW0050PQ Front Load Washer
    I think a overloaded the washer and it wouldnt spin.
    Frigidaire washer will not take a overloaded tub without causing belt problems.
    Unplug the washer.
    Remove the 2 screws on the very bottom of the front washer panel.
    Slide the front panel down slightly and remove it from the cabinet.
    Inspect the belt around the motor pulley and transmission.
    If it is worn at all it needs replacing.
    You could plug the washer back in and set it to Spin cycle and watch for the motor to turn and the belt slipping to verify a bad belt.
    Keep your hands,fingers and tools away from all moving parts.
    Jan 24, 2010 | Frigidaire FGX831F Top Load Stacked Washer...
    Front loading GE washer making noise when the drum turns. sounds like a belt but I don't have the manual and don't know how to get the top off.
    there should be two screwws in the door jam on the front panel, they hold the top down
    once you remove those slide the top backwards then lift up
    let me know if its the belt
    Oct 19, 2009 | GE WSXH208A Front Load Washer
    My Maytag washer will agitate without clothes in it but will not agitate with clothes in.
    The belt is not doing it's job. It could be that the belt is worn, if so a replacement can be bought from a Maytag dealer. It is also possible that the belt is just not under the proper tension. Maytag motors are mounted in a slide, and tension is applied by a spring. if the grease in the slide gets old and hard, the slide will stick making for a loose belt. To access, you'll need to remove part of the cabinet. Pop the top loose at the front, remove two screws at the top of the front panel, and release the clips at the bottom to remove the front panel. Free up the slide with some light motor oil and re-assemble.
    Jul 12, 2009 | Maytag HAV3460AWW Top Load Washer
    Whirlpool Duet model GHW9100LQ1belt slides to back of pulley
    DO YOU HAVE THE CORRECT BELT? DO THE GOOVES MATCH THAT PULLEYS? IS UR MOTOR PULLEY ON GOOD? DO YOU HAVE ANY RESTRICTIONS IN UR DRUM /BASKET CAUSING IT NOT TO TURN?
    ARE YOU USING HE DETERGENT?
    May 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Belt amana washer replace mod lw6501w2
    I have a similar amana top load washer and just changed the belt. Here are the steps I used to change the belt:
    1) Unplug the washer
    2) Slide the washer away from the wall about 12"
    3) Remove two screws from the bottom of the front panel, slide the front panel down (there are 2 metal tabs that slide into slots on the top of the front panel - observe how they slide into/out of the slots). Set the panel aside.
    4) Remove the electrical connector (upper left of motor). Press down on the top of the plastic connector - this will undo the catch hook holding the connection in place). Observe how the belt is routed before proceeding.
    5) Remove 4 bolts holding the motor in place. You can remove the motor - even with the water pump and hoses in place - they will flex.
    6) Remove the water pump from the motor. There are 3 torx - head screws to remove. Note: You will need a star shaped (torx) head driver (Looks like a screwdriver but with a "star" head on it. The one I used measured just under 3/16 in diameter.
    7) carefully remove the water pump. - remove the old belt from main pulley under washer drum and also from the water pump. Insert the new belt - be sure to put the tension pulley on the outside of the belt.
    8) Reinstall the water pump to the motor. Reinstall the motor. Route the belt correctly in the water pump body area first - them slide the belt around the left side of the main drum pulley - rotate the pulley counter-clockwise and the pulley will tug the belt onto the pulley. Once in place - check bolts and belt - then reattach the electrical connector (remember to press the plastic lever on top of the plastic connector before sliding it in place). Reattach front panel - slide the top of the panel onto the metal tabs - then attach screws at the bottom.
    Feb 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
    I need to replace the motor in a front load washer frigidaire gallery
    remove fill hoses remove a zillions screws from back remove belt from pulleys remove 2-4 bolts from motor and slide toward front unplug wire harness
    Jun 30, 2008 | Frigidaire Washing Machines
    Whirlpool ghw9100l belt will not stay on drum drive pully
    I already fixed this problem with the same washer. You need to replace the metal yoke that spins. Its loose. Remove and replace the nut also that hold the yolk.
    Nov 07, 2006 | Whirlpool GHW9100L Front Load Washer
    Kenmore 24032\24036 Top Load Washer Logo
    13 people viewed this question
    Sal DeAngelo
    fordexpert
    Ed Mac
