Question about Echo Garden
Fuel oil mixture echo es 210 - Echo Garden
  • 37 Answers
SOURCE: oil/fuel mixture
Hi,the mix is 50-1 ratio.
thanks for using fixya
Posted on Nov 20, 2008
trippssmengi
  • 76 Answers
SOURCE: McCulloch 32cc blower, what is the fuel mixture, gas/oil
Do a 40:1 ratio to start, if it smokes cut it back alittle but 40:1 should be ok. Better to be alittle high on mix than not enough.
Posted on Jan 06, 2009
localwonder
  • 6784 Answers
SOURCE: oil gas mixture of model pb-2100 echo leaf blower
GAS-- Use 89 octane r+m over 2 (mid grade or higher) This gasoline known to be good quality. Gasoline may contain up 10 15% MTBE (methyltertiary-butyl ether). Gasohol containig methyl alcohol is not approved.
TWO STROKE OIL-- 50: 1 is usable.
please rate and god bless.
Posted on Mar 27, 2009
  • 107 Answers
SOURCE: I have an Echo 300E
Here it is straight from ECHO:
Link is http://www.echo-usa.com/faqs.asp
A 50:1 ratio with 89 Octane fuel can be used in all ECHO 2-stroke equipment, provided the oil is ISO-L-EGD and JASO M345 FC/FD certified. ISO-L-EGD and JASO M345 FC/FD oil must be used with a mid-grade (89 octane) or premium gasoline in all 1997 and newer engines.
A 50:1 Ratio = 1 US Gal. 89 Octane + 2.6 fl. oz. ECHO POWER BLEND OIL
Echo Power Blend Universal 2-Stroke Oil can be used in all of our 2-cycle air-cooled equipment ever made. You may also use this oil in any other brand of 2-cycle air cooled equipment, but it should always be mixed at the 50:1 ratio whether or not it was a 32:1 or 16:1 etc. machine. This oil is the highest quality 2-cycle oil on the market today. There is no need to have more than 1 tank of fuel for your 2-cycle equipment any more.
Posted on Apr 19, 2009
  • 122 Answers
SOURCE: what is gas:oil mixture for Echo PB-500t blower?
50:1 ratio, 2.6oz of 2 cycle oil to 1 gallon gas
Posted on Feb 26, 2011
What is the fuel/oil mixture for my echo pb 250 blower
Sometimes, the fuel ratio is stamped on the fuel cap. Your ratio is 50:1. Echo specifies using 89 (mid-grade ) octane Here is a chart that tells you how much oil you need in a gallon of gas...Just 1/2 it for a half-gallon mix. A copy of your manual is also here.
http://support.mtdproducts.com/app/answers/detail/a_id/347/~/two-cycle-engine-fuel%3Aoil-mixture-chart
http://www.echo-usa.com/getattachment/624aee9f-103c-416c-ae9b-55fb42dd94af/PB250es1112_010410_1.pdf
Jul 22, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
I have an older echo blower. just had it tuned up and adjusted and still running poorly. just wondering if it is my fuel mixture of 25;1
25:1 may be too rich a mixture. Clean your spark plug well. Then get some good synthetic 2 stroke oil and try a 32:1 mix or a 40:1 mixture. Here is a fuel mix chart for you use.
May 15, 2011 | ECHO, Inc. PB-251C Handheld Blower
What kind of fuel do you put into an Echo PB201 Leaf Blower?
The blower is a 2 cycle, so you run an oil and gas mixture. Here is the link for the owners manual.
http://www.echotool.ru/files/50_17_21-21G-00.PDF
Apr 08, 2011 | Echo Blower Nozzle Es 2400 Pb 200 201 2100...
Echo chainsaw 16in. model 280 E(P) or 290 EVL(P) \r\nLooking for the correct oil and gas mixture ?
The mixture for most echo products is 50:1 ratio. You can use the Stihl fuel mix in this unit .. The Stihl fuel mix is also a 50:1 ratio.
Mar 29, 2011 | Echo Garden
What fuel does my Echo pb500H use??? 2 stroke oil gas mixture????
2 stroke means that it is a gas mixture. 4 stroke means that there is no gas oil mixture.
Fuel is VERY flammable. Use extreme care when mixing, storing or handling, or serious personal injury may result.
Do not forget to rate the answer, Thank-you
Jan 02, 2011 | Echo Gas Blower 162 MPH 450 CFM Blower...
What 2 stroke fuel ratio do i use for the es 2400 leaf blower
50 to 1 don't use outboard 2 stroke oil. Use good oil echo, still, Husq ect.
Sep 27, 2010 | Echo Blower Nozzle Es 2400 Pb 200 201 2100...
Vacuum tube will not stay attached. ES 210 sn 6ehxs.o21 .. Has this unit been recalled?
Some ES-210 units have been recalled, yes. It does not appear that the recall affects your particular serial number. However, more info is available from the ECHO-USA website, found HERE.
If in doubt, use the "DEALER LOCATOR" link and call your nearest location.
Hope this helps,
Dolf-
Oct 12, 2009 | ECHO, Inc. Shred n Vac
Es 2100 blower/vac what is the correct fuel mixture
3.2 oz of 2 cycle oil to 1 gallon of gas 40:1.
Sep 30, 2009 | Echo Garden
I NEED AN OPERATING MANUAL FOR ECHO SRED N VAC ES 210
You can find a manual at this website http://www.echo-usa.com/documentation.asp?Model=ES-210&lang=E You'll need to know the serial number of your machine.
Mar 08, 2009 | Echo Garden
Garden Logo
64 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
