Question about Watches
I have a casio atc 1100, that has two batteries, i need to replace them , but one of the battery holders is insulated and the other one, isn
  • Ger Vermeulen
    Ger Vermeulen Jun 01, 2016
    Is it answered on which side the insulation should be placed?
5 Suggested Answers
upajos
  • 24 Answers
SOURCE: For Casio F-91W how do I replace battery? I see 4
Most of these resin-case F-series Casio sport watches use a fairly large lithium coin cell battery. Once the four screws holding the watch back are removed, you should be able to just pop off the stainless steel spring clip that holds the cell in place and pull it out, without having to remove any more screws. Be careful when replacing the clip, because it is asymmetrical and goes in only one way. Also be careful not to lose the tiny spring contact that connects the watch movement to the piezoelectric sound element glued to the watch back. If you lose the spring, the watch will still run, but the alarm won't sound anymore.
Posted on Sep 01, 2009
SOURCE: Casio 1170 ATC-1200 watch needs to have batteries changed
I'll post in case somebody still needs this. This is the general procedure to switch the ATC 1200 from meters to feet. You can also switch the ATC 1200 (1170) from C to F. This is very helpful if you change the batteries and the watch gets reset to meters.
Also note, when you pull out the two batteries, you may not get the watch to come up. This is because of a race condition when the watch gets power. To fix this, look for the AC mark on the inside of the watch. Under this marking, in a little space to the left, are two copper pads. Short this out with a small screw driver to get the watch to ground zero.
To fix the Metric measurements:
1. Go to the home screen on the watch. This is when the the 3 letter abbr for the day is at the top. Also, if you cycle the mode button, it is the screen where the final beep is "high."
2. Then press the "memory" button, which will take the home display to the data screen. This shows current time, pressure and temperature.
3. Hold down the adjust button, until the set screen comes up.
4. Tab the mode/select button on the watch until you get a flashing C. Then press the memory button to toggle to F.
You can adjust all the measurements from this screen.
Posted on Dec 30, 2010
escapement
  • 2334 Answers
SOURCE: what watch battery do i need?
If you are asking for that, it means you want to replace battery yourself, and if you do, you will have to open your watch anyway. So, open it, take the battery out and memorise all the writings on the battery. This is the type of battery you need.
Do not forget to rate, please.
If I was wrong with my guess, then submit all the writings on your watch caseback and dial, please....and do not rate yet.
Posted on Feb 28, 2009
  • 10 Answers
SOURCE: need to replace casio atomic solar watch 2608 gw-300
Check out this YouTube video which walks you through the battery change process:
http://www.youtube.com/watch?v=ogCz2vjUKVg
Posted on Jul 14, 2010
How to change the battery on my casio w-753 watch
change the battery on my casio w-753 watch Lee, Check the attached links,video,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
replace the battery in the watch casio 753 CAR FLIP REMOTE CONTROL ALARM...
How to replace the battery on Casio watch
CASIO 753
Aug 02, 2016 | Casio W753-1AV Watch
I am replacing the battery for a Casio #3011. Inside the back plate of the watch there is a note. "After battery replacement, contact AC with battery( ) using tweezers." What does that mean...
it is a tricky way but it can be done...
remove the clockworks completely (that's including the plastic casing) from
its housing
separate the plastic frame from the clock
remove the little screw you spoke about earlier
look at the edges of the big battery clip holder, they latch to the clock
housing at three locations,
pry-off the cover plate...Presto battery can be removed. Before you
reassemble in reverse order make sure that the pushbuttons in the housing
can move freely, lube with light oil if necessay or remove them completely
to remove sweat and dirth
Aug 01, 2008 | Casio Watches
How do I replace the battery, in a Casio G-Shock G-2300 9V watch?
Your watch is a solar powered watch and normally you don't need battery change .Nevertheless,if (as it is an old Casio model),you are convinced that battery is the cause of your problems,then replace.
1) You have to be absolutely sure that you are able to carry out the procedure.
2) IMPORTANT!! Pse note that the specific battery IS NOT an ordinary battery as it is rechargeable.DO NOT TRY TO REPLACE WITH AN ORDINARY ONE.RISK OF EXPLOSION on your wrist.+total damage of the watch.New battery has to be exactly the same with the old one (ID.code).Can be ordered on E-Bay,I suppose.
3)TOOLS:Watchmakers screw drivers + philips small size screw driver (for backcover screws) + watchmaker tweezers + 2 finger rubber gloves.
Turn the watch upside down and carefully remove the four screws (try not to loose them).Remove the strap if needed.Gently remove the back cover.Pay attention as there must be 1 or 2 tiny springs embeded on the mechanism.Keep them in place and try not to loose them.You have to remove the plastic cover (pay extreme caution to the spring/s) in order to have access to the battery.Unlatch and remove (if needed) the battery holder ( if can be removed-remember the position to put it back correctly).Take out the battery and check for possible leaks.Check the battery compartment cleaness.DO NOT TOUCH WITH BARE FINGERTIPS THE CONTACTS OF THE BATTERY COMPARTMENT.DO NOT TOUCH THE NEW BATTERY ON BOTH SIDES WITH BARE FINGERTIPS.Use the finger gloves.Put the new battery in place (do not force) and secure back the battery lamina holder.There is a AC(All clear-reset) contact on the mechanism.Using the tweezers touch one end on this contact and the other to the metallic body of the mechanism.Lift the watch very carefully(as it is,upside down-without disturbing spring/s) and check if display is activated.By paying much caution put back the plastic cover correctly in position PAYING CAUTION TO THE SPRING/S. Clean up the back cover,gasket,and gasket furrow from dirt as good as possible.Check the gasket condition.Replace if needed.Apply a little amount of special gasket silicon compound all around the gasket,both sides.Put the gasket in place.Put back gently the back cover and screws in position.MAKE SURE TO POSITION THE BACK COVER CORRECTLY(in place and not upside down).Press it gently when in correct position before you screw.CHECK ALL AROUND FOR CORRECT CONTACT. DO NOT SCREW TOO TIGHT,DO NOT FORCE.Screw with fingertips until you meet resistance.
I hope this will help.
BRegards
Jul 04, 2014 | Casio G-Shock GW300CA-1V Wrist Watch
Casio not working
You need to Shortcut the battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs to get the watch started
Jul 29, 2013 | Casio F-91WG-9QDF F91WG 9 Digital Alarm...
I need the instructions manual for my casio atc 1000 to download for free please, if its possible....thank you...!
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Apr 08, 2011 | Watches
I have a casio cmd 40 i recently changed the battery and the keypad did work. it still switched on but the key pad was not working
hi lagathon121 I had the same problem after i replaced the battery and what i did was to short the + end of the battery plate with the - end for two seconds, apparently this will reset the watch. there is also a sticker pasted on the battery plate holder.
Oct 15, 2010 | Watches
Casio Triple Sensor ATC-1200 Module #1170 I cannot find a manual for this old, but very complex, watch anywhere
Charlessmall: I have a downloaded copy of the Casio ATC 1200 watch manual. I misplaced the original and downloaded it several years ago when it was still available. E-mail me at toddkj@yahoo.com. I'll e-mail a copy to you.
Sep 05, 2010 | Casio Watches
How do i replacs the batterie in a g-shock illuminator
<P>Thanks for contacting FixYa.</P><P>Found a great tutorial for you.</P><P>Ive been changing batteries for 25 years and I wouldnt touch this one, so best of luck to you!!</P><P><A href="http://forums.watchuseek.com/f43/how-change-battery-g-shock-19704.html">http://forums.watchuseek.com/f43/how-change-battery-g-shock-19704.html</A></P><P>If you do this one, then you should get in the biz for sure!!</P><P>Jewel</P>
Aug 26, 2010 | Casio GShock Illuminator watch
Jan 10, 2010 | Casio Watches
How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
May 12, 2009 | Timex Expedition 84601 Wristwatch
Watches Logo
735 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
