Question about Hitachi (HTS424040M9AT00) 40 GB Hard Drive
Compaq v2000 hard drive, bsod, willnot boot system
Ran diagnostic on drive and got fail code #2-07. cannot start in safe mode either.
    President:
  • 948 Answers
That is the end of the line for that drive, you need a new drive. You MAY be able to recover the data on the drive you have by installing it in another computer (or this one once you get a new drive and reinstall your operating system) as a second drive and copying what you need or just ghosting the whole drive. Sometimes if you put the drive in the freezer it will help.
If you have important data on this drive you may want to have a pro try to recover it. When drives fail they can destroy internal parts, so use it as little as possible during the recovery process.
Posted on Jan 04, 2009
Hp compaq nx6110 hangin when booting and difficult to recognise the hard drive
Try booting into safe mode by pressing F8 at startup until the boot menu appears. Then select "safe mode with networking". If it boots into safe mode then see if your missing some drivers in device manager. If you are then download and install them. Next run some anti-virus and anti-malware programs to make sure your system is clean.
Jun 01, 2012 | HP Compaq nx6110 PC Laptop
Dell inspiron 1545 Laptop computer is getting BSOD on boot, when first ran diagnostics got error: Hard Drive - DST Test Results - Fail Error Code 2000-0142 Msg Hard Drive 0 - self test unsuccessful status...
The error indicates that there's a hard drive issue. If it just happened after the hard disk is reinstalled, remove it and reinstall it. It could be a problem caused by loose connection or improper connections. If the same problem repeats, install the hard drive on another system (to verify whether it works on another machine or not and to confirm it still works). If it doesn't work on another computer/system then your only option to run the system is replacing the hard disk. If it works on another computer or if it's detected on another system, then there could be problem with the hard disk, eg. Corrupt Partition, Windows Corrupt etc....
First of all, try booting into Safe Mode. You have to press F8 during the startup to go into Advanced Boot Options. Once you are in the Windows Advanced Boot Options, select Safe Mode using the up and down arrow keys on your keyboard. If it still doesn't work, it's the hard disk issue. Try with another Hard Disk.
But if in case you can boot into safe mode, check the Hard Disk for errors. In other words, run Windows Checkdisk utility. Hope this helps.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Oct 10, 2011 | Dell Inspiron 1545 Notebook
I have error compaq #10008 fail changed hard drive but still no responce when i install new operating system, just blank screen
Hi ,
Lets start buy starting in safe mode , so press esc, f10 or f12what ever you see at boot up , go to the start button and click on it to open the control panel on the right , click on the control panel to find device manager , open the device manager and find the disk drive;s , left click on on hard drives and find your hard drive , right ckick on your drive and scroll to scan for hardware changes ,, after that right ckick again and go to prop . and see what the error code is and let me know ...now if your unable to start in safe mode , boot off the start up disk , and try to get in safe mode from there .... Let me know if this is a help , if not i will advise futher ...................Good Luck Roy
Sep 16, 2011 | Compaq Presario Notebook
When I try to boot up my computer, it will get to windows loading, then the BSOD appears. It then restarts and the process starts all over again. I have tried to run my Compaq Presario V2000 in Safe Mode...
That is an indication the disk is incompartible to computer. Second a compartible disk may have scatches of dirt requirng cleaning with damp tissue to reachive the installation process.
Feb 09, 2011 | Computers & Internet
Hello, My laptop will not start the windows set-up/Fresh Install scenario. after the drivers get loaded and says starting windows it goes to the BSOD error Stop 0x0000007B, I figure this to be a MBR virus...
In Figure 2-2 you can also see that the Windows service SPCMDCON.SYS has failed. From the BSOD, you should be able to gather the following information:
•The stop error number, which uniquely identifies the error
•The stop error parameters, which provide additional information relating to the specific stop error number
•Driver information is available if the source of the problem relates to drivers
Armed with this information, you are able to search online to establish the problem and hopefully a resolution.
In addition to the information available on the blue screen, if the system is able to be rebooted after the BSOD, either normally or using Safe Mode, it is useful to take a look in the System Event Log and view the error message. For example, a faulty driver during boot up usually has the stop error code STOP: 0x00000050 and an Error EventID of 1003.
If your system refuses to reboot successfully, or is trapped within a perpetual BSOD that restarts over and over again, you should take the following steps. Press F8 after the BIOS screen appears. From Advanced Boot Options, select Disable automatic restart on system failure, as shown in Figure 2-3. This allows you to read and make note of the information contained on the BSOD. You can then allow Windows to attempt a reboot. If the perpetual loop reoccurs, select another option, such as Safe Mode, from the Advanced Boot Options menu.
To disable the system from automatically rebooting, take the following steps:
1.Click Start, right-click Computer, and select Properties.
2.Click Advanced System Settings.
3.In the System Properties dialog box, click the Advanced tab. Under Startup and Recovery, click Settings.
4.In the System Failure box, clear the Automatically Restart check box.
These steps can also be configured if the system is booted in Safe Mode. There are over 300 unique stop codes, and most are quite rare. The full list
can be found on MSDN within the Bug Checks (Blue Screens) reference at
https://msdn.microsoft.com/en-us/library/windows/hardware/hh994433(v=vs.85).aspx.
Jun 11, 2017 | Sony VAIO VGN-NS140E/S Notebook PC
I recently had a BSOD problem with my Compaq now display problem
Try this, it may work, start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back. Otherwise you may have to bite the bullet, and do a new install, into the same directory as it is in now.
Feb 15, 2010 | Compaq Armada M700 Notebook
Blue screen of death presario v2000
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set first boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windows " then it repairs old windows then it loads again old windows.
Feb 11, 2010 | HP Compaq Presario V2000 Notebook
Won't boot up, Hard drive self test result #1-07 Fail
Hi there.
The hard drive has failed and you will need to replace it.
If the laptop is under a year old take advantage of the warranty and send it in to be repaired for free.
Good luck and thanks for using FixYa!!
Apr 06, 2009 | HP Compaq Presario V2000 Notebook
Laptop compaq v2000
your windows install is screwed up. i'd dig up your Windows XP CDand pop that in and do a repair install. if it still doesnt work then i'd enter the bios setup (hit F10 on compaq boot screen) and look in there for "Hard Drive Test" and run that. be aware it will take 70 mins on a 60GB hard drive, and longer for a bigger drive. if the hard drive passes the test then you may want to boot up the XP cd and do a fresh install, opting to format the drive. be aware that formatting WILL delete anything and everything on the laptop.
if the hard drive fails the test, then obviously you need to get a replacement drive and reinstall Windows on that. if the hard drive failed, any data on it is most defenetly toast.
Aug 16, 2008 | HP Compaq Presario V2000 Notebook
Unmounable boot volume
This is an operating system error, and you will need an operating system disc. You can try to repair or reinstall the operating system, but most likely the hard drive has failed and will need replacing.
Jul 19, 2008 | HP Compaq Presario V2000 Notebook
Hitachi (HTS424040M9AT00) 40 GB Hard Drive Logo
161 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
