Question about Kenmore Washing Machines
How to remove front from Kenmore washer to change belt
How to take front off kenmore washer to change the belt
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 02, 2012
  • 7 Answers
SOURCE: Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Posted on Jan 30, 2009
SOURCE: kenmore front load he3 washer: door wont unlock
happened to me once - I just unplugged the machine - waited a minute and plugged it back - it - then used cancel button
Posted on Mar 02, 2009
jsrock516
  • 5911 Answers
SOURCE: removing front panel from kenmore elite HE-3 front load washer?
If you've removed the screws and the panel sticks, tapping on each side will knock it loose. The panel should drop down, then off. You can also try propping the two front feet of the washer up slightly for better access. A 2x4 works real well. This will allow more room for the panel to drop and gives better access to the screws. The washer is very heavy, so you may need some assistance to lift the front. Either lift from the bottom, or place your hands on the front facing of the cabinet to push the washer back. DO NOT push on the door or control panel.
If you still need assistance, please let me know. I hope this helps you.
Posted on Jul 05, 2009
mgprice
  • 744 Answers
SOURCE: Kenmore 90 series washer w broken belt
Hello I'm afraid you didnt find a belt but maybe a piece of the coupling. Here are detailed instructions on replacing a coupling: from the limited information this sounds like it's going to be a broken coupling. Kenmores are usually direct drive machines made by whirlpool, this means they don't have a belt. Instead the transmission is connected directly to the motor via a coupling. This is what a coupling looks like: 0c6b869.jpg To confirm this pull the machine forward enough that you can lean it back and it will stand back under it's own weight. Wedge something underneath the chasis so it does not fall on you while your accessing the bottom. Go under the Machine and locate the motor, You will see the pump connected to the motor connected to the transmission. 1. Unplug the wire harness from the motor then. 2. Use a screw driver remove the 2 clips holding the pump in place and remove or push the pump out of the way. 3. You will need to remove the 2 screws from the brackets holding the Motor in place with a nut driver. 4. With a screwdriver remove the 2 clips holding the motor in place (be carefull to support the motor as the clips comes off) 5. remove the motor and drop it onto the floor. Now you will see the coupling..one side on the motor the other side on the transmission the rubber connector in between. Replace the coupling if broken or worn and reassemble the washer in reverse order. Now you should be all set. Be aware you may smell rubber on the first couple loads this is normal after replacing a coupling. Good Luck!! if you have any other questions or concerns please feel free to comment again. Mike p.s Please remember to rate my solution since this helps me to help other people :) Thanks!
Posted on Jul 15, 2009
blueextc3221
  • 15935 Answers
SOURCE: Removing a pressure switch (Kenmore HE2 Front Load Washer)
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the "Load Level", "Load Size" or "Water Level". On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½" off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
How to change belt?
<P><SPAN style="WIDOWS: 2; TEXT-TRANSFORM: none; TEXT-INDENT: 0px; BORDER-COLLAPSE: separate; FONT: medium 'Times New Roman'; WHITE-SPACE: normal; ORPHANS: 2; LETTER-SPACING: normal; COLOR: rgb(0,0,0); WORD-SPACING: 0px; -webkit-border-horizontal-spacing: 0px; -webkit-border-vertical-spacing: 0px; -webkit-text-decorations-in-effect: none; -webkit-text-size-adjust: auto; -webkit-text-stroke-width: 0px" class=Apple-style-span><SPAN style="FONT-FAMILY: arial, verdana, sans-serif; FONT-SIZE: 13px" class=Apple-style-span>If this is a Kenmore FRONT LOADING WASHER, similar to the one pictured, the following link explains step-by-step, how to change the drive belt:</SPAN></SPAN><BR class=Apple-interchange-newline></P><P>&nbsp;</P><P><A href="http://www.fixya.com/support/r3609900-drive_belt_installation_whirlpool_front">http://www.fixya.com/support/r3609900-drive_belt_installation_whirlpool_front</A></P><P>&nbsp;</P><P>&nbsp;</P><P>There is no tension pulley on this model washer and there are no adjustments to tighten or loosen the belt.&nbsp; If you have diffiulty getting the belt to go back on the drive pulley on the back of the tub, or if this is NOT a question for a WASHER, please post back with your MODEL NUMBER and let me know.&nbsp; I hope this helps you.</P>
Aug 24, 2010 | Kenmore 44102 Front Load Washer
The machine is not spinning or tumbling, i went through the diagnostic test and that was the only thing it did not do. my understanding is that it is a belt that should be the problem how do i get at it?
I have the same washer and problem. I've had mine for just over five years with no problems, but I've had other top loading washers for as many as 12 years. I solved the problem with the Kenmore 44042 as follows:
1. Remove the washer from the laundry room and move it to the garage.
2. Go to Lowe's and purchase a Roper top loading washer for $300.
3. Install the new Roper in place of the Kenmore 44042.
4. Create and sign an agreement with yourself to never purchase another Kenmore product.
Sep 26, 2009 | Kenmore 44042 Front Load Washer
I need to replace the dryer belt from a Kenmore washer dryer comb
Remove the top lid, then the front panel to access the drum and belt. Unplug the dryer first.
Jun 07, 2009 | Kenmore Dryers
The tub on my kenmore model no.44052401 front loader won't turn
Always remember Electricity is dangerous and should be treated with respect.
Please pick a topic of your  problem by clicking ...hope you find this helpful :-)
  1. Automatic dispenser information
  2. How a washer works, good to read this first: Click here
  3. Has Kenmore or Whirlpool ever had a off-balance switch.....
  4. Help for storing an appliance
  5. How does the agitator come off my washer ??
  6. How to prevent socks from getting into your pump
  7. Inglis, Whirlpool and Kenmore belt washers - common problems Like timers, pumping problems, leaking, spinning, agitating and spinning/agitating at the same time.
  8. Inglis, Whirlpool & Kenmore belt drive washers How to take washer apart and how the washer works.
  9. Inglis, Whirlpool & Kenmore style washers which style do I have ?
  10. Inglis, Whirlpool & Kenmore - how to replace the belt
  11. Inglis, Whirlpool & Kenmore - how to tighten the belt
  12. Inglis, Whirlpool and Kenmore - how to replace a pump
  13. Inglis, Whirlpool and Kenmore - how to replace or check the wig/wag solenoid assembly from American appliance
  14. Inglis, Whirlpool & Kenmore - How to remove inner basket
  15. Inglis, Whirlpool, Kenmore belt drive washer - parts breakdowns
  16. Inglis portable washer belt change help From our friend Lee )
  17. Important disclaimer
  18. Missing cycles or timer stalls in middle of cycle
  19. My clothes have a whiting on them that looks like lint.
  20. My washer has a funky odor
  21. Slow water fills
  22. Washer Basics: Filling with water problems
  23. Washer belts: If your belt on any washer looks like this, replace the belt(s).
  24. Washer sample wiring diagrams
  25. Whirlpool newer style apt size newer washer
May 06, 2009 | Kenmore Washing Machines
How difficult to replace belt for front load clothes washer Kenmore 8 years old? I'm an average handyman.
the belt is held by pulleys, there is an ajustment bolt loosen this (should be marked) to loosen the belt. some models have a frame bolt that must be removed to get the belt off. this repair should be fairly easy to do.
Apr 21, 2009 | Kenmore 22422 Top Load Washer
Changing a belt on a kenmore washing machine
99% of kemore washers (anything after 1950)
dont have a belt. and
the back does not come off for repair, the front does, with the removal of 2 screws
If the washer does not agitate or spin the usual cause is a plastic & rubber coupling between the motor and gearbox. replacement gearbox couplings now have a metal hub to prevent further breakage.
If this matches the problem you are trying to fix, reply & I will step by step the replacement process, its 2 screws, 2 bolts, a hammer & dowel & some time, to fix
Oct 11, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore front load washer 44052
Mine issue was a loose connection. I removed the back panel and pushed in all the wires. The washer started working again. If you take off the back panel and the belt is broken then that could be your problem. Unplug the washer first.
May 22, 2008 | Kenmore 44042 Front Load Washer
Kenmore model 41743142200
Un plug washer remove belt by lossing the tensioner , bring to appliances center and assemble again /
Jan 07, 2008 | Kenmore 45081 Front Load Washer / Dryer
Washing Machines Logo
37 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
