Question about Epson Office Equipment & Supplies
No paper jam & new ink... both ink & paper light is on... (Turn the printer off and delete all print jobs. Open the printer cover and remove any paper from inside the printer and turn the prin
Using CISS
    Problem Solver:
  • 4 Answers
The printer sensor at the bottom of the printhead must be dirty. If you can, take out the printhead and clean the sensor with a paper towel dipped in rubbing alcohol or take paper towel soaked with alcohol folded to fit the path of the printhead and manually move the printhead several across the paper towel to clean it
Posted on Nov 01, 2012
2 Suggested Answers
michellearak
SOURCE: Epson RX595 says "Error-paper jam" but no paper in printer!!!
I got my printer to work (finally! #$^%$%) by moving the ink carriage back and forth a bit gently and then I sprayed a small amount of WD40 on a lint free small cloth and wiped the silver bar inside with it. I slid the carriage slowly from one side to the left and it seemed to stick less. I thought my printer was broken so I figured it couldn't do any more harm and lo and behold it worked! My printer went back to the normal screen after turning it back on and I am finishing the print job that I never thought would happen. YAY!
Posted on Apr 18, 2012
What is error 5101
When the message "5100 / 5101 Printer error has occurred. Turn off power then back on again. If problem persists, see the manual." is displayed, the behavior of the print head holder is interrupted.
Do you see a jammed paper or foreign material?
Did you install the print head properly?
Please see the following for detail.
If the problem persists, contact the service center for repair. Cause 1. Is there a securing material for the holder inside the printer? Summary There may be a securing material for the holder inside the printer.
(This material must be removed before using the printer.)
Open the Top Cover, then remove the securing material for the holder. See Also Cause Summary [ With the securing material ]
[ Remove the securing material ]
Then, close the cover, and turn ON the printer again. See Also Cause 2. Is there a jammed paper or foreign material inside the printer? Summary Stop printing, then push the power button of the printer to turn OFF the printer.
Open the Top Cover of the printer; then,
  • If there is a jammed paper or foreign material inside the printer, remove them.
See Also Cause Summary [ The printer with the Top Cover opened ]
( Paper jam )
After checking the above items, push the power button to turn ON the printer again.
CAUTION
When removing the jammed paper or foreign material, take extra care so that you do not touch the inner parts. Or, it may cause another printing problem.
See Also Cause 3. Is the ink tank properly installed? Summary If the ink tank is not properly installed, it interferes with the operation of the print head.
See the following images to get an idea of proper print head position. See Also Cause Summary [ When the ink tanks are not properly installed ]
The ink tank is not set firmly.
The ink lamp is not turned ON. See Also Cause Summary [ When the ink tanks are properly installed ]
The ink lamps are turned ON.
CAUTION
Always remember "Do not touch the Print Head Holder while it is moving."
Wait until the Print Head Holder automatically stops.
Do not even attempt to stop/move the Print Head Holder by holding it.
Canon PIXMA MX922
Apr 10, 2017 | Canon Pixma MX922
General error,open the printer cover remove any paper from inside the printer.turn the printer off and delete all print jobs.turn the printer back on .am already try all still doing same what can i do
I have open the printer cover and check there no any paper inside the printer only use tray and off it after 10 minute on it again still doing thing please help me ?
Feb 13, 2015 | Epson L800 - printer - color - ink-jet
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Turn the printer off and delete all print jobs. Open the printer cover and remove any paper from inside the printer and turn the printer back on. two red light segnul and not print .
Oct 06, 2010 | Epson TM-T60 Printer
General error Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes%2C turn the printer back on.
general error Delete all print jobs and turn the printer off. Remove any foreign objects from inside the printer. After a few minutes%2C turn the printer back on.
Nov 24, 2009 | Epson Stylus Photo R300 InkJet Printer
Printer says Paper Jam but it is not
  1. Remove the paper from the paper tray.
  2. Press the Power button and then wait for the jam to clear.
    • If the paper jam cleared, try the print job again.
    • If the paper jam is not resolved, continue.
  3. Remove the rear access door. Press the handle to the right, and then pull out the door.
  4. Remove any paper that is inside the printer by pulling the paper out from the back of the printer.
  5. Replace the rear access door.
  6. If the paper jam cannot be removed from the back of the printer, raise the product cover, carefully remove the jam from the front of the product, and then lower the cover.
  7. Re-load the paper in the In tray. Fanning the paper makes sure that the pages are not stuck together.
  8. Press the Power button ( ) to turn on the product.
  9. Open the document in the application in which it was created.
  10. Click File, Print, Properties, Printing Preferences click Paper/Quality tab.
  11. Verify that the type of paper specified in the Type is text box matches the type of paper being used. A paper jam might result if photo paper is specified in the Printer Properties dialog box, but plain paper is loaded in the printer.
  12. Click OK to try job again.
Sep 22, 2009 | HP Deskjet D2360 InkJet Printer
P2015dn paper stops in the through-output path with approx one-half to one inch of paper projecting. Jam indicator lights. Removing paper shows printing has completed over full length of paper.
please, gradually pull out the paper, off your printer and clear the scheduled print jobs through control pane-printers and faxes-select your printer to open then select all the jobs in it and cancel/delet, please before you on and start using make sure the papers in the feeder are aligned and fits the tray i mean set the tray according to the size of the paper, one minutes u can now on and start printing it will work 100% i use the same printer.
Jul 19, 2009 | HP LaserJet P2015 Printer
Constant yellow blinking light, no paper jam
I found this on the HP support site:
The power light is on, and the resume light is blinking.
c00109831.gifc01272271.gifc00109834.gif The printer might be waiting to complete a print job or to receive data from your computer.
Solution
Wait for the printer to finish the current task. The printer is waiting for the ink to dry on freshly printed paper.
Solution
  1. Remove the paper with fresh ink.
  2. Press the resume button.
The printer might be out of paper.
Solution
  1. Load paper in the paper tray.
The printer might have a paper jam.
Solution
Clear the paper jam. If the resume light continues to blink after the paper jam is cleared,
OR
if the print carriage is stuck or making a grinding noise, then follow these steps.
Solution
  1. Lift the top cover of the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cable from the back of the printer when the grinding noise starts. Unplug the power cable from the wall outlet.
  4. Movethe print carriage toward the middle of the printer (this proceduremight take a couple of tries to get the timing correct).
  5. Remove the print cartridges and close the top cover.
  6. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover.
The printer may be ready to eject banner paper.
Solution
Press the resume button to eject the banner paper.
Mar 14, 2009 | HP DeskJet 5550 InkJet Printer
Can't print
I would check out the paper pickup roller (and any other rollers. They may be dirty or jammed. Also, blow out the inside with low pressure compressed air and clean with a papertowl and 90% isopropyl alcohol. Most problems I have encountered like this are little bitty ink soaked pieces and paper "dust" gumming up the works. 90% of most problems in anything like this is paper "dust" and dried ink. You should wear latex "medical type" gloves when performing this. If you get ink on your fingers, a 50/50 solution of bleach and water will get it out.
Jan 28, 2007 | HP DeskJet 3820 InkJet Printer
Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to http://.i18nguy.com
Apr 19, 2006 | Epson Stylus C80 InkJet Printer
133 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
