Question about HP Office Equipment & Supplies
Hp laserjet cp4520 won't print from tray 2 - HP Office Equipment & Supplies
CompuGuy44
  • 432 Answers
SOURCE: HP COLOR LASREJET 3500 41.3 ERROR
Check your settings under the properties menu. and in the software your using.
Posted on Jun 26, 2007
  • 25 Answers
SOURCE: My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Posted on Aug 14, 2008
SOURCE: I need tray 2 to
I don't know if this is an HP-approved solution but I fixed mine by setting the tray 1 paper size to "Custom" (instead of letter).
Posted on Sep 04, 2008
SOURCE: hp laserjet 8100 8150 13.1.42
hp printers typically do not have an error message to cover every known condition, thus if the printer needs maintenance in an undefined area, it will invariably indicate a paper jam. The printer usually responds to the installation of a maintenance kit which will include transfer roller, pickup rollers, and fuser.
Posted on Oct 03, 2008
  • 4 Answers
SOURCE: HP Laserjet 4700 Always Defaults to Tray 1
Your tray 1 might be open (even just partially) or your manual feed setting might be on. You can find this setting under > Configure device / Printing / Manual Feed
Posted on Sep 18, 2009
What does a fuser look like? hp cp4525 color laserjet? How to clear the error?
A 50.2 fuser error will on most cases require replacement of the fuser assembly. It is located on the right hand side of the printer. Same side as the manual feed tray. Open the door and look for two blue handles near the top of the opening.
May 09, 2015 | Rhinotek Digital Imaging Suppl HP Color...
My HP laserjet p3015 wont print from tray 2 on its own. I have to press ok twice to bypass other instructions and then it will print
Hi is your document you are trying to print matching paper size that is in tray 2? sometimes you have a word document that is set to print to tray 2 but the paper in tray 2 is not the right size so hit Ok twice to confirm the size. also the adjustments on the tray may need to be fixed
Feb 08, 2015 | HP Laserjet P3015X Printer
HP Color LaserJet C2320fxi MFP toner tray won't open
i think your not handle correctly...you must contact service engineer???
Apr 18, 2013 | Hewlett Packard Printing & Imaging Hewlett...
Change default paper tray HP LaserJet 9050
When you click Print then right click on your HP ptinter - click Properties - Paper Quality tab - click Paper source and select Tray 2 - Click OK - then OK to print.
You can change the paper type in Tray 2 into Tray 1 and vice versa to save going into Properties to change the Tray selection.
May 31, 2012 | HP LaserJet 9050 Printer
How to set printing to tray #2? HP Laser Jet printer won?t stay printing on tray 2- They do a lot of printing from this printer in the wire room and for some reason it will not stay printing on tray 2-...
Thanks for the inquiry.
Print a configuration page from the menu to determine what Tray 2 is set to.Pull Tray 2 and make sure the rear paper stop is set to Letterhead. Make sure it snaps into place and is not broken or loose. If it's broken you may have to replace the tray.
On your computer got to the printer driver icon and right click for properties. Make sure tray 2 is set to 8 1/2 x 11. Tray 2 should now be the default tray unless tray 1 (Manual Feed Tray) is open and then it will pull from it first.
Let us know how this works. We need to eliminate these setup issues 1st and more steps can be taken if necessary.
Thanks for contacting FixYa.
Oct 20, 2010 | HP LaserJet P4015N Printer
My hp laserjet 3005 does has paper loaded in try 2 but always prompts me to load tray 1 to print. I would like the printer to print from tray 2 when it's loaded and try 1 is not loaded. Thank you.
Thank you for contacting FixYa with your printer inquiry.
This is a common problem. The device can be set to print from tray 1 if it is loaded, or to print only from tray 1 if the type of media selected is other than standard bond.
Pull out tray 2 and make sure the paper size adjustments are properly set to match your size of paper. If you are using std bond and the adjustments are set to A-4 it won't pull paper.
HP Control Print Jobs Support Page: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=115&prodSeriesId=1846088&prodTypeId=18972&objectID=c00764862
HP Support Page: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00764851&lang=en&cc=us&taskId=101&prodSeriesId=1846088&prodTypeId=18972
Hope this helps helps. Please keep us updated and remember to rate this answer.
Sep 02, 2010 | HP LaserJet P3005 Printer
Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Jan 08, 2010 | HP LaserJet 3800n Printer
Hp Laserjet 8150. Does not pick up from Tray 3....but the tray does lift
Start by pulling out tray 2 and setting it on the floor. Next take out tray 3 and slide it into tray 2. Print from tray 2. If it works, take the tray on the floor and put it into the tray 3 slot. Print from tray 3. If it fails change the feed rollers.
Nov 11, 2009 | HP LaserJet 8150 Printer
Hp laserjet must manually push button to print
Please print a configuration page from the control panel of the printer
- Menu > Information menu > print configuration.
- Check for paper handling details.
Following setting should reflect.
Tray 1: Any size / Any Type
Tray 2: A4 size / Plain Type
If the above settings are not reflecting in the configuration page, please change accordingly by browsing on the control panel of the printer to:
Paper Handling Menu >
Tray 1 Size: Any
Tray 1 Type: Any
Tray 2 Size: A4
Tray 2 Type: Plain
Let me know if that helps to solve the issue.
Regards,
Nikhil.
Jun 14, 2009 | HP LaserJet 2420 Printer
I hope this helps.
Aug 08, 2008 | HP LaserJet 4200 Printer
427 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
