Question about Refrigerators
Whirlpool refrig Model ET18 DEFROST TIMER
DEFROST PROBLEM DIAGNOSE
bobicehouse
  • 1524 Answers
SOURCE: Freezer thawed. Replaced temperature control, replaced defrost timer, replaced defrost thermostat. Compressor relay is cycling. No cooling still. Help!
Why were those parts changed? Was the compressor cycling on overload at the time?
If so, you should have first replaced the relay/overload combination and the see what happened.
Posted on Apr 26, 2009
aasc
  • 1606 Answers
SOURCE: Model ED20PKXAN01 side by side. Defrost timer
The timer could be set for accumulative instead of continuous . The one wire on the timer , set on the wrong terminal .
Posted on Jul 21, 2009
aasc
  • 1606 Answers
SOURCE: My Whirlpool refrigerator trips the main breaker of 40 Amps
A refrig cannot pull 40 amps in defrost , unless there is a direct short in the defrost system ( timer , heater , bimetal ) . I would use an extention cord ( for test purposes only ) , and try a different plug . Sounds like the circuit breaker is weak . In defrost , the MOST you should get , is 6 amps . This will not throw a 40 amp breaker . If you have an amp meter , remove the back refrig panel behind the refrig , and connect to one of the power cord lines (just not the green ground ) , turn into defrost and check the amps . This will tell you if short is in refrig , or weak breaker .
Posted on Sep 06, 2009
sonicboomele
  • 1557 Answers
SOURCE: HOW CAN I START A DEFROST CYCLE ON A WHIRLPOOL
you cant its controled by the pcb either the pcb has a short or the element is blown
Posted on Apr 21, 2010
  • 257 Answers
SOURCE: Where is the defrost timer
Behind the freezer panel at the top usually the right side but sometimes the left , snapped on to the aluminum tube, It's round a little bigger than a quarter, about an inch thick and has 2 wires usually brown and pink.It may be covered in ice if it is not functioning, So you may need a hair dryer to find it.
Posted on May 17, 2011
Have a whirlpool refrig. both sides freezing up even when set on lowest level model # ed5phaxtsoo cleaned coils fan runs allthe time.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 09, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Sep 06, 2009 | Whirlpool ES5FHAXS Side by Side...
Refrigerator and freezer not working
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 15, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Jul 20, 2009 | Whirlpool Refrigerators
I have a whirlpool refg that will not auto defrost.
Inside your fresh food compartment is a defrost timer hidden behind the tep. control panel. Most panes have a hole or plug you may need to remove to turn the timer. I need you to turn it clockwise slowly until compressor stops running. Wait about 30 min. to see if the refrigerator comes back on. If not we need to replace the defrost timer part # 482493
That is providing the model number above your post is correct.
Model Whirlpool ET22RKXG?
Let me know, Thanks Sea Breeze
http://servicepartstec.blogspot.com/
May 18, 2009 | Whirlpool 21.6 cu. ft. Top Freezer...
Whirlpool Refrig. stopped cooling with no warning. Freezer is freezing with ice build up on back wall. Thanks, Mike Strickland
Mike, Please send the complete model number so I can help you better. If your refrigerator has a defrost timer this could be the problem. You also can visit my site below and enter model or part number in the search feature. We also offer free help and assistance. , Thanks, Sea Breeze seabreezehvac@yahoo.com
Mar 29, 2009 | Whirlpool Refrigerators
Whirlpool ED25DQ - not colling
Need you to look inside the fresh food compartment and turn the defrost timer clockwise slowly.
d01b0a9.png part number 6 is defrost timer. When you turn it and compressor stops leave it there for 20 minutes and see if the refrigerator comes back on. If not the timer will need to be replaced, Let me know, Sea Breeze
Mar 22, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Refrig/freezer just quite working?
The defrost timer is located in the control panel in the fresh food section.
Look up under the panel and see a opening slightly smaller than a dime.
Put the blade of a butter knife in there and turn clockwise a quarter turn.
If the fridge starts working, replace the defrost timer.
Mar 10, 2009 | Whirlpool ET1FHMXLQ / ET1FHMXLT Top...
Wards/Admiral refrig/freezer
I put the fridge in manual defrost by advancing the timer. The defrost heater worked so the problem was with the timer not advancing to defrost every 6 hours. The plastic gears wear out over time.
Apr 18, 2008 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
