Question about Home Security
Honeywell security system chime battery replacement
Honeywell Ademco alarm panel reads Chime BAT 11
The answer above is incorrect. If the back up battery was low it says, "bat" on the screen and that's it. Since the "11" is being displayed, zone #11 on your wireless system as a low battery.
Jan 07, 2014 | Honeywell 5804 Ademco Wireless Security...
Chime
power cycle the system then hold star and pound that is a back door into programming hit #20 that will tell you the installer code then hit *99
once you have the installer code hit (Installer Code + 5 + 0) if you want to change the master code hit installer code + 8+02+new code + new code to create a new code
If you need further help, reach me via phone at https://www.6ya.com/expert/joshua_f823c77053c73844
May 16, 2013 | Honeywell Ademco Alarm 6150rf Keypad Lk
Ademco security system still doesn't chime when press 9 key
You need to enter your 4 digit code first. Make sure you do it half way quick.
Oct 24, 2012 | Honeywell Ademco 6160 Alpha Keypad Vista...
I can't get the system to chime when the door is opened. How do I turn chime mode on?
Enter your code and the 9. This turns on chime mode. If it still does not chime the zone is not programmed for a entry exit or perimeter zone.
Dec 25, 2010 | Honeywell Ademco 6160 Alpha Keypad Vista...
Honeywell Ademco alarm panel beeped repeatedly for about a minute and now reads, "Chime BAT." How do I fix this problem?
Find the metal box (usually beige) housing the control panel and open it. The system backup battery is inside. Take it to Battery Warehouse or similar store and buy a new one to replace it.
While you're inside the control box, read the model number of your control panel. That can be useful for future questions.
Sep 12, 2010 | Honeywell 5804 Ademco Wireless Security...
Sensor failure Simon 3 wireless home alarm
the sensor is going out, i would switch it out with another one in your house and see if the problem follows it there.
Sep 02, 2009 | GE Security Simon 3 Wireless Home Security...
Home Security Logo
199 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
