Question about Kenmore Dryers
Kenmore electric dryer 86273100
When turned on dryer drum won't turn, but machine hums
    Top Expert:
  • Kenmore Master
  • 9,472 Answers
What is the model number listed on the inside of the door?
Posted on Nov 02, 2012
  • 91 Answers
SOURCE: kenmore dryer hums but will not rotate
PRETTY OBVIOUS REPL/ MOTOR
Posted on Jan 03, 2009
dealt_soul
  • 296 Answers
SOURCE: Dryer Not Tumbling
Sounds like belt problems.
Posted on Jan 20, 2009
TheMobilian
  • 8220 Answers
SOURCE: kenmore dryer hums/heats up, but drum does not spin!
Depending on the type of door the dryer has, is how you approach the access of these dryers. Mostly though you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way. Yank out the tub. Clean the junk out (send me the coinery) oil the wheels and Idler with temp resistant zoomoil from ace hardware. Use this guide to replace dat belt Kimosabe:
BELT CONFIG 101
Posted on Apr 08, 2009
  • 66 Answers
SOURCE: press the start button on dryer, it hums but wont
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Posted on Dec 27, 2009
  • 2333 Answers
SOURCE: Heatman - you comments are
it could be the extra weight on the motor and the motor is bad,try this,open the door,push the door switch in with one hand and spin the drum with the other hand and have someone push the start button,if it runs and most of the time it does because you're helping it along you need a new motor.one more thing,if the filter is in front,remove the duct that the lint filter slides into and spin the drum,if the blower wheel moves with the drum you have a bad motor,if it doesn't you have something stuck in the blower wheel and it jams up the motor because it's attached to the motor shaft.
Posted on Jun 10, 2011
Testimonial: "Salde386 is the man. Helped me out and confirmed, clearly, what my issue was. Having an easy to talk to expert, reduce my frustration."
Dryer motor just hums, drum doesn't turn
check belt drum drive? check drum turns at all, it may be stuck.most drums turn with a belt. if it broke it is laying on the bottom of the dryer.didnt u see it??look again.
Apr 21, 2013 | Kenmore 98702 Stacked Washer/Dryer
KEYS750LQ0 dryer doesn't start it just hums when I push start
Check the belt. You may have to open the machine up to look. if the belt is ok turn the drum by hand and see if the motor pulley is also turning. While you are in there look for foreign objects that have wedged against the drum preventing it from turning.
Oct 09, 2012 | KitchenAid KEYS850LQ Electric Dryer
Kenmore dryer 70 series 66722690 - has power but won't start (no humming noise, no ticking noise from timer, and no light when you open door) nothing!
I would check the breaker before you go any further. Here are some things to remember when you do this. 1) The breaker for the dryer is generally located outside on the side of the house somewhere near the electric meter. Most 220vac breakers are, which include any electric range, cooktop, wall oven, etc. 2) When your checking the breaker, actually physically touch it. Sometimes breakers can trip a but the spring that actually pulls the breaker to off position is weak and by visual inspection would appear on. Just simply reach in and tap the bar lightly in the off direction. If it pops over to the off position, turn it back on then go check your dryer. If the breaker passes inspection, I would unplug the machine because there migfht be a short at the terminal block where the plug connects to the dryer. After you've unplugged it, remove the back and check to see if everything is ok. I have a strong feeling that you won't need to get to this point cause I'm betting on breaker.
Apr 30, 2012 | Kenmore Dryers
Kenmore Heavy Duty Plus Dryer 86273100 drum won't spin
How could the belt be in working order if the drum doesn't spin? Check to see if the belt has come off the motor. If the motor runs but your dryer doesn't spin, the belt is off. If the motor runs with the belt on but it still won't spin then you'll have a lot of black smoke because your drum is jammed. In other words, there are a number of things that could be wrong, but not very many.
Dec 22, 2011 | Washing Machines
My dryer makes a buzzing noise when i try to turn it on, but it won't turn on at all. What could the issue be?
The motors centrifugal switch may be stuck. Try having someone start it while pressing in the door switch while you rotate the drum with your hand by grabbing one of the drum vanes. I don't know which direction your drum rotates. Try both. This may start the drum turning on its own and resetting the switch.
Sep 20, 2011 | Kenmore 62722 Electric Dryer
Won't tumble. Drum won't roll. How do we open it
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 11, 2011 | Kenmore 62702 Electric Dryer
My dryer won't turn on and it makes a humming
heatman101
Aug 11, 2011 | Kenmore 600 6965 Electric Dryer
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
Drum will not rotate
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 25, 2010 | Kenmore 83142 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
