Question about HP Office Equipment & Supplies
Default black ink printing on hp 6600
I want to print in black ink only as the default on my hp6600 is that possible?
Democritus
  • 120 Answers
SOURCE: INK
Brother multifunction printers require that all ink be filled before you can print to it. If any ink is empty, you cannot print, even if you are printing only black.
Posted on Jun 27, 2008
  • 133 Answers
SOURCE: Black ink not working on HP C5180 Photosmart
Try a hard restart, which simply means unplugging the power cord of the printer, and replugging it after one minute has passed. If that does not work, then rerun the CD used to install the printer. Both techniques reprogram the electronics, to a certain extent.
You can also visit the HP website, to see what solutions are being offered for various printer problems. They probably have a number to call, in case you need to talk to a technician.
Hope these suggestions help you out.
Posted on Jul 04, 2008
Basti
  • 1447 Answers
SOURCE: Changed the black ink cartridge but can't print just black
Hi-
Sorry to say but NO you can't print if there are other inks which ae empty, thats one safety features of epson printers to prevent nozzle clogging. change the other ink carts as well for you to continue printing.
Posted on Sep 02, 2008
SOURCE: HP L7590 black ink printing poorly even with new HP cartridge
I have had the same problem It is the print head not the cartridge If your printer is still under warranty have the printhead(s) replaced if not Open the unit where the print heads are and hold the OK button for 5 seconds. The Print head carriage will move to the left
Carefully remove the KY (Black & Yellow) Print head with a cotton swab and alcohol clean the contacts and replace the printhead. If this does not work remove the printhead and then with a spray bottle spray the nozzle area on the bottom (DO NOT TOUCH THE NOZZLES AS THEY WILL BE DESTROYED) HP techs have told me this will void any warranty so act accordingly I use a printhead cleaning solution available from most any online ink supplier
Replace the printhead after it has dried out (less than a minute). The printer will then go through an alignment cycle and should print I had to do this several times before the print head performed as it should
Posted on Jun 16, 2009
  • 5 Answers
SOURCE: installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
Posted on Jan 22, 2010
How do I print black with hp6600 printer? new cartridges and all colors in printer
Normally when you start to print out to printer you get a selection window on the screen. you can select Black only there.
Hope this helps.
Feb 25, 2015 | HP Hewlett-Packard - Officejet 6600...
I have hp6600 it give small print how do I change it to lage
The print is controlled from the software you are using. Eg. Word Perfect. Choose your font size in the document you are using
Aug 03, 2014 | HP OfficeJet 6600 e-All-In-One Inkjet...
I was low on black ink and needed to print flyers , the Epson 630 asked me if i would like to continue printing and use other colors , i pushed yes, and have changed out ink and its still prints in r
Is it possible that you accidentally put the wrong colour cartidges in the wrong spots? Otherwise, it should work fine. Also, the printer's default is usually to print in colour, therefore even pages in black and white will usr colour, which uses up coloured ink. Always check the prooerties when printing to switch to b&w:)
Jan 20, 2014 | Epson WorkForce 630 Wireless All-in-One...
Out on magneta
Kim, check preferences and allow it t print black. It may work.
Dec 20, 2013 | HP OfficeJet 6600 e-All-In-One Inkjet...
How can I get my HP 6500a plus printer to PERMANENTLY default to black printing? I am needlessly using too much color and the default setting is only for a single document.
Hi
Go to right click at the printer icon on your computer and choose printer properties or printing preferences and from there choose the color setting to print in black alone. Regards
Jun 23, 2011 | HP Officejet 6500 Wireless All-in-One...
Why does color ink in Photosmart C7280 go down when you are only printing using black ink
Unless you set the printer settings to black and white it mixes colored ink to create black. It does this by default. Go to start printers and faxes. Right click on printer icon.Click printing preferences to change this.If youre using hp tool box setting is grayscale black only.
Hope this helps.
Plaese leave feedback.
Dec 10, 2009 | HP Photosmart D7160 InkJet Printer
Changing ink default to BLACK
Not possible.
Epson uses the black cartridge mostly, but also adds color to the black printing in order to keep the color inks from drying in the print jets on the printhead.
They also make lots of money that way...
===sorry===
Sep 14, 2009 | Computers & Internet
Printer not printing in black. Print Color only.
Hi
Thanks for using FixYa. First of all please try the refill cartridge on some other printer. If it’s working fine on the other printer then check the settings of the printer which are by default 960 dpi (dots per inch) but due to some reason this size has been reduced. Now you have to change this setting to more than 960, around 1200 dpi and then check out that if your printer works fine.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 28, 2009 | HP PSC 1210 All-In-One InkJet Printer
HP L7680 prints red instead of black
Check your default ink setting if red is default then change it and make black ink default settings.
Thank You
Jul 28, 2009 | HP Officejet 5610 All-In-One InkJet...
459 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
