SOURCE: lanier LW324 waste toner bottle full
Open the machine and to the right under the drum you should see the the black powder (toner) going down into container the right lower side cover must come off. probably a service call will be needed
Posted on May 01, 2009
SOURCE: Canon IR2018 keeps saying waste toner full
...the waste compartment is same unit in the drum unit...if you know how to take out the drum unit then you can see the waste compartment...but be carefull not to damage the drum...couse its will cost you a lot, the price of a drum is high...and if you can change the blade in the drum unit then you can emptying the waste toner...better call for the expert technician...
Posted on Jul 09, 2009
SOURCE: How to reset waster toner bottle full Xerox 3535
Here's what I did.
Emptied the waste toner cartridge. Left it out of the machine. Held the microswitch (located to the right of the optical sensors) in the "cartridge in" position with a paperclip. Printed one document. Inserted the waste toner cartridge. Error now gone!
GCC.
Posted on Dec 18, 2010
SOURCE: I have a aficio mp
The wast toner is placed next (next) to the first tray.
To reach there open the front door and you will see a screw (placed on top toward the main swith).
After unscrew you will be able to open a small door that hides the waste toner bottle.
Be careful because it is a little messy.
Good luke. If you need extra help reply to me
Posted on Mar 10, 2011
Aug 14, 2014 | Savin Office Equipment & Supplies
Apr 08, 2014 | Savin 4051 Sp, Ricoh 2051 Sp, Copier W/net...
Apr 02, 2014 | Konica Minolta New Bizhub C25 Color Laser...
The bottom left portion of the display gave
the error message:
Waste Toner Bottle 1 Almost Full. Please call service.
They were still able to print,
however this message would not go away.
To Fix:
Power down the printer using
the normal shutdown method.
Open the top front door.
Remove the cover directly below
the 4 toner cartridges.
The removable cover below the
toner cartridges is actually the Waste Toner Bottle.
Bring this to the dumpster.
There is a round, clear-plastic tab on the underside of the "bottle". Remove this.
Shake the bottle around over the dumpster.
Continue until all the toner has been removed.
Push the clear plastic tab back in place.
Wipe off all toner residue before putting it back into the printer.
Put the waste toner bottle back into place. Power on the Savin. Confirm the message no longer appears and that users are able to print.
Feb 08, 2012 | Savin Office Equipment & Supplies
Mar 18, 2011 | Konica Minolta magicolor 4650DN Laser...
Jan 23, 2010 | Toshiba e-Studio 350 Copier
Apr 20, 2009 | Lanier Office Equipment & Supplies
Dec 02, 2008 | Ricoh Aficio MP1600SPF Copier
Oct 24, 2007 | Samsung CLP-510 Laser Printer
115 people viewed this question
