Question about Dryers
Asko 7305 dryer keeps tripping out hi-limit on back of unit please help
  • seanself117 Jan 04, 2009
    asko 7305 eleectric dryer. when the dryer runs with no clothes in it it doesn't trip hi-limit. shoud i check heater elment when clothes are in it? thanks for helping me out. also i already replace the hi-limit.
  • 530 Answers
Make sure that the heating element is not shorted to the cabinet. Usually when you replace the hi limit you should replace the thermastate along with it. What is the brand of the dryer?
Posted on Jan 04, 2009
  • erica graber Jan 04, 2009
    Check and make sure that your heating element is not shorted to that cabinet. also any time you replace the hi limit you want to replace the thermistate along with it. Is the heating element glowing when you open the door usually you would see this if you where looking in the back left of the dryer? If so the element is shorted and you need a new one.
I have an Asko 7305 Dryer that keeps tripping the fuse. When I put a load in to dry, it will run for a few minutes, then stop. I push the black button in the back and it will come back on for a few, then...
either the motors overloaded from clothes load size,the motor bearings are getting tight from lack of lubrication, or the dryer heating element is beginning to short out to the case and grounding itself and tripping the fuse
Jul 04, 2011 | Dryers
My asko t721 dryer is one week old and i do not have a manual.it stopped in the middle of a cycle. it had 3 bath towels in it.. it starts when i push the button but will not stay on for more than a few...
Hello, welcome to FixYa.
Based on your description I`d direct you to first check the hi-temp cut out at the back...if you haven`t already.
It will look like this on the Asko dryers...
If you push this to reset and the unit works, great. I would keep an eye on it though since the hi-limit typically trips for a reason such as a excessive long vent or flex vent being used ( stay away from flex venting ) plugged lint filter, plugged vent ot partially plugged etc.
If it doesn`t run after-wards or it`s not tripped, you`ll need to investigate further...if necessary.
Keep me posted on your progress or what you find and I'll help in whatever manner I can. Good luck.
Regards,
Macmarkus :)
Jun 02, 2011 | Asko T712 Electric Dryer
T700 asko dryer runs if you hold the start button but cuts off when you let the button go, any suggestions?
Welcome to FixYa.
If you push this to reset and the unit works, great. I would keep an eye on it though since the hi-limit typically trips for a reason such as a plugged lint filter, plugged vent ot partially plugged or the heater itself is plugged up with lint.
Take the lint filter and clean it under some warm water and soap as they do become plugged with wax over time due to fabric softener and static sheets...when present/used regularly
If it doesn`t run after-wards or it`s not tripped, you`ll need to investigate for a faulty heater element. This is quite involved, so we`ll cross that bridge when you get there...if necessary.
Regards,
Macmarkus :)
Mar 16, 2011 | Asko T700 Electric Commercial Dryer
Press start and go for a secound then stops
Welcome to FixYa.
Regards,
Macmarkus :)
Mar 05, 2011 | Asko T721 Electric Dryer
How do I change the power cord on my asko 7305 dryer?
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Dec 29, 2010 | Hotpoint NBXR463EBWW Electric Dryer
Dryer turns but no heat?
Hello, Welcome to FixYa. Based on your description I`d direct you to first check the hi-temp cut out ( safety ) at the back ( black rubber round button )...if you haven`t already. This is quite common on the Asko dryers like yours. If you push this to reset and the unit works, great. I would keep an eye on it though since the hi-limit typically trips for a reason such as a plugged lint filter, plugged vent ot partially plugged or the heater itself is plugged up with lint. Take the lint filter and clean it under some warm water and soap as they do become plugged with wax over time due to fabric softener and static sheets, thus causing the safety to trip. If it doesn`t heat after-wards or it`s not tripped, you`ll need to investigate for a faulty heater element. This is quite involved, so we`ll cross that bridge when you get there...if necessary. Keep me posted on your progress or what you find and then if you require further assistance. Thanks for choosing FixYa. Please take a second to rate the info I provided accordingly. Thanks again and good luck. Regards, Macmarkus :)
Oct 22, 2010 | Asko T701 Electric Dryer
When drying a load of clothes the dryer (Asko 7305) simply quit and when I came back to the unit the clothes were dry, but the digital panel was dark and no power available to the unit. I have pushed the...
Hello Susan, Welcome to FixYa. Have you checked to see if perhaps one or both of the fuses may have blown at the back of the unit...I don't mean the hi-limit that you already referred to...I mean the in-line fuses the Asko machines are equipped with. Let me know and we can move forward from here. Regards, Macmarkus :)
Sep 12, 2010 | Asko T761 Electric Dryer
How to change dryer belt on Asko 7305 dryer
You have to pull the back off the dryer.Then you,ll be able to see how it comes off.Ussally its on two pulleys similar to a car.There may be a tensioner on it to to keep it from slipping.If there is one you,ll have to losen it to remove the belt & replace it,then tighten the tensioner back up.Ussally you keep about a 1/4" to 1/2" free play on the belt.You use a sraight edge on the two pulleys to measure it with the belt on,tighten belt tensioner till you have the recommended tighteness.
Nov 05, 2007 | Hotpoint NBXR463EBWW Electric Dryer
Dryers Logo
226 people viewed this question
Top Dryers Experts
