Question about Carrier Weathermaker 8000 Gas Furnace 125k Btu
Carrier Weathermaker 8000 furnace LED is flashing polarity reversed code
My Carrier Weathermaker 8000 furnace is not igniting. The LED is flashing at regular intervals incication the polarity reversed code. How do I change polarity back? Do I need a new control board? If so, where do I order one? This is an uplflow furnace Thank you
SOURCE: carrier furnace weathermaker 8000
. Several times of recyling power normally brings the furnance up. Though the failure code has always been 31, there are several different behaviour when the blower starts after reset :
a. blower simply creases.
b. there is an attempt to start the heating unit (I hear the high pitch noises), then everything stops.
c. there is an attempt to start the heating unit (I hear the high pitch noises), once I see the orange glow from the coil, normally the gas is lit up and the unit starts working.
Posted on Dec 18, 2007
  • 86 Answers
SOURCE: Carrier Weathermaker gas 8000 will not ignite
1. check indoor unit wiring.
2 check sensar of thermostate.
3if not change thermostate
Posted on Mar 28, 2008
  • 232 Answers
SOURCE: Carrier Weathermaker 8000 furnace blowing COLD AIR
you have a dirty flame sensor. just needs mantenance.
Posted on Dec 28, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: I have a Carrier Weathermaker 8000 VS furnace that
If you can get to the shaft of the motor, oil it using electric motor oil. If the motor spins freely, you just may need to replace the start capacitor, however if it is binding; you will need to replace the inducer as an assembly.
Posted on Jan 18, 2010
meBNme
  • 334 Answers
SOURCE: Flame sensor dirty
Sandpaper lightly scrubbed over the sensor tip to remove any contamination.
Sometimes cleaning is not enough and the sensor must be replaced.
Posted on Jan 31, 2010
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Why wont an older model carrier gas furnace light when standing pilot light is lit at all times? Why would there be no gas at the burners
when it comes to GAS appliances , I do not recommend any self fixes . they can explode and do you serious damage even up to death .call a gas furnace repairman
Feb 28, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 58TUA doesn't work
The switch could be defective but more likely the furnace blower is failing.
Dec 17, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Furnace keeps shutting down
The only thing I would fuss with on a furnace is the optical sensor that checks to see if there is flame. It would be a metal tube sticking into the combustion chamber, with a lens inside, or a flat black plate near the igniter. The lens can get sooted, need to be cleaned off.
Otherwise, it's a service call to check the gas control coils.
Be real careful not to touch the igniter, it is super delicate.
Nov 26, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
I have a Carrier Weathermaker 8000 furnace. it will not light.I tested the igniter on my upstairs furnace and it will glow and light that furnace. I can manualy light the furnace with a match. flame sensor...
If you're sure the igniter is good and the controller is sending voltage to gas valve to open, but not to the igniter then, yes, the controller is bad. The only way to know for sure is to remove the igniter's molded plug from the board and test voltage directly at the board. You should get about 100-120 vac to the igniter.
Mar 25, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker 8000 - furnace does not ignite
having a problem with a weather maker 8000. It will not come on at all unless I shut down the switch on the side of the furnace. filters is clean. it will start to light then stop
Dec 10, 2008 | Heating & Cooling
Mar 25, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier Weathermaker 8000 Gas Furnace 125k Btu Logo
98 people viewed this question
Top Carrier Air Tools & Compressors Experts
Tom Chichester
ray gallant
Are you a Carrier Air Tool and Compressor Expert? Answer questions, earn points and help others
