Question about GE Washing Machines
Hello, problem when I turn the water source on it begins rushing into the washer, but it doesn't stop. It continues running even when it says it's in the drain and spin cycle, any solutions?
    Top Expert:
  • GE Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 02, 2012
mikedurland
  • 481 Answers
SOURCE: fixn my GE washer spin cycle
It sounds like it could be the lid switch, check to make sure the lid switch is clicking when you close the lid.
Posted on Jun 27, 2008
  • 1937 Answers
SOURCE: Kenmore Elite Washer Does Not Spin
This a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20992991
and you'll see a list of major sub-components with diagrams and parts.
The brake on these washers is driven by the clutch on top of the transmission.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
This is a Whirlpool PDF on how these washers operate. It has a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
If the washer drains the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again or stopping and starting the cycle knob, and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, or stopping and starting the washer torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Nov 16, 2009
  • 1531 Answers
SOURCE: Frigidaire Gallery Series GLTF2940 front load
check the belt make sure it is still contected.
if that is good you may have a faulty door lock
Posted on Apr 10, 2010
miket756
  • 2702 Answers
SOURCE: Washer won't drain or spin
your not going to like me? its the programer playing up,,,pricy part too?
see i was right,,,you hate me now!
Posted on Jun 08, 2010
tunde007
  • 2382 Answers
SOURCE: whirlpool washer model# WTW57ESVWO starts to
Hi, the water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Posted on Dec 09, 2010
Frigidaire front loading washer, letter J in the display, will not operate.
First I recommend unplugging the washer for a couple of minutes then turning it back on. If that doesn't clear it unfortunately your are going to have to replace the control board. You can find the part here
http://www.repairclinic.com/ Just use your model number to look it up.
Oct 27, 2012 | Frigidaire Washing Machines
I have a Whirlpool Ultimate Care II washing machine (model LSN1000JQ0). The washer will fill with water and begin to agitate. Shortly after it will stop and will not drain. I've cleaned all hoses
see the next steps and use the common sense: God bless you
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 01, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Where's my washer filter located on the washer?
Hello, it doesn't have a water filter. Now, there a screen on the hot/cold water valve side. It could be possibly plug from sediments front the city water source. GB..stewbison
Sep 12, 2011 | Kenmore Elite 45986 Front Load Washer
When my LG is washing sometimes the FE codes comes up, what does this mean? How can I fix this issue?
This means that the washer is overflowing. This is a built in fault that turns on the drain pump so that the water doesn't get so high that it gets into the floor. If water is continually flowing into the washer you will get this problem. If this is the case the water valve is most likely the problem. To confirm unplug the washer and if the water doesn't stop flowing into the washer the water valve is the problem.
If water isn't continually running into the washer then the problem can be the water level control.
Jun 23, 2011 | LG WM-2277HW Front Load Washer
My washer only runs until it's time for the rinse cycle and then it stops completely. It doesn't rinse or spin. What's going on?
hello, it sounds like a failed lid switch part #3949247 it wont rinse or spin with a bad lid switch. it also wont rinse or spin if there is no cold water to the unit.
Jun 08, 2011 | Roper RAS8445KQ Top Load Washer
The water did not stop and overflowed and would not stop until we turned the water off at the source. What do we do?
Thank you for contacting fixya.com.
This can be caused due to faulty water inlet valve or water level switch.
1) Turn the power off to the washer.
2) Turn the water back on.
3) If water continues to enter the washer, the problem is the water inlet valve.
Also a defect or an obstruction in the water-level switch may cause the water not to stop. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Please check the bellow link and go through the article thoroughly to have an in-depth knowledge related to your issue:-
http://www.washerhelp.co.uk/diy-repair-help_7.html#cl_q1
http://www.doityourself.com/stry/how-to-repair-a-washing-machine-that-overfills
Please get back to us if you have further query else please accept the suggestion.
Jun 01, 2011 | Admiral Washing Machines
LG front load washing machine WM2233H Error code is FE
I found this information on the internet. I hope that it helps.
" Getting fe code on lg washer.
"This means that the washer is overflowing. This is a built in fault that turns on the drain pump so that the water doesn't get so high that it gets into the floor. If water is continually flowing into the washer you will get this problem. If this is the case the water valve is most likely the problem. To confirm unplug the washer and if the water doesn't stop flowing into the washer the water valve is the problem.
Thank you,
Shawn"
I hope that this helps you out
Apr 21, 2011 | LG WM2233H Front Load Stacked Washer /...
GE Top load washer.
Hello rschneeweis
Welcome,
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Huuum
Please remember to leave a rating
Oct 04, 2008 | GE WBSR3140D Top Load Washer
Washing Machines Logo
83 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
