Program stops led blink - Washing Machines
  • 31 Answers
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Posted on Nov 01, 2012
Codes and programing
To program your URC-3021 remote control to operate your TV, the remote has a code search function.
To search for a code for your TV:
  1. On the remote control, press TV once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
I hope that helps.
Dec 22, 2009 | One For All URC-3021 Remote Control
Tip
How to Auto Search Program Your URC-4021 One for All Universal Remote
To program your One For All URC-4021 remote control to operate your TV, the remote has a code search function.
I hope that helps.
on Jan 31, 2010 | One For All URC-4021 Remote Control
Need to be programmed to television
Hope that helps.
Dec 21, 2009 | One For All URC-3021 Remote Control
I dont have the code to program the tv
Hope that helps.
Dec 09, 2009 | One For All URC-3021 Remote Control
How to program remote control urc-3021b00 please
Hope that helps.
Nov 15, 2009 | One For All URC-3021 Remote Control
How to program remote brand all in one
Hope that helps.
Nov 01, 2009 | One For All URC-3021 Remote Control
I need the directions on how to set it up.
Repeat the process with the CBL/SAT button to program for your sat box.
Hope that helps.
Oct 20, 2009 | One For All URC-3021 Remote Control
How do i program my urc-3021b00 remote
Hope that helps.
Oct 17, 2009 | One For All URC-3021 Remote Control
I have a phillips universal CL034 remote control and i dont know the code or how to program it to my television
without knowing the brand of the tv i have to give you generic instructions on how to program the remote without knowing the codes:
  1. Turn your tv on manually
  2. on the remote press TV once
  3. Press and hold the set button until the LED red light blinks twice, then release the set button
  4. enter 9-9-1. the led will blink twice
  5. aim the remote at the tv and slowly alternate between pressing POWER and TV. Stop when the TV turns off after pressing power.
  6. lock in the code by pressing and releasing the set button. the led will blink twice.
Jul 02, 2008 | Televison & Video
Enter codes for remote R55L8-RCR4358
There are 4 ways to program your remote:
-Brand Code search and entry
-Direct code entry
-Manual Code search and entry
-Auto Code search and entry
*ON TV/VCR(DVD) combos you must program each button individually and that button(ie. TV or VCR/DVD) will program that part of your device.
*the DVD/VCR button programs DVD by default, in order to program it for VCR you must put it into VCR mode:
1.hold down the DVD-VCR button-->the red led will stay lit.
2.while holding down the DVD-VCR button press the number 2 --> the red led will turn off
3.Release the DVD-VCR button--> the red led blinks 4 times and turns off
4.The DVD-VCR button is now set to VCR mode-->program for VCR
BRAND CODE SEARCH ENTRY:
1. turn on device
2. locate brand codes(sorry, I don't have it, try finding genaric RCA codes)
3. hold down the component button--> led should stay on
4. while holding component button, also hold power button--> the led will turn off, then after 3 seconds it will turn back on.
5. release both buttons--> led will stay on
6. enter brand code--> led blinks once
7. press power button repeatedly until component turns off-->each time you press the power key the remote sends a different code for that brand. led blinks once
8. if power on your device turns off press the stop button to save configuration-> led turns off
9. if the led blinks 4 times and turns off, you have reached the end of the codes for that brand, try using a different method to program your device.
DIRECT CODE ENTRY:
1. turn on the device
2. locate your device codes
3. hold component key down-->led lights up and stays lit
4. enter code while holding components key--> as first key is pressed the led turn off, then as 4th digit of key is pressed the led turns back on
5. release component key-->led turns off, try using your remote, if it doesn't have all of the functions you need, try a different code
6. if the led blinks 4 times after entering code you have entered an invalid code, try again.
MANUAL SEARCH AND ENTRY:
1. turn on device
2. hold the component button--> led lights up and stays lit
3. while holding component button hold power button-> led turns off then turns back on after 3 seconds
4. release both buttons--> led stays lit
5. push the power button a bunch of times until the device shuts off-> each time the power button is pressed a different code is sent to the device, the led blinks each time.
6. if the device turns off press the stop button to save your config.
7. if the led blinks 4 times you have reached the end of the code list, there are hundreds of codes, you may be pressing the power button for a while...
AUTO CODE SEARCH AND ENTRY:
1. repeat steps 1-4 of "manual search and entry"
2. press the "play" button--> led blinks 10 times, sending a code each time
3. continue pressing the play button until the device turns off
4. if the device turns off press the reverse key to until it turns back on then press the stop key to save config.
5. if the led blinks 4 times you have run out of codes, try a different method.
Now if someone would please post the codes, or if someone knows the code for a durabrand DVD-1002...
Apr 09, 2008 | Televison & Video
Washing Machines Logo
158 people viewed this question
Top Washing Machines Experts
