Question about Jandy Pool & Spa
Jandy aqualink 8227
Firmware rev b12
SHANEOK
  • 21 Answers
SOURCE: Jandy Aqualink with IntelliFlo VS-3050
Jandy has an e pump.It would be cheaper to go that route.the Inteliflo is not compatible with the jandy system .If money is not a concern the pentair product is the way to go.
Posted on Oct 04, 2009
  • 990 Answers
SOURCE: Jandy filter and pump with a aqualink. Pump
Once you turn it off their will be a heater override that will keep the pump running for five minutes so the heater can cool down. Be sure that you give it that time.
Posted on Feb 10, 2010
SOURCE: jandy aqualink says Firmware Rev B11
my pool power is on but the remote in the house does not work.
firmware rev b-11 is showing on the display and the display lights up.
what could be the problem?
Posted on May 25, 2010
  • 84 Answers
SOURCE: My Jandy Aqualink, all the buttons are lite up and
This is a common problem with the communication between the RS Aqualink remotes and power centers. These can be fixed quickly and reliably at www.fixyourboard.com
Posted on Jun 11, 2010
  • 84 Answers
SOURCE: On Jandy Aqualink RS display it says 6700 Rev C
If you bypass the 4 wire cable wire as described by 'the californ', and the problem persists, there is a problem with the control boards. Either the PowerCenter board or the RS remote board. We see this failure alot. It is usually due to a a problem in the RS4/6/8 electronics but in some cases it is the PowerCenter. They can be repaired at a fraction the cost of new at www.fixyourboard.com. You can send the remote unit first since all the pool functions will remain and they can test it for you. If it is ok, you will have to send the PowerCenter.
Posted on Nov 01, 2010
I have aqualink rs 6 model 8227 we had a power outage for about 5 hours when the power came back on it says firmware rev b 13 and establishing communications but it never does. I can turn everything on...
turn system off then try again make sure wire connecting to controller is plugged in and tight if wireless see if antenna is flashing green and red lights inside of case
Nov 03, 2013 | Jandy AquaLink RS2/6 All Button Dual...
Jandy 8227
make sure 4 pin connector is plugged in and wires arent cut or shorted
May 12, 2013 | Jandy Aqualink Rs4 One Touch Control...
What does firmware rev b13 mean
check wires going to controller and PCB board if ok check wires to see if cut
May 26, 2012 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
I have lost control. Hit the reset button inside the box and now it says "firmware rev B12." But the rest of the screen is blank. help!
From the information given it sounds like it needs to be replaced. On the other hand, a more educated guess might be obtained with a call to the Jandy technical support line at 800-822-7933. They should be able to help you figure this issue out. I hope this helps.
Please vote on this answer. Thank you.
Aug 27, 2011 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy aqualink says Firmware Rev B11?
Apr 11, 2010 | Jandy Aqualink Rs4 One Touch Control...
Pool & Spa Logo
69 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
