Question about Ruud UAMB Air Conditioner
Air Handler--Noisy Harmonic Sound - Ruud UAMB Air Conditioner
  • 31 Answers
DO NOT buy a RUUD system. I purchased a complete system in 2010 & have had multiple issues since - - new coil, high humidity levels, condensation on my walls when the furnance is on, and now when the outside temp is 90+ degrees the AC unit shut off and only blows hot air. THey've replaced the "board" and I was told that RUUD is aware of multiple problems with the 2010 units but will NOT recall them.
Posted on Nov 01, 2012
Tempstar indoor outdoor central air unit is so noisy you can't hold a conversation. any lubricant's i could use and where.
I'm assuming you have an air handler that is inside. Turn the power off and make sure there is nothing that the fan is hitting. If not the bearings are probably bad. These motors are sealed and cannot be lubricated. You will need to replace the fan motor.
Jul 16, 2016 | Heating & Cooling
Why does our Lennox AC Air Handler, Model CBX26UH-060 makes a beeping sound when it starts up?
Dear Friend,
Normally all Lennox handler beeps right after turning on and off, but if beeps all the time it might be that there is an error with the handler or it beeps because it was program to beep when going on and off. Please refer to your user manual for any beeping error.
Good Luck!
Sep 20, 2014 | Heating & Cooling
What causes my AC to sometimes stop cooling & can hear a buzzing from the motor?
The blower motor probably needs very badly to be cleaned, lubricated, or replaced, Michael.
Aug 06, 2014 | Heating & Cooling
Noisy air handler
check fan motor and squirrel cage.
Oct 02, 2013 | Goodman Heating & Cooling
Noisy start up of york air handler
The source of the thump could be the sheet metal ductwork
Feb 25, 2013 | Heating & Cooling
Noisy motor front end vn v6 commodore, bad rattle sound??????????
It sounds like your timing chain may be worn, A bit of a pain to change but do-able if you have the tools and some time. The harmonic balancer makes more of a knock than a rattle.
Mar 04, 2012 | Cars & Trucks
Amana heat pump/AEPF variable spd air handler system works great, but air flow at the higher speed is just too noisy (ducts are not very wide). Is there a way to limit how fast the air handler / blower...
Open the airhandler -should be a speed selector on the main board. If not -checkt he installation/set-up manual. May be some dip switches you can turn on or off to modify blower speed.
Jan 26, 2011 | Goodman CLQ36AR49 Air Conditioner
Hi contractor replace air handler motor now 4 months later pop
The mildew smell could have been created by the clog, but it also could have been created by low airflow and/or refrigerants leaks that can cause your evaporator coil to ice up and melt inside your air handler.
The "Popping" sound sounds like it is either your ductwork or the casing or access panel of your air handler.
If you still have the original ductwork, it should be thoroughly inspected for air leaks and/or degradation insulation (insulated will degradate in time). Re-seal and Re-insulate if necessary.
Without being onsite, with toolbox in hand, I hope you find this information to be very helpful to you, moving forward. :-)
May 03, 2010 | Intertherm P3RA-048K Air Conditioner
Heat Pump Cycles On and Off and Air Handler Noisy
I am pretty sure you have a low charge and the pressure switch is kicking it off. probably just a pound or two however the accumulater will sometimes hold more.
Mar 27, 2009 | Bryant 463AAC008BA Air Conditioner
Ruud UAMB Air Conditioner Logo
131 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
