Question about Senco Fastening Systems 760102N Pro 25 Xp Brad Air Nailer
Senco framing pro
After long time without using it, i started to use it again, was working very well, but when i put oil, started to lick oil in the back, anybody know how to fix this problem?
  • 3 more comments
  • washingtonma Jan 04, 2009
    *"started to leak AIR in the back" of the vent (-sorry (two typos) before i put the oil in, it did not leak air. now it's loosing pressure very slowly.
    [i put a little more than six drops in; but not a ton more]
  • washingtonma Jan 06, 2009
    the model is (Frame pro 702xp)
  • washingtonma Jan 07, 2009
    the model is frame pro 702xp, serial number 04cd2490.
  • washingtonma Jan 08, 2009
    what lubricant should i use before reassembly?
  • David Ford
    David Ford May 11, 2010
    "started to lick oil in the back" I am uncertain exactly what you mean. One question I would ask first is how much oil did you put in it. It only requires about 6 drops before using and about the same if you shut down for lunch. And more and the oil would try and escape from vents. Let me know and I will try and help.
    Problem Solver:
  • 10 Answers
There are two things to check when this tool is leaking out the cap.
1. Take the cap off of the tool. Look in the cap. There is one bolt holding the "firing valve" on to the inside of the cap. The blot is tightened against a white round piece that is holding in a larger black donut shaped piece. The black piece has two yellow o-rings and a cream seal on it's outside and it has two thin black o-rings on the inside. It will be the black o-ring that is visible that rides against the white round piece. It's part number is LB0038.
2. There is a large black rubber seal that seals the cylinder to the main body of the tool and it will be cracked on around the outside. You will need to look around the outside of this seal and gently pull the upper and lower parts apart to inspect it. The crack is sometimes hidden because it is where the seal is molded at a right angle. This seal is part number BC0342.
Posted on Feb 26, 2009
  • 2,176 Answers
Please provide the model number for this tool and I can direct you to a site that sells o ring kits for it. They are not hard to install and have excellent directions. It sounds to me that one of the O rings has a split in it or is rounded off allowing this leak. It would be to your benefit to replace them all. Maybe about 1/2 hour to replace them. Let me know
Posted on Jan 05, 2009
  • David Ford
    David Ford Jan 07, 2009
    K took me awhile but what you need is the upper O ring kit for this tool. It comes complete with all the Orings to seal the leak and DETAILED instructions. The kit number I found is YK0243 and it costs around 28.00. To find a Senco dealer near you go to and under the find a dealer section click on it and you can buy this kit online. It is not that hard to install. Just remember to lubricate the Orings before reassembly. About 1/2 hr maybe a little more but this should cure the problem.
  • David Ford
    David Ford Jan 08, 2009
    generally it comes with the kit if you are buying it. If not a lightweight grease will work. It does not require much just enough to lube the o rings so they don't pinch or roll upon reassembly. Wherever you get this from ask them for a small vial of lube.
I have a Senco SN70 framing nail gun. The gun
One question is do you regularly put oil in the gun? Also you need to make sure that the screw holding the 'clip' near the barrel is tight and not loose. These are the 2 main problems when a gun is misfiring.
Oct 02, 2013 | Senco Air Tools & Compressors
My frame pro 601 will sometimes shoot one to five times and then when you pull the triger nothing happens air comes out the core valve hole above the trigger when pulled then you can unplug air and tap on...
Senco makes a kit for your nail gun, part number YK0360. If you have any o-rings giving you problems, it's always best to replace all of them. You can get them from online parts stores like or possibly from rental or repair places near you. Make sure you lubricate all the o-rings well when putting the new ones in.
Dec 13, 2012 | Senco & Frame Pro 601 Framing Nailer
I have a Senco Frame Pro framing nailer. The plunger is sticking in the
Check the drive pin for burrs and file them off. Check for worn piston replace if necessary. Clean the air return hole in the top of the piston cover. Add oil if manufacturer recommends it.
Mar 24, 2012 | Senco Air Tools & Compressors
Finish Pro 32 is Leaking air out of the exhaust cap
You have worn or broked o-rings/seals inside the gun. The Finish Pro 32 is one of Senco's older guns and they no longer offer a repair kit for this gun. You have to go to a site like or, find a breakdown of your gun and order each part you need. If you are going to rebuild the gun order all the o-rings/seals (Senco parts that start with LB) and any other parts that may be damaged like the piston stop, springs, etc. Lubricate the o-rings with light grease as you put them in and make sure to oil the gun regularly when you are using it to make your work last.
Jan 27, 2011 | Senco FINISHPRO32 ProSeries 16 Gauge...
Air come out the back and doesnt shoot nail was working fine
You have out of worn or broken o-rings inside the gun. Your best course of action is to rebuilt the gun. This is a fairly easy task and when you're done you'll have a gun as good as a new one. You need Senco's repair kit #YK0360, available at several online parts stores. When you disassemble the gun, replace the o-rings (use all of them) and seals one at a time so you get them back in their proper place and use the lube in the kit liberally. Remember to oil your gun before each use, twice a day if you are using the gun all day long and your o-rings will last a lot longer.
Jan 17, 2011 | Senco & Frame Pro 601 Framing Nailer
Schematic for Senco Frame Pro Model 601
Try this link:
If it doesn't work go to and put 601 in the PRODUCT FINDER search block. You'll get one result, click on the nail gun link then on parts guide link to get the parts breakdown.
Dec 20, 2010 | Garden
What angle nails are used in a frame pro 601 senco
The Senco Frame Pro 601 uses 34 degree clipped head nails.
Nov 23, 2010 | Senco Tools & Hardware - Others
Nail not sinking completly
Usually too low pressure or lack of lubrication. Also using too long a hose or too small a hose can cause this. Make sure you put the drops of oil into the unit at start of each day and use the approved air tool oil. Air pressure should be per manufacturer;s spec... I use around 90 PSI.
Using a small 1/4 inch air hose that is very long can cause the problem... Keep it under 50 feet.
Oct 26, 2010 | Senco & Frame Pro 601 Framing Nailer
Senco Fastening Systems 760102N Pro 25 Xp Brad Air Nailer Logo
240 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
