Question about Dell 922 All-In-One InkJet Printer
Replaced black ink cartridge and it says its low
I replaced the black ink cartridge cartridge and it now says its low, and why does my color cartridge say its in wrong, even though I've put it in several times?
  • Anonymous Jan 12, 2009
    replaced both black and color ink cartridges.
    now the black cartridge will not print and the printer says the color cartridge is the wrong one.
Some newer printers, such as Lexmark, will have a place in the properties app that allow you to "tell" the printer the cartridge is new. Check yours and see, it fixed mine.
Posted on Jan 04, 2009
  • bentolittler Jan 04, 2009
    Reseat the color cartridge, make sure there isn't anything odd in the ink cradle. Once you are sure you have it in right, you could look at two other possibilities, you could have a bad ink cartridge, a data path on the ink cartridge's chip panel chip panel may be bad, or there could be a service issue with the printer.
I want to use Black ink only but it will not print because the colors are empty. Do I need to replace all cartridges (LC61) for Brothers print, copy, fax machine. Thanks
If you don't want to replace the color cartridges, you can fool the printer instead. Sensors in the printer shine light through a thin area on the cartridges. The empty (or even just low, even though there may be plenty of ink still inside) cartridges allow the light to get through, the printer sees the empty cartridges, and it won't print anymore. You can cover this part of the cartridge with a piece of black electrical tape to block the light. Voila! No light gets through and the printer thinks you have full cartridges again. This site has pictures showing where to put the tape. I've used this trick on the printer we have here in our office and it works great.
Feb 11, 2011 | Office Equipment & Supplies
My printer will not print black ink, says I need to remove tape from cartridge? the ink is partly gone and has been working and is not empty.it will be a cppier and do it but not from computer.
Mine did same ....turned out I was out of ink.....even though the estimated levels say I had a full black and near empty color ...went to store picked up a color cartridge ..put it in and it still gave me the same err message [allignment prob please remove tape] thats when I tried to clean cartridges and there wasnt any black ...soI went out & got a black also ...put it in and wala Im back in buisness...accept for the wrong messages or is it a software prob?
Sep 14, 2010 | Dell V305w All-In-One R840635AU InkJet...
The printer keeps doing the alignment and saying that there is a problem. My color ink cartridge is low but I would still like to print with black ink. I don't know if the color cartridge being low affects...
Replace your color cartridge and power printer on. The color cartridge is probably empty (even though there might be a little ink left in it). Many inkjet printers require the color cartridge for composite black even if you are not printing in color.
Jun 16, 2010 | Dell 926 All-In-One InkJet Printer
Can i print using black ink when im out of color ink it wont let me even though ive changed the settings to print colors as black and white
That's the way Kodak works
It won't allow yu to do anything if any of the lights are flashing or there is a error message
NO RESOLUTION
Get your color ink cartridge replaced by Kodak.
Just say its a new color ink cartridge and printer is saying its empty!!
Hurraay you'll get a free color ink cartridge
Jan 25, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Error message that color cartridge has low ink, so printer won't print. How do I override this? This message occurs when only one color is low and requires replacing the entire cartridge.
No way 2 override the message. Printer works on a combination of both black and color ink to print those perfect pictures and documents. If it is showing color ink needs replacement,you ve 2 change it in order to print even in black and white.
Jan 13, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I put a new black ink cartridge in the printer. When attempting to print, no black ink is being used, just color ink, even though the little level indicator on the printer window the appeared when one...
goto maintenance, on the panel of your printer..choose clean printhead..or wipe your black cartridge with a wet cloth..maybe your cartridge suffered clog that covered the nozzles ..
May 13, 2009 | Dell 926 All-In-One InkJet Printer
Cartridge problem
Basically, you placed a black ink cartridge [30] into the compartment for the color one [31]?
Make sure you have a black ink cartridge in the left compartment, and a color one in the right one. I don't even think it would properly fit if they were in the wrong slots. They should "click" into place, confirming that they're installed properly.
Sep 08, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Print Cartridge Problems
i have an mp170 all in one and when you fill the cartriges they dont show up as full cannon put a chip in the cartridge to con people into buying new ones try siting the cartridges in warm water for a few hours then blot the cartridge with tisue paper if it dont blot out the ink the cartride is finnished and you need a new one .To align the cartridge you flick through the menu on the printer not pc screen look for alignment page print this off then you have to pick the dark boxes on the sheet shade the bit next to it and put on your scan bed and click ok it should scan the sheet and reset the alignment
Jul 19, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Dell 922 All-In-One InkJet Printer Logo
95 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
