Question about Cisco Computers & Internet
Cisco 2801 series does not boot - Cisco Computers & Internet
  • Cisco Master
  • 32,281 Answers
CISCO/Linksys -To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of the router with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to be configured with the SSID, encryption etc. and also the wireless cards in all the laptops/computers needs to be configured with these router's wireless settings. Then the laptops/desktop computers can communicate with your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down and put it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2 encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Posted on Nov 02, 2012
Cisco 2801 router does not boot
http://192.168.1.1
Nov 01, 2012 | Cisco 2801 Router
Fix broken ejector handle
You need to obtain a replacement flash ejector handle first. If you open the router out, you can push the broken ejector handle out with a small flathead screwdriver, it just slides out forward toward the face of the router if you apply a bit of pressure. Then you just slide in the new ejector handle, which is "keyed" on one side. There is also a small metal lever pin that you need to line up with the spring hole when sliding the new ejector handle into place. Once inserted is will snap gently into place and you are done.
<a href="http://www.ciscobuy.com">Sell Used Cisco Equipment</a>
Mar 15, 2012 | Cisco 2801 Router - 2801
Cisco 2600 series router problem
are you clicking on the reset defaults button when you set up hypertrm? while it's booting it will run a boot test. if you can see any of it, see if it passes. Try another computer?
Jan 05, 2010 | Cisco 2600 Series - IOS
Upgrading Memory
Sorry 384MB is MAX, any reason you need 512? They come standard with 128MB and that works for about 99% of the need.
More memory is not going to make it any faster.
Aug 19, 2009 | Cisco 2801 Router
One way audio on NEC ITL 12 button IP Phone at remote site. Main site has IP Phones which are working fine. IP Phone connected to Cisco 3560 24 port poe switch. Switch connected to 2801 router. Point to...
This is likely a config problem on the NEC or a hardware/software issue on the NEC. Do a Wireshark capture on the NIC on both ends. Examine the RTP streams and see if they are intact. You may have to decode the stream from UDP to RTP depending on if it is a peer to peer call or if it is going through the 8100. Plenty of documentation on how to do that at Wireshark's website.
Aug 01, 2009 | NEC Computers & Internet
Cisco 2801
What Model Series do you have?
Nov 11, 2008 | Cisco Catalyst 2924 Networking Switch
Cisco 2801 router's power supply
Suggest you go to Cisco for two reasons....A) it may not be an off the shelf item you can cross source and they can be different (even within the same external model number)...be careful or take a look at the supply itself (open sesame). Hope this helps....Tango
Jan 14, 2008 | Cisco 2801 AC PWR SUPP (PWR2801AC) Power...
WIC 1B S/T Not Detected
If you are trying different model routers, you'll find the card was made for one series.
If it works in one 2800, it should work in all 2800's. It won't work in a 2600, even though the card looks identical to one that was made for a 2600.
Dec 17, 2007 | Cisco (WIC-1B-S/T) Modem
Computers & Internet Logo
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
