Question about IBM Computers & Internet
My ibm laptop's mother board cannot power on, please help me solve it
When i power on the mother board nothing comes on, when i plug the charger no charge light indication comes on and when i use the charging system and the charger on another ibm laptop the charge light comes on and the board powers on too
  • Anonymous Mar 24, 2014
    over charge no power
  • 3,799 Answers
The most likely problem is that the onboard power supply has failed, usually a capacitor has burned out. Or it could be a loose DC supply socket (they only need to have one loose pin on the motherboard.)
Posted on Nov 03, 2012
djnick989
  • 1067 Answers
SOURCE: My mother board AOpen MX4LR, socket 478, dead
bad mobo or psp is bad try psp for now lock down mobo tight also losee no good
Posted on Jan 06, 2008
  • 95 Answers
SOURCE: Sony Viao, won't power up
Laptop motherboard power pin, broken solder connections. Quite common on all laptops. Can be bought from ebay for cheap, if you are mechanically inclined and can solder you should be able to repair it yourself, if not need to find someone who is good at electonics and have them repair it for you.
Posted on Mar 29, 2008
  • 21 Answers
SOURCE: battery will not charge on a dell d610 when plugged into outlet
I have seen this with faulty batteries.
Try changing the battery.
Also, check in the BIOS that the adapter you are using is recognised and shows a state of charging with the battery in.
Posted on Jun 25, 2009
justin217
  • 85 Answers
SOURCE: Mother board light comes when I plug the board,
It's probably a motherboard issue, since you can get power to the board, but it doesn't fully power up. I would replace the motherboard and see if the problem persists. I hope this helps!
Posted on Jul 15, 2009
  • 119 Answers
SOURCE: I think my mother board is fried.
If they had you plug in a USB cable to the modem (not even sure how that fit) then you need to work through the ISP to repair your laptop.
The battery probably is charging but sounds like the mobo is fried (like you suspect).
Posted on Jul 21, 2009
No Power on Hp 620 Laptop
If the battery does not charge then the problem is likely the charger.
If you can borrow a charger instead of buying a new one you can find out for sure if the problem is the inside the laptop its self or the charger.
Remove the battery and hold down the standby button for a whole minute to drain any remaining power in the model. replace the battery , attach the new/borrowed charger lead and see if any activity happens ie, sound, lights...ect. This is the first thing someone does in a repair shop and its to diagnose where the issue is comming from.
Feb 21, 2014 | HP Computers & Internet
Toshiba Satellite L655 Not Switching on
You mentioned that it won't turn on with the charger (without the battery). Does this mean that it turns on if the battery is in?
If it turns on with the battery, then you need to replace your AC adapter.
Feb 13, 2013 | Computers & Internet
MY ASUS F5VL MOTHERBOARD WON'T TURN ON???
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
AC adapter failure.
Power jack failure.
Motherboard failure.
Possible troubleshooting steps and repair solutions:
Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Oct 30, 2012 | ASUS F5VL-A2 Notebook
I am having a problem with a hp pavilion dv4. When it is plugged in the charging light will flash when i try to power it on the other lights on the case flicker and die . and if i plug in the laptop...
had a similar problem,and I resoleved it via a bios flash..this allowed the hardware to be fully recognized and to perform the specified role.For some reason,the bios software for this version seems to corrupt after several years. I have had my machine for the last four years..until it recently started giving the issues,it had no problems.
Jun 06, 2011 | HP Pavilion dv4000 Notebook
My IBM R51's battery ran down. Connected the
If it is the first time its happened, has your charger fused/broke.
Is the lead from the power block to the laptop loose??
Jul 09, 2010 | IBM ThinkPad R51 Notebook
My IBM 8311-13U will not power up at all. Replaced
sounds like you have a fried mother board change it out and you will solve your problem
Dec 05, 2009 | IBM NetVista A30p PC Desktop
IBM THINKPAD X21
Sir your problem is very common and only have two possibilites :
  1. Your RAM is faulty and you need to replace it. Its cheap n simple solution.
  2. Also it may be a problem in any component of *********** board and you need to repair that specific module.
Rate me properly if i was helpful to you.
With Regards,
Shyny Saxena
Dec 10, 2008 | IBM ThinkPad X21 2662 Notebook
Computers & Internet Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
