Msi laptop wont charge
I got a new charger but the laptop still won't charge so I know its the laptop
  • 7,627 Answers
Bad Battery? how old is the battery? mine lasted 4 years and died.
What gives you the idea it's not charging? need more info.
Posted on Nov 01, 2012
benwabnick
  • 2404 Answers
SOURCE: If the charger cord moves a tiny bit it would stop
Its going to be a problem with the power jack on the motherboard where it needs to be resoldered to the motherboard, or an issue with the motherboard itself.
Posted on May 06, 2010
  • 388 Answers
SOURCE: My computer won´t charge, The battery held
Likely to be a charger issue. You can pick up a new generic charger from your local supermarket for a few pounds
Posted on Sep 04, 2010
mmnhltm
  • 695 Answers
SOURCE: my hp compaq turned
Remove the PC labtop battery then re insert it again.
If still not charging check the charger connector if its connected as well.
If there was no problem in the charger connector,Check the charger itself.
These all what you need to check only,no problem in your labtop.
If still not charging means one of these :
1- The BATTERY may needs to be changed .
or
2- The charger may needs to be changed.
Posted on Jun 13, 2011
  • 123 Answers
SOURCE: My laptop won't turn on,
Good day. You can try to do these steps which is usually a normal solution to this kind of issue:
1. Take out the battery of your laptop
2. Remove main supply, or power cord
3. Hold power button down for 30 secs,
4. Put only power supply in or power cord
Note: do not put battery in yet
5. Turn laptop on
6. Put the battery in.
If this will not work you might consider contacting toshiba tech support for laptop for other resolution. Hope this information will be helpful in resolving your issue. Thanks for using fixya and have a great day.
Posted on Jun 25, 2011
You've to replace the ac adapter, if it's brick doesn't get warm or LED does not glow on Power Jack on the laptop. offcourse, check with the wall different sockets
power jack can also be loose. so jiggle the cable to find out.
if notebook is getting power, you can remove the battery, ac adapter, hold and keeep pressing poer button for a minute, then, turn it on.
finally, you can take out hdd and ram, put them back again and turn on the laptop. hope it will help
Posted on Sep 17, 2011
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
My MSI GT680 Notebook charging system doesnt work. when I plug my charger into the wall the green light indicator comes on, then when I put the plug into the laptop the light turns off and it doesn
Hello! It seems that you have a problem with the laptop charger connector. It maybe in short circuit. You can try to look for some electronic workshop that works with reballing, BGA solder, etc., that might change it. In Portugal we have some, so I think in other countries you can find them to.
Apr 03, 2013 | MSI Microstar GT680R-008US 15.6" Notebook...
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
My aspire 5100 wont hold charge without charger
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 05, 2012 | Acer Aspire 5100 Notebook
My N5010 dell laptop battery won't charge anymore. Could I just need a new battery, or charger, or could there be something else going on internally that I need to know about? For the most part, I
If your laptop is still under warranty, contact dell and they should be able to fix it free of charge, The same thing happened to my laptop a few years ago and fortunately, it is still under warranty, The fault is the charger itself which dell replaced free of charge.
Jun 26, 2012 | Dell Inspiron N5010 Laptop Core I5...
Samsung R519-53S not charging
Please remove battery and connect charger and turn on computer. If on adapter working fine, now connect battery without removing charger , and check charging.
May 09, 2012 | Samsung R519-53S Notebook
My msi netbook wont turn on even though the battery charging indicator is lit.
1. Turn netebook OFF with button, hold 4 seconds.
2. Remove recharge plug
3. Remove battery
4. Leave it like this for about 5 minutes.
5. Put everything back and power the laptop again
Does it appear to charge the battery at all when plugged into AC? Can you hear the charger humming when you put the brick up to your ear? (while it's plugged into AC,You may have a bad motherboard
Dec 04, 2011 | MSI Wind U120-020US Netbook
My laptop wont turn on
Well, it's either AC or DC.
If the AC charger has failed, then the battery hasn't been charged and the PC just won't come on. I would go to a box store or a PC Repair shop and tell them you want to try a charger and if it will turn the PC on agree to buy it.
You can save money on the internet but it's a hassle sending stuff back with gas at $3.30 a gallon.
Let me know how it turns out.
Aug 12, 2011 | HP Computers & Internet
It wont charge im holding it right nw hoping it wont shut down help fast
If your laptop won't hold a charge and you need to hod the connection in order for it to stay on, you may have a power jack issue. The power jack on the laptop may have been moved around from moving the laptop while connected or wiggling around the connection, and needs to be re-soldered back on the motherboard.
Also, just before taking that step, try using a different or brand new charger. Sometimes the pin inside a charger might be bent or broken, therefore not making a proper connection with the power jack.
Hope this helps.
Jun 25, 2011 | Computers & Internet
My dell inspiron won't charge if the OS is awake/on but DOES charge when it's off/asleep. this is a new problem.
This appears to be a common problem. Sounds like the current is not being shared while in use. If you know the battery to be good, I'd check the output voltage of the charger 1st and see it is putting out the right voltage. The chargers for the Mini series are weird, so may be worthwhile borrowing another charger to eliminate it from the problems.
After that... you may need to get the laptop checked by Dell
Jun 15, 2011 | Dell Inspiron Mini 10 Notebook
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
