My heater is coming on and then shutting off - Heating & Cooling
I don't have a solution because like you mine is also shutting completely off. I turn it on the temp is set at 72 and it will run for a while then it completely shuts off, display screen goes blank....I unplug it and then plug it back in and it comes back on....at first I thought it was because I live in an old house and the outlets were wrong but that is not the case.....why won't it run?
Posted on Nov 01, 2012
Heater still runs after shutting off
Fan will come to dissipate any heat build up in heat exchanger
Apr 13, 2014 | Rinnai Water Heaters
My confort zone infered heater comes on for a few minutes then shuts down
Does it shut off heater with lights and fan on or power off? Did you bypass the temp sensor or thermostat? If temp sensor that mounts above filter, see http://www.fixya.com/support/t15119324-comfort_zone_cz2011_heater_shuts_off .
Feb 14, 2013 | Comfort Zone CZ1500WC Infra-Red...
Cz 500 shuts off and comes back on in about 5 minutes. is this a correct procedure.
Heaters have
)Tip over switch If the heater is thermostatically controlled then what you may have is the thermostat cycling just as a central heating system in your home. When heater reaches the temp you set it shuts off, then comes back on when temp drops several degrees below setting. Yes, It is normal. Ned
2)Thermostat
Dec 18, 2010 | Comfort Zone CZ-530 Compact Heater
Alarm comes on for no reason a couple minutes after turning it on
I have a presto heater what i did was tape the buzzer botton up. if the heater fall over the buzzer will not go off because it is taped shut. the problem is your buzzer is sticken. the heater works fine once you shut the botton shut. to eliminate the buzzer.
Dec 07, 2010 | Presto HeatDish Compact Heater
Pool heater wont start but when i turn off the pump and start back again the pool heater comes on for 2 seconds and shuts off AGAIN
Heater must have water before it will fire up. There is a delay relay that may be dozing off. Not a bad thing but should be chk'd by a pool sevice.
May 26, 2009 | Heating & Cooling
Kerosene Portable Forced Air heater comes on, runs awhile
Here is a link to your owner's manual... http://12.153.20.74/manuals/123919-01A.PDF. Look on page 8 and 10. It could be several things. It could only be a dirty fuel filter or the pump pressure may just need adjustment. If you need a part you can contact Master Parts at 800-466-1446 or you can find them on-line at www.masterparts.net. I hope this helps!
May 04, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
I just moved in. What happens when you shut the wall switch off.
If the wall control is the thermostat, then if you shut it off, your unit will not come on at all. If there is a pilot on your heater, it will remain on unless you shut it off at the gasvalve or gas shut off valve. Some heaters light themselves when they need to come on.
Mar 25, 2009 | Empire GWT-25 Wall Mounted Panel Heater
The unit should have a fuel & air filter. Check that both are clear. Inside the burner tube, there will be a photo-cell, if the lense is dirty it will shut the flame off. The photo-cell needs to see the flame. You can carefully and gently, clean the lens with a tissue, soft cloth, or Q-tip. Please let me know how its coming along.
Feb 09, 2009 | Desa International Reddy Heater R115DT...
Heating & Cooling Logo
81 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
