Question about Miele H348 B2 Electric Double Oven
H348 B2 Oven does not heat up, no fan or oven light, but external controls light up!
  • Michael Clenshaw May 19, 2007
    THANK YOU SO MUCH !!!!! IT WORKED!!!! You are a genius........... I hope someone crosses your path to help you as much! You have saved me £94 callout. A BIG THANK YOU!!!!!!!! :-)
    President:
  • 1,462 Answers
Turn of at mains, wait 5 mins and turn back on then consult your handbook to set clock. i suspect you have the oven on automatic by mistake. if this don't work, you may have a problem with the clock itself. you can bypass the clock by connecting together the two contacts adjacent to the clock relay
Posted on May 18, 2007
Simpson Harmony Nova electric oven heating problems (oven heats but no fan and light)
The Fan has ,in most cases, two functions - to maintain the oven temp and to clear any condensate or smoke coming from items being cooked. If your oven is over heating it could be the thermostat sensor faulty and giving a faulty reading to the fan. If you set you oven at 350F then sensors control the heat by kicking the heating elements off and in some models and makes the fan aids cool down. Make sure it is at a temperature that would trigger the fan to cool it down. It mostly relies on the regulation of the heating elements to control the temp. Only if it were to get hotter than the elements kicking off can control should the fan kick on. Not being at the site and actually seeing the stove it is hard to determine but if the fan is working every where else it should work when the oven is heating. Again check and see if there is a seperate sensor that monitors the temp of the over and triggers the fan. Not much help but that's where I would look first. Hope this was of some help.
Col. Dana Gillespie
May 11, 2014 | Ovens
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
Hoover bottom oven not heating up
Hoover Oven not heating? How to replace a Hoover fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 14, 2012 | Ovens
My Electrolux EOB5610 fan oven will not heat up. The power light is on. The oven light is on. The fan works. There is some heat in the oven but not enough to cook with.
Only two possible causes. The oven element is faulty or the oven thermostat controller is faulty. Probably the first thing to do is test the oven element and check the resistance. If the element is okay then the oven thermostat will need replacing.
Feb 23, 2011 | Electrolux EOB5610 Ultrafan Electric...
Fan and light work, oven stays cold
one of three things are possible:either you are missing part of your 240volts at input power,or a bad neutral power wire to heating element,an oven temp control,or the thermocouple that controls oven temp
Aug 22, 2009 | Ovens
Top oven (and Grill) have stopped workingMy 3 Year old AEG Competence D2100-4 Double oven has malfunctioned.  Bottom (main oven) works fine but top oven and grill have ceased to function.  The fan will run...
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Nov 12, 2008 | AEG D2100-4 Electric Double Oven
My oven turns off on me after only a minute never heating up fully
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
Jun 19, 2008 | AEG B1180-4 Electric Single Oven
Temp display shows 444
If everything on your B1691N0GB oven seems to be working, i.e. all the lights are on and fan comes on in fan oven setting, but there is no heat from fan oven, conventional oven or grill, try turning your oven off at the mains, then turn on again. If the temperature display then shows 444, your oven is locked. To unlock, make sure the central control knob is in the "out" position, then press the fan oven and light buttons simultaneously for 10 seconds or so, until 333 appears on the display. Your oven is now unlocked.
Apr 08, 2008 | Neff B1641 Single circotherm super...
Elan 948 OVen doesn't heat and light designating heating does not go on.
we just had the same problem with the same oven. pull the oven out of the wall. on the top right side there is a fan. there is a safety switch that is activated by the fan blowing on it. a piece of insulation was preventing the switch from activating so the oven thought the fan was not running. remove the insulation and the oven comes back to life.
Oct 22, 2007 | Elan E-948-CB / E-948-CW Oven
Miele H348 B2 Electric Double Oven Logo
649 people viewed this question
Top Miele Ovens Experts
Paul Bade
John
Marvin
Marvin
Are you a Miele Oven Expert? Answer questions, earn points and help others
