Question about Microsoft Xbox 360 Console
Dns server failed
  • 23 Answers
Hello.
Go to network settings in the system tab of your dashboard, then first set all to automatic and try if it works then if it shouldnt take a look at the setting gateway and write down the IP, it should be something like 192.168.1.1 or so, then manually edit the DNS servers in the network configuration and add the gateways IP as primary DNS.
Retry if it works if it shouldnt you will have to get the direct addresses of the DNS servers of your provider to get these click on your start menu button in Windows then look for "Run..." and enter the command cmd and hit enter.
A command line should pop up enter the commain ipconfig /all in it that will list the DNS servers set these up for the xbox as well and retry again.
If it should still not work then something else must be wrong with your connection setup like your router blocking your xbox because you didnt allow it to connect to the internet or so, there are various reasons.
I hope this helps.
Kind regards,
Wilhelm@Xboxexperts.com
Posted on Mar 07, 2009
DNS FAiLED thats only the problem .. i can connect to wifi but when i start typing the url then enter go ..the response is dns failed
It is a problem due to DNS server ip address.If you configured ip address in mobile manually to connect wifi check the DNS address.If you have connected to wifi automatically means there is a problem of DNS ip in the wifi router configuration.Google has public dns of 8.8.8.8 if possible configure in Mobile and try it
Oct 28, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
Tip
Why can't you connect to the Internet?
First check your TCP/IP address - see my earlier tip on checking you are connected to a network. For most recent systems, (not Linux) open a command prompt window (type "cmd" in the RUN window from the start menu) and type ipconfig /all
you should see your network adapter name and IP address, a subnet mask (don't worry) and a default gateway, also a DNS server IP address. If ANY of these are missing, that's your problem, try repairing or resetting the network adapter. WRITE THEM DOWN. You may have more than one adapter, you need to identify which one is used for the Internet connection.
If they are all there, from the SAME window type "ping" followed by the IP address of your default gateway. If this fails, you have no connection to your internet router, find out why!
If this succeeds, type "ping" again, followed by the IP address of your DNS server. If this fails, type "tracert" and then the IP address of your DNS server. The FIRST address that will be reported is your default gateway; followed by your ISP address; if the only address you see is your default gateway, the link to your ISP  is down, give them  a call. If it succeeds, from the same window type "nslookup"
You will see a chevron prompt, type in the name of the site you want to go to, e.g google.com.
You should then see a reply from your DNS server, and an IP address for your required server. If not, then either your DNS server settings are wrong OR the server does not exist. It will be obvious which it is from the reply you receive. If the DNS settings are wrong, you can change them from the Control Panel, Network, Network adapter, Properties, TCP/IP v4 properties menu; try setting DNS server to 8.8.8.8 or 8.8.4.4 and try again.
on Mar 26, 2010 | Computers & Internet
Tip
Tip 1: One of the major problems with BSNL Dataone Broadband connection is the...
a9d13a0.jpgTip
1: One of the major problems with BSNL Dataone Broadband connection is the DNS servers they provide by default. Most of the timethey are very slow and sometimes they fail to respond. I noticed that Iam starting to spend a significant amount of time in DNS resolutionwith Dataone connection, often it is larger than the time it takes toactually get the reponse. Here is a simple solution to significantly speed up your DNS resolution.
Open up the network connectionprofile and
edit TCP/IP settings. In the DNS server address fields,specify the following
DNS server addresses: 208.67.222.222 and208.67.220.220
Disconnect the connection and then connect again. You are done.
This specifies third party DNS servers which are significantly faster than BSNL Dataone’s DNS servers.
Tip 2: Firefox users can use FlashBlock extension to preventdownloading of Flash content by default, thereby significantly speedingup browsing experience. You can click on the placeholder icon todisplay the original Flash content any time. This is more of a passivetip in that reduces data usage to improve your overall experience.
Tip 3: You can try to increase your broadband bandwidth tweaking theTCP/IP parameters. The process is simplified by using TCPOptimizer, afree tool. It helped me, your mileage may vary.
on Dec 24, 2009 | Computers & Internet
Network diagnostics = failed DNSServerSearchOrder
Click Start
Click Run
Type CMD and press ENTER
Type IPCONFIG /ALL and press ENTER.
Look for lines of output like:
Ethernet adapter Local Area Connection:
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
DHCP Server . . . . . . . . . . . : 364.259.160.040
DNS Servers . . . . . . . . . . . : 364.259.160.13, 364.259.160.15
especially the "DNS Servers" line.
Call the "Support Desk" of your Internet Service Provider, if that "DNS Servers" line is blank -- or even if it is non-blank -- ask the ISP what the values *SHOULD* be -- just in case your computer has been "hijacked" to point to "rogue" DNS-servers.
Nov 18, 2009 | Microsoft Windows XP Home Edition
Tip
Bsnl Broadband speed trick
Tip
Linksy router
a DNS server stands for domain name service. The DNS server translatesnames from IP addresses. The internet sees IP addresses such as 209.235.250.53 but the DNS server provided by your ISP translates it for you into fixya.com. You should be able to aquire the DNS server information from your internet provider (ISP) hope this helps.
Jul 10, 2009 | Linksys Wireless-G WRT54G Router
RECOVER FIRST DNS
Is there a running Domain Controller present? If so DNS info is often stored in Active Directory (A.D. Inegrated DNS Zone).  If this is the case you can just connect a server to the network, join the domian (verify DNS settings in TCI/IP config is pointing to Domain Controller) and then installm DNS from Add/Remove windows components.  Zone data should replicate from AD to new DNS server, to verify open DNS console and look for resource records relevent to the domain.
Dec 17, 2008 | Microsoft Windows Server Standard 2003 for...
Hurricane h5200 modem/router
Hello jmazaredo,
Does your DNS server have your server fqdn in its tables, and does your PC have the address of your DNS server in its lookup table?
One test you can do is to use the hosts file to put the fqdn into and assign it an address this would let you know the the PCs can use host tables to do the translation then this becomes a DNS issue as opposed to a lookup issue and you cut your troubleshooting in half.
In other words edit your hosts tables (hosts file) with the entry (Example 1):
IPADDRESS FQDN ALIAS
192.168.10.2 somesystem.myhome.com. system
192.168.10.5 somesystem2.myhome.com. system2
This as stated will determine if you have a DNS issue or a lookup issue, because the DNS system will use host tables first and the do a DNS lookup.
Once this is done if it works then try this setup:
1) in your router set the DNS to capture the DNS of your ISP (normally the setting will tell the router to use the DNS given to it by the DHCP protocol.
2) turn on DHCP on the LAN side of the connection in the router and set the controls for proxy DNS service (using the router as the local DNS server also called caching DNS server), However set the router up to allow static IPAddreses and if possible to recognize the domain name of the local LAN.
3) set your servers up with static IP addresses and in their host tables set the fqdn up as stated above in Example 1
4) in your PC set the DNS to be the IP Address of your LAN side of your router i.e. 192.168.1.1 and if needed set the host tables of all PCs to the server addresses, fqdn, and aliases this way if DNS fails the system will at least have the host tables to use.
I hope this helps.
Thank you,
Shuttle83
Aug 14, 2008 | Computers & Internet
Hooking up my playstation 3 to the internet with a wireless connection
enter the DNS server addresses manually in the PS3 network settings AND use tetertiary DNS server from my ISP as either the primary or the secondary DNS server
Feb 01, 2008 | Sony Playstation 3 (PS3) Console
Microsoft Xbox 360 Console Logo
42 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
