What caused my kitchen pipe to burst?
Recently I turned off the hot tap at my kitchen sink, immediately afterwards I heard a hissing noise which made me turn back to check (both taps were switched off) and then hot water suddenly started flooding the kitchen. It was all pretty instantaneous and something had caused the hot water inlet hose to my machine to burst. The rubber pipes had a white hessian type covering which were previously in very good condition showing no signs of wear and tear at all. However the force had caused a clean sharp break. I asked the plumber who fixed it whether water pressure or a build up of air caused it to which he replied neither and that he had never come across this problem before. Since the incident the water pressure has been deemed fine and although the pipes knock in my kitchen and bathroom I've been told that's common in old houses (I live in a Victorian terrace conversion) and nothing to worry about. Something made the pipe to burst and I would be very grateful to anyone who could diagnose the possible cause. Thank you
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
I have never heard of this in all my years of appliance repair but I would tend to think that it was a one off hose and nothing more than that.
Well, that's my two cents. :)
Posted on Nov 02, 2012
  • 1462 Answers
SOURCE: Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
Posted on Jun 22, 2007
IB4G2008
  • 3587 Answers
SOURCE: Old washing machine is starting to leave grey streaks on clothing
hmmm..let's see..sounds like you have some residue accumulating from something possibly seeping into the tub. That can be old rubber, a metal sheath, or even an leak of lubricant. Like an old car, there are parts of every mechanical device that need to be attended to.
I'd recommend you find the most seasoned person that works on older machines, to come by and assess what is 'leaking' on your clothing. Grey comes from something metallic or rubber/plastic.
Hope you can solve this one, and keep that old machine happy.
Posted on Feb 19, 2008
jsrock516
  • 5911 Answers
SOURCE: whirlpool front loader washing machine
I would recommend you replace the water inlet valve. This is the only device between the fill hoses and the dispenser that controls the flow of water. The "hissing" noise you hear could be a defective solenoid in the valve that is staying open and allowing water to flow. Try turning the water off at the tap to see if the sound goes away. If it does...water inlet valve. Another tale-tell sign of an inlet valve leaking would be a small trickle of water running down the dispenser tube in the rubber door boot. Over a period of time, the tub will begin to fill and possibly overflow (even with the washer turned off).
You can find a replacement valve at searspartsdirect.com. Just type in your model number and look under the "Dispenser Parts" heading for item number 1 (part #8181694).
Replacing the valve is simple. Just follow these steps:
1. Unplug washer, turn off water supply and remove hoses from the back of the washer.
2. Remove the top panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off.
3. The water inlet valve will be located at the left rear of the washer (as viewed from the front).
4. Remove the dispenser hose, electrical connections and mounting screws and the valve is removed.
5. Install new valve by following these steps in reverse order. NOTE: When reinstalling top panel, make sure you lay panel on top of washer, leaving a couple of inches of room from the front panel. Then, slide panel towards you (front of washer) so that the top panel slides into the mounting clips.
I hope this information is helpful to you. If you still require assistance, or if you feel I'm wrong in my assessment, please post back and let me know.
Posted on Oct 07, 2008
onthejob5130
  • 640 Answers
SOURCE: Can't turn off taps for cold water hose
if you have the type with little screw in the middle tighten than try again,,,or if you can take it of use a small pliers to turn it off,,onthejob
Posted on Jan 10, 2009
mkh5094
  • 145 Answers
SOURCE: Water Leak
Yes all you have to do is take off the front cover of the washer or the back cover, it it usually the front on top load washers. I believe your water pump may be cracked, but am not sure. What you need to do is remove the cover and start your washer and let it fill. Get a flashlight and pay close attention to where the water is leaking from. Then all you have to do is replace the part and your done. Any part dealing with water leaking will not be hard to change.
Posted on Apr 27, 2010
How to troubleshoot a water heater
1) If water flow stops when tap is off, then Sound of water running: could be factory-installed heat trap inserts or nipples: These things cause noise.
http://waterheatertimer.org/Low-hot-water-pressure.html#trap
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html#heat-trap
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
2) If sound of water continues when tap is off, then there is a broken pipe or leak somewhere in plumbing system.
Feb 17, 2013 | Reliance 606 Series 40 Gallon Natural Gas...
I have a BOSCH 425N tanlkess hot water heater. In order to get hot water to flow to the sink taps, I need to turn more than one tap on (eg. if I want hot water at kitchen sink I must also turn a bathroom...
You need to have the flow switch looked at. The low flow of the water to the lavs and the kitchen sink, they all have as small demand next to t bath or shower,
Tom
Sep 19, 2011 | Bosch 425HN NG Tankless Water Heater
The rinnai 20 Infinity is perfect but have recently noted a problem. I found the basin hot water tap in the bathroom begin dripping only when the kitchen hot water tap is turned on. I don't know how...
Some taps are designed to release excess pressure but it could just be a dodgy tap washer that leaks when the pressure of hot water in pipe work builds. Change the tap washer in your tap, see if it fixes it, if not it's just the design.
Jul 02, 2011 | Water Heaters
Water hammering after disconnecting a washing machine. I have just replaced our old washing machine that took a hot and a cold feed, with a new washing machine that only takes a cold feed. I have turned...
You can use a water hammer arrestor and hook it up to old washing machine hot valve by use of a standard washer hose. This type of aresstor is basically. a shock absorber. You will needtonget pipe adapters to go from hose thread to pipe thread.If you can mount the hammer arressror higher then the washer valve. Hook everything up and turn old hot water valve back on. This shoulg take care of your problem. Thank you.
Jun 02, 2011 | Plumbing
Hot water noise when tap is turned on louder when full on at tap. Atwood MOdel GC104A
Noise in pipe means vibration.
Pipes vibrate when water turns corner, or if there is a clog somewhere in the line, or if there is air in the line.
Water heaters make noise when sediment builds up inside of tank.
I would probably try to track location of noise, and then put that spot on top of suspect list. For example if sink has shut-off, and noise seems loudest there.
May 08, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
Hot water flow is fine to the bath but to the bathroom basin and downstairs kitchen sink it is just a trickle. We recently had a new kitchen fitted and the problem has arisen since.
Check the end of the tap where the water comes out, if there is a fine filter on there it may be blocked, unscrew the end where the filter is and clean, if clean you have a restriction in the pipes
Jan 22, 2011 | Plumbing
I have a LG intello dishwasher 2050SH Turned it on yesterday and did a rinse. This was the first use for 4 months in our second home. It was very cold. The rinse stopped some way through and an error...
Hi
To unlock the lock in your LG Dishwasher, with the door open press the SPRAY & RINSE buttons simultaneously for 15 seconds. Hope this helps...please post back for further assistance.
Daniel
Dec 24, 2010 | Dishwashers
How do I install a second hand waher/dryer with limited piping?
1 yes all standard.2 Yes you can get a Y piece. 3 no you will only use water from cold. But you can solve that by going to a good hardware store or B.Q and gettein a self cutting tap for washing machines. You can fit this in just minutes, and do not even need to turn off the water supply. just make sure there is a clean straight piece of pipe to fit it to. 4 yes fit waste pipe to u bend under sink.
Feb 04, 2010 | Washing Machines
I have mixer taps fitted to my kitchen sink which leak from under the mounting seal when the taps are turned on.when the taps are turned off the leak gradualy stops and the actual tap never leaks,do the...
It appears that the seal at the base of the tap is worn or the screw collar is loose - try hand-tightening it. It may cure your problem. Plumbers tape is a white tape that helps seal water pipe joints!
Oct 08, 2009 | Plumbing
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
