Question about Sony Audio Players & Recorders
Sony Home Theater ss-ws92 subwoofer not working
Sub woofer not working
SOURCE: Sub Woofer Won't Work
mbruno did this work? I have the same issue
Posted on Jan 16, 2008
sanjin
  • 56 Answers
SOURCE: subwoofer noise
You didn't say is your sub active or passive.If its active first check signal cables from theater system,power line of the sub, it has to be the same phase as the system.If its passive take a voltmeter disconnect the sub from the system and measure for DC voltage on the SUB output on the system when its OFF.If DC voltage is present your amp is damaged.It can also be that the preamp circuit for the sub doesn't mute the input when unit is on stand by and you hear frequency of your power supply (50-60Hz) on the sub
Posted on Mar 10, 2008
  • 10 Answers
SOURCE: Velodyne FS12 Subwoofer Problem
I regret to inform you that it sounds like the velodyne's internal amp has a problem and will likely require servicing.
Posted on Oct 24, 2008
  • 93 Answers
SOURCE: Problem w/ Panasonic SA-HT700 speakers
Let me show how to resolve your problem since you are not very good at this system.
A/V troubleshooting 101:
Remember the 2 speakers that you mentioned before that it worked.First,locate the one speaker output that work for you before(ex. front left)you will use this speaker output to connect each one of the speaker and leave the system on either tuner(radio with a proper station=101.3) or a dvd with sound,this way,you are troubleshooting two things for sure A. be sure all your speakers do work and B. your source is working.
After you test all the speakers with the same speaker output which had confirmed the speakers are working,that particular speaker output is working and also your source is working,send me an email and i will show the next step.
However,for any reason,if one of those speaker got no sound from the same speaker output connection,please do not waste anymore time,should take it back to the place you bought it from and get our money back and try to buy the A/V system separately(A/V receiver with speakers in one package, separate dvd player,etc.)
Cheers,
solutiondoct
Posted on Nov 06, 2008
SOURCE: sony subwoofer model# sp-pwm505
I have a JVC sub woofer SP-pwm 505 can I use this with any system my receiver has RCA jacks it looks like this uses a S cable...is there a cable that would convert "S" cable from sub woofer to an RCA output jack in receiver allenfreedman@yahoo.com
Posted on Nov 21, 2008
Sub woofer is not working. it has orange flashing light at the back
Look at the connection of the sub woofer. The orange light indicates either there is some problem with the wire or the connector at the end of the wire.
Also make sure the pin or hole where you insert the sub woofer is working perfectly. You can simply check it by placing another sub woofer at that vary spot and see if it is working fine. If the hole is fine then the problem is either with your cord or your wire pin.
Oct 24, 2012 | Audio Players & Recorders
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
QUESTION ABOUT SPEAKERS. SPRCIFICALY WOOLFER. WHAT KIND OF WOOLFER SHOULD WORK BEST WITH THIS AMP?
hi,
Do you mean sub woofer. Then you can select any brands Active sub woofer ( active means built in amplifier) to connect with your system. They comes in different power (watts). you can use an active sub woofer with 100W output.
connect the sub woofer pre out of you amp to the pre input of sub woofer.
ok
Feb 05, 2011 | Technics SA-EX500 Receiver
How it can be connected to a stereo amp
hi,
if ur amplifier have a pre out, then u can connect that to ur L/R input of ur sub woofer.
if not the only way is, connect ur amplifiers speaker output to sub woofers speaker input and then connect ur speaker to sub woofer speaker output terminal. remember don't inter change positive and negative wires.
if ur amplifier have speaker A,B connection then it is very easy. connect the speaker A to ur left and right speaker. then connect speaker B to ur sub woofer's left and right speaker input. be sure to make that speaker A and B switch is in on position. the power on both and check it. ( use good quality speaker cable to connect the sub woofer)
your sub woofer is designed to work , both at low level and high level input.
ok
Dec 17, 2010 | Yamaha YST-SW215 Subwoofer
Connecting a Sony Subwoofer SA-W2500 to a STR DE 598
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Jan 08, 2010 | Sony STR-DE598 Receiver
If i increase the sub woofer volume the voice distorts and gives a buzzing sound. it works fine on low volume
Your sub woofer is not mean for voice sound...check that you have connected the systen up properly and that you have put the sub woofer into its wn connection..if it is in the right connection the woofer could be blown.also try decrease the midrange hurts on the woofer
Jan 03, 2010 | Audio Players & Recorders
Hi I own a Technics Hi-Fi system (Model SC-EH780) and would like to attach a subwoofer to it. I cannot find the subwoofer unit that is supposed to go with this system. Can you help?
Any powered sub-woofer will work with it. Check the back of the Technics, make sure there is an RCA output labeled "Sub-woofer" or "Woofer" or "Sub". If so, you can get any brand of powered sub woofer and it will work. A powered sub-woofer is one with an amplifier for the sub built into the box and you will need to plug it into an A/C outlet as well. The only exceptions to what will work with this unit is to make sure you are not buying a sub-woofer that is made to only work with the companion unit it is originally sold with. Many Panasonic and JVC sub woofers are like this. Just look for a sub-woofer that is not part of any system. Velodyne makes some really great sub-woofers that would work nice with yours, but they can be a little expensive, but they are very good.
If your Technics has no RCA output for the sub-woofer, you will need to make sure that whatever powered sub-woofer you buy has a speaker level input for it. Most powered sub-woofers have this feature, so that you may just run the front speaker outputs of the receiver into the subwoofer and then the sub-woofer will have a set of speaker outputs right below the speaker inputs so you can still have your front speakers connected to that and not loose anything from your system.
I hope I have explained this in a manner you will understand easy, if not just post whatever questions you may have right on this thread and I will get back to you as soon as possible.
It would also be appreciated if you could rate this solution if you no longer need any help from me. If you do require more help, please wait to rate this until we are finished. That way I do not get an undeserved bad rating when we have not even finished our communications.
By the way, A "Thanks for trying" and "Helpful" rating are really not good, they always end up lowering my overall score.
Dave
Nov 09, 2008 | Audio Players & Recorders
Sony subwoofer model# sp-pwm505
May 15, 2008 | Audio Players & Recorders
156 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
