Question about Epson Office Equipment & Supplies
Service req e542
Printer comes ready, you then try to print. It says printing waits 5 mins then this error appears. Could this be the Photoconductor unit faulty?
5 Suggested Answers
  • 300 Answers
SOURCE: Epson CX11NF Error Message Service Req E511
This is from the service manual
Service Req E511
�� Possible parts that caused the error�� Troubleshooting
�� Photoconductor Unit �� SENSOR TR-0
�� HARNESS-ASSY XERO �� MOTOR ASSY P/R
�� HARNESS ASSY MAIN �� PWBA MCU�� LV/HVPSStep Check Yes No
1 Check of Photoconductor Unit attachment
Re-attach Photoconductor Unit.
Does the error recur when the power is turned
ON?
Go to Step [2]. End of
procedure
2 Operation check of Photoconductor Unit
Is the Drum of Photoconductor Unit rotating?
Go to Step [3]. Go to Step [10].
3 Check for dirt on silver seal on Belt in
Photoconductor Unit
Remove Photoconductor Unit.
Turn gear of Photoconductor Unit until silver
seal attached to Belt can be seen.
Is silver seal dirty?
Replace
Photoconductor
Unit.
Go to Step [4].
4 Check of SENSOR TR-0 (TR0 Sensor)
Is SENSOR TR-0 attached securely?
Go to Step [5]. Re-attach
the SENSOR
TR-0, and go to
step [5].
5 Check of dirt and foreign bodies on surface
of SENSOR TR-0
Are there any dirt or foreign bodies on the
SENSOR TR-0 surface?
Clean to remove
any dirt or
foreign bodies,
and go to step
[6].
Go to Step [7].
6 Does the error recur when the power is
turned ON?
Go to Step [7]. End of
procedure
7 Operation check of SENSOR TR-0
The voltage of P416-2 ↔ P416-3 on PWBA
MCU is 5 VDC when silver paper or other
reflective object comes close to the sensing
area of SENSOR TR-0, and is 0 VDC when
the object is released?
Replace PWBA
MCU. (p.404)
Go to Step [8].
8 Check of 5 VDC power supply to SENSOR
TR-0
The voltage of P416-1 ↔ P416-3 on PWBA
MCU is 5 VDC?
Go to Step [9]. Go to Step [14].
9 Continuity check of HARNESS-ASSY XERO
Disconnect the P/J416 from PWBA MCU.
Do all of the wiring below have normal
continuity?
J416-1 ↔ J108-3
J416-2 ↔ J108-2
J416-3 ↔ J108-1
Replace
SENSOR TR-0.
(p.361)
Replace
HARNESSASSY
XERO.
10 Check after replacement of MOTOR ASSY
P/R
Replace MOTOR ASSY P/R. (p.398)
ON?
Go to Step [11]. End of
procedure
11 24 VDC power supply check to MOTOR
ASSY P/R
Disconnect P/J201 from MOTOR ASSY P/R.
The voltage of J201-1 ↔ J201-2 is 24 VDC?
Go to Step [12]. Go to Step [13].
12 Continuity check of HARNESS ASSY MAIN
Disconnect the P/J403 from PWBA MCU.
Is the continuity normal between all terminals
of J403 ↔ J200?
Replace PWBA
MCU. (p.404)
Repair broken
or shorted part.
13 Continuity check of HARNESS ASSY MAIN
Disconnect P/J502 from LV/HVPS.
continuity?
J502-9 ↔ J201-1
J502-10 ↔ J201-2
Replace LV/
HVPS. (p.407)
Repair broken
or shorted part.
14 5 VDC power supply check to PWBA MCU
The voltage of P410-3 ↔ P410-4 on PWBA
MCU is 5 VDC?
Replace PWBA
MCU. (p.404)
Go to Step [15].
15 Continuity check of HARNESS ASSY MAIN
Disconnect P/J410 from PWBA MCU and P/
J502 from LV/HVPS.
continuity?
J410-3 ↔ J502-3
J410-4 ↔ J502-4
Replace LV/
HVPS. (p.407)
Repair broken
or shorted part.
Posted on May 22, 2008
Inky
  • 691 Answers
SOURCE: Service Req C0302
CPU Error. Mainboard is faulty.
Posted on Jul 23, 2008
antiochpc
  • 1314 Answers
SOURCE: Fault 37,002.47:338665
From the service manual:
37,002.4x - PEST_FAULT_JSL_HEATER_DISCONNECT
PEST - Left jetstack disconnect.The left jetstack is not drawing the expected power from
the supply.
1. Run the printhead Left Jetstack Heater test.
2. Verify printhead wiring.
Yes, could be faulty printhead, but could be faulty power supply as well.
I have the full service manual available if you need it. Please take a moment to give this solution a rating of fixya. Thanks!
Posted on Mar 10, 2009
ViscamTech
  • 528 Answers
SOURCE: Stepson has a 2600 and when installed says
I don't think you have connected the printer as a network printer. If you have just connected the printer to the computer, the firewall will not block anything to the printer. If it says system doesn't meet min. requirements, try increasing the RAM of the computer. That will probably help!
Posted on Jul 21, 2009
My printer is blinking green light in every 5 seconds. i am give test print but is not came to print
Ready and Error Lights (EPL-6200L only)
The Ready (green) and Error (red) lights on the top of the printer may be the first indication of trouble. The status of the lights, on, off or flashing, indicates your printer status, as described below. The Status Alert window in the EPSON Status Monitor 3 utility indicates what type of error has occurred and offers you a possible solution. Look through this section to find the kind of problem you have, then try the recommended solutions in the order they are presented until your problem is solved.
a. Error light (red)
b. Ready light (green)
Status/Error/Warning
INDICATOR LIGHTS
Ready
Error
Service Required (controller error)
OFF
> Service Required (engine error)
> > Service Required (protocol error)
> > Output Paper Jam
> > Paper Jam
> > Paper Out/Feed Jam
> > No Developer Cartridge Installed
> > Wrong Developer Cartridge Installed
> > Installed Developer Cartridge is Not a Genuine EPSON Product
> > Developer Cartridge Memory Error
> > Toner Out
> > Front Cover Open
> > Output Cover Open
> > Printing on Incorrect Paper Size
> > Unsupported Paper Size
> > Time Out Error
> > Insufficient Memory to Print Current Page
> > Paper Size Warning
> OFF
Not All Pages Are Printed
> OFF
Warming Up
> OFF
Replace Photoconductor Unit
> OFF
Toner Low
> OFF
Installed Developer Cartridge is Not a Genuine EPSON Product Warning
> OFF
Sleep mode
> OFF
Ready
> OFF
Printing
> OFF
Processing Data
> OFF
> Note: > If the problem remains after trying the suggestions in this section, contact your dealer or a qualified service representative for assistance.
Control panel: Error light on
A controller error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If all the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready and Error lights flashing
A print engine error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Control panel: Ready light flashing, Error light on
A protocol error has been detected. Turn off the printer, wait 5 seconds and then turn it back on. If the lights come on again, turn off the printer, unplug the power cord, and contact a qualified service representative.
Output Paper Jam
Control panel: Ready and Error lights on
Indicates that there may be a paper jam inside the printer. Open the printer's output cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Jam
Indicates that there may be a paper jam inside the printer. Open the printer's front cover, remove any jammed paper, and close the cover. The error will automatically clear itself and the jammed page's print data is reprinted.
Paper Out/Feed Jam
Indicates that there is either no paper loaded in the printer, or there is a paper jam in the feed slot.
If no paper is loaded, load paper into the MP tray, then open and close the printer's front cover. See Loading Paper for instructions on loading paper.
You can clear the error by pressing Continue on the EPSON Status Monitor 3 window that appears.
If paper is loaded, then there is a paper jam in the feed slot. See Clearing Jammed Paper for instructions on clearing paper jams. The error is automatically resolved upon clearing the jammed paper and opening and closing the printer's front cover.
Either the developer cartridge is not installed or is installed incorrectly. Check to see if the developer cartridge is properly installed and follow the instructions under Developer Cartridge to install or reinstall it.
Either the installed developer cartridge is defective, or it is not the right one for your printer model. Replace it with a new or correct developer cartridge by following the instructions under Developer Cartridge.
Control panel: Ready light on, Error light flashing
The installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
To continue using the currently installed developer cartridge, press Continue on the EPSON Status Monitor 3 window that appears to clear the error.
A memory read/write error has occurred. Try reinstalling the developer cartridge or replacing the current cartridge with a new one by following the instructions under Developer Cartridge. If this still does not resolve the problem, turn the power off and then on again.
Toner Out
The developer cartridge is out of toner. Replace the developer cartridge by following the instructions under Developer Cartridge. To clear this error and print a single sheet, press Continue on the EPSON Status Monitor 3 window that appears to clear the error. After that, this error will occur again until the developer cartridge is replaced. If you set the Toner Out Error setting to Off, you can continue printing even when this error occurs.
Front Cover Open
The printer's front cover is open. Make sure that the printer's front cover is closed properly by opening and closing it again.
Output Cover Open
The printer's output cover is open. Make sure that the printer's output cover is closed properly by opening and closing it again.
The paper loaded in the paper source does not match the required paper size. Replace with paper of the correct size and click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
The specified paper size is not supported by this printer, or the paper feed direction is incorrect. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Time Out Error
Data transmission from the computer to the printer is interrupted and a timeout error has occurred. Click Print Again on the EPSON Status Monitor 3 window that appears to resume printing. If printing does not resume, or if you want to change printer driver settings, click Stop.
The printer does not have sufficient memory to print the current page. To continue printing from the page after the page that caused the error, click Continue on the EPSON Status Monitor 3 window that appears. If you want to change printer driver settings, click Stop.
Paper Size Warning
The size of the paper that fed through the printer does not match the specified paper size. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
This warning is displayed if an Insufficient Memory to Print Current Page error has occurred while Auto Continue is set to On. Click Close on the EPSON Status Monitor 3 window that appears to dismiss the warning.
Warming Up
Indicates that the printer is warming up to process and print data.
Control panel: Ready light flashing (flashes at longer intervals than usual)
Indicates that the photoconductor unit is close to the end of its service life (less that 5%). Prepare a new photoconductor unit to replace the current one. See Photoconductor Unit for instructions.
To temporarily dismiss the warning, click Close on the EPSON Status Monitor 3 window that appears. Resetting the photoconductor unit also clears the warning.
Toner Low
Indicates that the developer cartridge is nearly out of toner. Prepare a new developer cartridge to replace the current one. See Developer Cartridge for instructions.
This is a warning to inform you that the installed developer cartridge is not a genuine EPSON product. The use of such products may damage the printer and cause the print quality to decrease. Remove the currently installed cartridge and replace it with a genuine EPSON cartridge by following the instructions under Developer Cartridge.
Sleep mode
Indicates that the printer is in energy-saving mode. The printer goes into standby due to inactivity. If the Sleep mode is enabled, the printer goes into standby in 15 minutes.
Ready
Indicates that the printer is ready to print.
Printing
Indicates that the printer is printing data.
Processing Data
Indicates that the printer is processing data.
Mar 18, 2015 | Epson laser Printer EPL-6200L Laser
Problem for Epson Aculaser C1100 Printer Error E542
Hi
Not much I can say for you I can only tell you what the error is but how to fix it I not know I try to look it up for you but every thing about this printer is in french,
Service Req E542: failure to clean the transfer unit
This all I can find Sorry.
All the best hope you find away to fix it
Pineworks
Feb 06, 2010 | Epson Aculaser C1100 Printer
How do I replace the photoconductor where is the menu button to reset PC CNT appears after it is replaced?
Power the printer on and get it to the Ready state. With the printer on and in the Ready state, open the front cover.
Press and hold the Cancel button until all of the lights begin flashing up and down.
Release the Cancel button and close the door. The photoconductor count should now be reset.
To confirm that the photoconductor page count has been reset, it is recommended that you print a menu settings page and check the photoconductor level. Do the following:
With the printer at the Ready status, press the Continue button once. The Ready light will begin flashing and one or two pages will print out.
Look for a section labeled Cartridge Information and locate the word Photoconductor under this heading.
Confirm that the photoconductor level reading is either OK or close to 100%.
If the reading is low, try printing 10 - 20 pages. Print the menu settings page(s) again.
Confirm that the photoconductor level reading is OK or close to 100%.
Good luck, Gerrit Jan
Oct 29, 2009 | Lexmark E232 Laser Printer
How do i reset a new photoconductor in lexmark e450dn.
According to Lexmark E450DN service manual;
1. Turn off the printer.
2. Press and hold Checkmark and Right Arrow buttons.
3. Turn on the printer.
4. Release the buttons when 'Performing Self Test' displays.
The message CONFIG MENU displays on top line of operator panel.
5. Scroll down and select 'Reset PC Cnt.'
Sep 25, 2008 | Lexmark Office Equipment & Supplies
Clearing message after "replace photoconductor kit" message came on
To reset the photoconductor page count:
  2. While the printer is off, press and hold the Select (pattlnk_1262005_1956-enus20772_selectbuttonicon_t64x_en_us.gif) and Return (pattlnk_1262005_1950-enus21096_returnbuttonicon_e340e342_en_us.gif) buttons on the operator panel.
  3. While keeping both buttons held down, turn the printer back on. Keep holding down both buttons until the printer screen displays Performing Self Test or CONFIG MENU.
  4. Release the buttons when you see either of these messages.
  5. If Reset PC Cnt does not then appear on the screen, press the left or right menu button until it does.
  6. Press the Select button once. The message Resetting PC Cnt Value should briefly appear on the screen, indicating that the photoconductor page count has been reset.
  7. When the display shows CONFIG MENU again, power off the printer.
  8. Wait five or more seconds and then power the printer back on. NOTE: Do not hold any buttons down when powering on the printer during this step.
    The photoconductor page count should now be reset. At this point, it is recommended that you print a menu settings page to confirm this. Do the following:
    1. With the printer at the Ready status, press the left or right Menu button until UTILITIES MENU appears on the screen.
    2. With UTILITIES MENU on the screen, press the Select button once. A new menu should appear.
    3. If Print Menus is not displayed on the second line of the screen, press the left or right menu button until Print Menus appears.
    4. Press the Select button once. The message Printing Menu Settings should appear on the screen and the printer will print out one to three pages of printer settings.
    5. Look for a heading labeled Cartridge Information on one of the menu settings pages.
    6. Under Cartridge Information, look for the word Photoconductor. Confirm that the level of the photoconductor says OK or is close to 100%.
    7. If the photoconductor is still reading low, try printing 10 - 20 more pages.
    8. Print the menu settings page(s) once more. Confirm that the photoconductor level is now at OK or close to 100%.
    9. If the photoconductor continues to give a low reading, repeat this entire procedure again from the beginning to reset the counter once more.
    10. If the photoconductor reading is still low after two attempts to reset the counter, the printer may require service.
Jul 28, 2008 | Lexmark E342n Laser Printer
Service Req C0302
Jul 04, 2008 | Epson AcuLaser C1900 Printer
Service Req E511
ON?
procedure
Photoconductor Unit
Replace
Photoconductor
Unit.
Go to Step [4].
the SENSOR
TR-0, and go to
step [5].
of SENSOR TR-0
Clean to remove
any dirt or
foreign bodies,
and go to step
[6].
Go to Step [7].
turned ON?
procedure
Replace PWBA
MCU. (p.404)
Go to Step [8].
TR-0
MCU is 5 VDC?
continuity?
J416-1 ↔ J108-3
J416-2 ↔ J108-2
J416-3 ↔ J108-1
Replace
SENSOR TR-0.
(p.361)
Replace
HARNESSASSY
XERO.
P/R
ON?
procedure
ASSY P/R
of J403 ↔ J200?
Replace PWBA
MCU. (p.404)
Repair broken
or shorted part.
continuity?
J502-9 ↔ J201-1
J502-10 ↔ J201-2
Replace LV/
HVPS. (p.407)
Repair broken
or shorted part.
MCU is 5 VDC?
Replace PWBA
MCU. (p.404)
Go to Step [15].
J502 from LV/HVPS.
continuity?
J410-3 ↔ J502-3
J410-4 ↔ J502-4
Replace LV/
HVPS. (p.407)
Repair broken
or shorted part.
May 22, 2008 | Epson Aculaser C1100 Printer
Error c0998
That what service manual says:
Service Req xyyyy
A Controller error or print engine error detected. Turn off the printer. Wait at least 5 seconds and then turn it back on. If the error message still appears, write down the error number listed on the LCD panel (xyyyy) and turn off the printer, unplug the power cord, and contact a qualified service representative
Apr 29, 2008 | Epson Aculaser C1100 Printer
Ibm infoprint reseter
Here is a procedure I would like you to do to reset the light:
1-Power the printer on and get it to the Ready state (i.e. the light on the operator panel is on)
2-With the printer on and in the Ready state, open the front cover
3-Press and hold the Cancel button until all of the lights begin flashing up and down.
4-Release the Cancel button and close the door. The photoconductor count should now be reset
1.With the printer at the Ready status, press the Continue button once. The Ready
2. Look for a section labeled Cartridge Information and locate the word Photoconductor
under this heading.
3. Confirm that the photoconductor level reading is either OK or close to 100%.
4. If the reading is low, try printing 10 - 20 pages.
5. Print the menu settings page(s) again.
6. Confirm that the photoconductor level reading is OK or close to 100%.
7. If the photoconductor reading is still low, there is a second, more detailed, procedure you
can perform to reset the count.
8. If the reading is still low after both procedures have been attempted, the printer may require service
Apr 06, 2008 | IBM Infoprint 1412 Laser Printer
Solution to epson c1100 error message
Turn printer off and remove photoconductor unit, close covers and turn printer back on without photoconductor, error will appear that you need to install photoconductor, install photoconductor and wait til it calibrates, if same error appears photoconductor is a consumable part you will have to replace it then.
Pls dnt 4get to rate solution. TY
Mar 18, 2008 | Epson Aculaser C1100 Printer
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
