Question about Frigidaire Washing Machines
My dryer timer is not counting down - Frigidaire Washing Machines
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 02, 2012
  • dustin518
    dustin518 Nov 05, 2012
    Frigidaire MET1041ZAS
  • Richard Roth
    Richard Roth Nov 05, 2012
    You will need to replace the timer. Here is the part to order. http://click.linksynergy.com/fs-bin/clic...
Does the timer count down on sensor heating
On a sensor drying, timer shows ONLY estimated time to finish. It might add some time, or finish sooner depending on the size of load, fabric, and saturation.
Dec 23, 2014 | Samsung DV5451AEW Dryer
Whirlpool dryer doesnt heat, time and shut off when you open the door
if you have it on time dry and it doesn't count down the timer is bad but it should stop when you open the door unless you have a broken door switch too,just open the door and push in on the switch with your finger,it should make a clicking sound,if not the door switch is also broke,if you have the timer on auto or more or less then it won't move without heat.on auto the heat comes on when the dryer reaches temp. the heat shuts off and the timer will advance a little,then the heat starts again and the timer stops,it will do this until the clothes are dry by using a sensor instead of time.
Feb 16, 2014 | Whirlpool GEQ9800P Electric Dryer
My dryer timer counts down to 7 minutes and then continues drying
replace the sensa board and make sure the wires on the sensors are ok
Jun 07, 2010 | Whirlpool GEW9250 Electric Dryer
Dryer will not turn on, i can hear the timer counting down
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 06, 2010 | Crosley CDE6000 Electric Dryer
Whirlpool dryer- timer freezes ~10 minutes left
Try running it in a different cycle. You may have a bad timer.
Mar 17, 2010 | Whirlpool Dryers
Intermittently Drying Problems, Electrical?
It could possibly be electrical, check for 240V at the supply side. The only other possibility could be plugged dryer venting, although it would be unusual for it to cause only intermittent problems. The reason the timer would stop turning (mechanical timer) or counting down (digital display), is because on any Auto-dry, (ones that use the moisture sensor) the dryness of the clothing dictates when the timer should count down or advance. Check for good airflow from the outside exhaust point, if that's ok, I would be possibly looking at the outlet for possible loose contact, look at the dryer cord prongs and see if there are dark marks on them, as this may point to a sloppy outlet causing arcing.
Nov 28, 2009 | Frigidaire Electric Dryer
Dryer runs but does not get hot
if timer runs thru cycles then it is the element sounds like timer
Oct 30, 2009 | Whirlpool LER8648P Electric Dryer
Replaced timer however time does not count down and dryer won't heat up
one thing to check it the voltage coming into the unit make sure you have 220-230 volts at the plug if so you want to open the back little panel where the cord goes in and check your terminal block and cord connection PLEASE unplug b4 you open the panel A dryer will still tmble but wont heat or advance if that leg(110volts) is not there and the other one is
Jan 20, 2008 | Whirlpool LER5636P Electric Dryer
Washing Machines Logo
300 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
