Question about Dryers
NO HEAT SOMETIMES - Dryers
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number?
Posted on Nov 02, 2012
I have samix AC, it does not heat properly.sometimes it doesnot heat at all. sometimes it heat to a certain limit and then start cooling. sometimes it heat to the required tempreture (24) for example
AC temperatures are controlled by thermostats, mechanical or electronic, As per your question it does work some times means thermostat is working some times. Please spray contact spray in thermostat, or replace thermostat. BTU (BRITISH THERMAL UNIT) denotes cooling capacity of AC.
Jan 08, 2015 | Heating & Cooling
Dryer heats sometimes and sometimes it doesn't
It could be a house electrical problem. Dryers need 240v to heat but can run with only 120v. Sometimes I seen were the power cord where it plugs into the house outlet is loose and will sometime heat and other times not.
Dec 27, 2014 | Maytag Dryers
Oster microwave OM1101NOE wont heat carosel turns light is on time runs but not heat
There are three things to consider, the magnetron "heats food" high voltage diode "sometimes cracks" and the high voltage capacitor "sometimes shorts" one or more can cause the symptom of no heat. I recommend a professional to assess.
Mar 08, 2012 | Oster Microwave Ovens
My gas dryer only heats occasionaly - sometimes will work all day, sometimes only will heat one load and not heat the next. Any suggestions?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 18, 2010 | GE DPGT750GC Gas Dryer
Dryer too much heat, or no heat at all
your vent is plugged somewhere clear the vent you can tell if its plugged is when running the top is hot
Sep 15, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
1998 S10 heat wont work sometimes
When you say the heat doesn't work are you meaning the fan doesn't blow out hot air or just doesn't blow out any air? if it blows cold air sometimes when you have the heat on then it could be poor circulation through your radiator or a weak water pump. make sure your radiator is clean on the inside, not too corroded or nasty inside. You can buy a radiator flush thing from wal-mart or any auto parts store. See if it helps.
Mar 01, 2009 | 1998 Chevrolet S-10 Pickup
Heat pump blows heat half the time and cold half the time
It sounds like it is just going into the defrost cycle. Go outside and see if it is iced up. If it is, it reverses itself to melt the ice. Heat strips should come on if unit has them
Dec 03, 2008 | Heating & Cooling
Dryer with no heat
It sounds like an intermitent Thermostat problem.
Sep 02, 2007 | Zanussi WJD1257W Front Load Washer
Dryers Logo
Top Dryers Experts
