Error signals during wash - Washing Machines
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is your make model number of your unit? What is the error signal?
Posted on Nov 02, 2012
Samsung refrigerator error code 8E
8E = OVER CURRENT ERROR
IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
Nov 23, 2012 | Samsung RS265TDRS Side by Side...
Tip
Error codes
Samsung Washer Fault Codes
4E WATER SUPPLY ERROR Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
5E WATER DRAIN ERROR 5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drainerror can be cleared by turning POWER SW OFF and back ON.
oE OVER-FLOW ERROR Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
UE UNBALANCE ERROR Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
HE WATER HEATER ERROR HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
1 E WATER PRESSURE SWITCH ERROR * Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is aPRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
cE ABNORMAL WATER TEMPERATURE ERROR e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
11 E WATER LEAKAGE ERROR Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
tE THERMISTOR ERROR This error occurs when the Thermistor circuit is abnormal or a voltage of O.2v or below or, 4.5v and over is detected. This error can be cleared by POWER switch OFF.
3E MOTOR RESTRICTION ERROR Hall Sensor is sensed every 5OOms. 1 second after motor starts to work.
If data of hall sensor is less than 2 (2RPM), the Washing motor will stop at once.
During Washing and Rinsing when a motor restriction is sensed, the motor stops and then proceeds to the next water -flow action. If the motor stops working and this happens in one direction ten times, "3E" Error is displayed.
During dehydrating. when a motor restriction is sensed. the motor stops working and then returns to the initial stage of the dehydration unbalance sensing cycle. After ten times, "3E" Error isdisplayed, When the motor Is told to stop because of an operating function. no error is shown.
Power 81W OFF can clear the motor restriction error.
8E OVER CURRENT ERROR IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
on Apr 14, 2015 | Washing Machines
E8 front loader washing machines
OVER CURRENT ERROR - Display shows 8E.IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
HOWEVER, the UK White goods website says:
E8
Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
You can find more about your Samsung Washing Machine error codes at:
http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
or
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
Jun 21, 2011 | Samsung Washing Machines
My washer is showing dE message what is this mean?
The machine identifies and indicates some operational errors through a series of beeps.As you are using LG WM2455 Front load Washer it is showing error message The error message "DE" This error signal beep during drain.Unhook/clean drain pipe and press the 'Start/Pause' button to continue cycle.Thanks for your question.
Jun 17, 2011 | LG WM2455 Front Load Washer
What does e 62 error code refer to?
E62: Overheating during washing this is real ans now iam giving u more tips abt error -
E11: Difficulty in filling during wash phase
E13: Water leakage.
E21: Difficulties in draining .
E23: Malfunction of drain pump triac.
E24: «sensing» circuit of the component (triac) that controls the drain pump faulty
E33: Incongruence between closure of anti-boiling and 1st level contacts of pressure switch
E35: Water level too high
E36: «sensing» circuit of anti-boiling pressure switch faulty
E37: «sensing» circuit of 1st level pressure switch faulty
E39: "HV" «sensing» circuit of anti-overflow pressure switch faulty
E40: Door open, Interlock, wiring or main PCB
E41: Door open
E41: Problems with aperture of door
E42: Problems with aperture of the door
E43: Problems with the triac which actions the door interlock
E44: Door closure «sensing» circuit faulty
E45: Problems with the «sensing» circuit of the triac that actions the door interlock
E51: Motor power triac short-circuited
E52: No signal from the motor tachymetric genetaror
E52: No signal from the tachymetric generator
Procedure for checking commutator motors
E53: Problems with the «sensing» circuit of the triac which powers the motor
E54: Motor relay contacts sticking
E61: Insufficient heating during washing
E66: The contacts of the heating element power relay are always closed
E71: NTC washing sensor faulty.
E82: Error in reading the RESET/OFF position of the programme selector.
E83: Error in reading the programme selector code
E93: Incorrect machine configuration.
E94: Incorrect configuration of washing cycle
E95: Communications error between microprocessor and the EEPROM
E96: Incongruence between control panel version and configuration data
E97: Incongruence between selector version and configuration data
EA1: Drum positioning system (DSP) faulty (top-loaders only)
EB1: Incorrect mains frequency
EB2: Mains voltage too high
EB3: Mains voltage too low
E32 INCORRECT CALIBRATION OF ANALOGIC (ELECTRONIC) PRESSURE SWITCH. IF THE MACHINE IS DRAINING OK, THEN IT IS THE SWITCH
E32 relates to the electronic pressure switch, normal pressure switch,inlet valves,poor water mains pressure and finally the main control board
E90 means theres a fault on the main control module so A;will need a new control module or B; get an engineer to try re-configureing the module
May 16, 2011 | Hoover Washing Machines
What dies the error code d5 mean on a maytag neptune
it thinks the door isn't locked even though it is during a wash cycle,check for bad connections around ribbon cables inside the machine,as corroded cables will block small electrical signals
Jun 19, 2010 | Washing Machines
My hotpoint washer/dryer keeps coming up with code e30 see user guid and stops washing,what does that mean
Error code E30 indicates motor tachometer failure.
There is a loss of signal during tumble or spin.
Check your user guide.
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
My samsung washing machine model WA13513 13.5kg load had 8E error message popping out from the screen. Is the computer board damaged?
OVER CURRENT ERROR – Display shows 8E. IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
If the motor stops working, in one direction ten times, “8E” Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error “8E” is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power SIW OFF can clear the overload error.
would advise calling a tech... hope this helps.
Oct 25, 2009 | Washing Machines
E8 error code
8E - OVER CURRENT ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 02, 2009 | Washing Machines
Message on screen 8E, Motor won't start on spin cycle. Model no Q1435(C/S/V)
This is what I found:
11. OVER CURRENT ERROR - Display shows 8E .
- IPM fault signal (that is caused by the overload of MICOM INT0 during motor action) is sensed.
IPM : Integrated power module. , IPM controls motor.
- If the fault signal (low signal) happens to be sensed even one time during cleansing/rinsing stage,
the motor stops immediately. However, during dehydrating stage the signal is to be sensed
when the number of signal is more than 6 for 500ms.
- During Cleansing or Rinsing
When the overload is sensed, the motor stops immediately and then proceeds to the next water-flow action.
If the stopping of the motor working is happens in one direction ten times,
- During dehydrating
When the overload is sensed, the motor stops to work at once and then feeds back to the initial
When the feed back is continuously happened 2 times, "8E" Error is displayed
During the dehydrating unbalance sensing, No error happens by overload sensing.
-Power S/W Off can clear the overload error.
in short: imbalance problem
In a german forum one guy solved the problem by replacing the motor electronics. I am currently experiencing the same problem. I keep you posted.
May 08, 2008 | Washing Machines
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
