Question about Sport & Outdoor - Others
1988 Yamaha 4 wheeler slow crank
I am having a serious slow crank on my 4 wheeler.It is so severe that the 4 wheeler will not start anymore. It is a new battery. I have ruled out all electrical problems and replace the starter. I assumed that the problem was mechanical, so pulled the covers off, pulled the timing chain, and then turned the top end and bottom end manually. Neither the top end or bottom end seem to be binding. Not sure what to do from here. Any ideas?
  • Steven Salvetti Jan 04, 2009
    I tried to start it by putting power straight to the starter, but the same thing happened. I will look further into the clutch assembly. There are 2 separate clutches on this model.
    Novelist:
  • 148 Answers
Put jumper cables from battery to starter directly
to see if it turns over faster put red on starter lead and black on gorund(metal housing)
You may want to try this from a car battery to see if it spins faster if it does it indicates a problem with power from new battery check cables and lines for power blead
Posted on Jan 04, 2009
  • Steve Archer Jan 04, 2009
    after thinking about it It almost sounds like the clutch could be dragging
    if you have been in a lot of dirt it could be the clutch is dragging (I am assuming it is centrifugal
I have 2004 arctic cat 650 twin 4 wheeler and battery went dead due to no water in several cells in battery so I refilled with DI water and now cranks great but won't run almost like belt light prob
Hi Jasper:
Have you tried jump starting from another vehicle?
It may be that your battery is just not putting out enough amps.
RV and motorcycle batteries tend to not last as long as car batteries.
Sep 17, 2015 | Arctic Cat 2004 650 4x4 Automatic LE
Yamaha big bear 4x4 2001
OUCH.... yea, this sounds serious.... I would suggest a trip to your local professional!! DO NOT ATTEMPT TO RUN OR RIDE.... it will just get more expensive!!!!
Jul 08, 2014 | ATVs
How to line up timing chain for 2000 Yamaha 400 Kodiak 4 wheeler
not sure what motor is in that, but i am sure you can get the manual from Yamaha. You will need to line up cam and crank on cylinder 1 tdc
Jan 09, 2014 | Atv Cover Quad 4 Wheeler Yamaha Yfz450x...
I just bought a 1988 yamaha virago 750 and it was stored outside covered for over 4 yrs.Cleaned carbs and gas tank,put new plugs in,new fuel lines and checked fuel filter is ok. I have spark,compression...
good start on cleaning things BUT, you should replace pump. the pump will have the same gum **** the tank did. you can unhook lines and turn over to see how much fuel you get
Jun 14, 2011 | 1988 Yamaha FZX 750
Have a 2003 350 yamaha warrior 4 wheeler I pour gas in carburetor to get it to start it runs fine when i shut it off i have to pour gas in again
A common problem with Yamaha 4 wheelers is soft rubber on the intake manifolds. They will often crack or separate causing poor running. I think you are either dealing with a cracked, broken, or separated intake manifold or a cracked, broken, or missing intake o-ring on either end of the intake manifold. Take the manifold off and inspect the manifold and the o-rings.
Mar 24, 2011 | Yamaha RD 350 Motorcycles
4 wheeler 250cc no compression
it needs a set of rings and maybe a piston then it will be like new again
May 07, 2009 | RTO Quads 125cc Full Size Adult 4 Wheelers...
Power less and hard to start.
Hi, Ttiimmiiss it could be a timing issue or the list below and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on blue links below. Good luck and have a wonderful day.
Project My 90 FZR250 3LN3
Fzr250 running problems
Yamaha FZR400 1988 1989 Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-fz-owners-manuals
Apr 19, 2017 | 1990 Yamaha FZR 250 R
Cranks as though battery is dying
That sounds like your alternator might need to be replaced.
Dec 18, 2008 | 1988 Yamaha XJ 600
Sport & Outdoor - Others Logo
276 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
