Question about HP Office Equipment & Supplies
Printer is slow - HP Office Equipment & Supplies
  • 4 Answers
Your printer could be conflicting with the computer, try reloading the printer driver.
Sometimes if you use compatible or re manufactured cartridges if they have not been pressurised correctly this can cause them to print slow.
Posted on Nov 01, 2012
My epson office tx600fw printer is very slow since I start using Windows 8.1 how can I restore its original speed
Steps to Troubleshoot Epson Printer Slow-to-Print Problem?
Learn to troubleshoot Epson Printer Slow-to-Print Problem as not all printers are created equal. Print speed may vary depending on system configuration, print mode and document complexity. Processing time on the computer system is not included in the print speed. The several factors where printing is slow are mentioned below:
    ·Printer driver settings
    ·Size of the data being sent to printer
    ·Windows spooling error You can also get in touch with Epson Printer Technical Support for further query or simply follow the steps to troubleshoot the slow-print issue.
    Steps to fix Epson Printer Slow-to-print issue:
    Step1: Observe the data cable
    Check whether the data cable is less than 1.8 meters in length and is connected directly to computer system. Use of long cable and connecting through third party such as USB hub can cause communication and print delays.
    Step2: Paper type
    Check that paper type you have selected in the printer driver matches the paper loaded in the printer and selected paper print is also appropriate
    Step3: Some general tips
    Click on icon shown for general information on how to remedy slow printing
    Step4: High Speed enabled
    Check for high speed if it is enabled in the printer driver. Depending on the driver the setting may only be available on certain quality and paper selections.
    Step5: Enable High Speed
    Open the printer driver from printers, printer and faxes or Devices and Printers folder and check whether the high speed is enabled in speed and progress
    Step6: Other Settings
    Check for other settings as well in speed & progress for better printing speed
    Step7: Spool folder
    Create new folder of spool on the hard drive and point the driver to it
    Step8: Carry a test
    Print a test page form general tab of your Epson driver
    Step9: Perform
    If printing is still slow try reducing the size of the data sent to printer
    You still have doubts to execute the above mentioned steps you can contact via Epson Printer Customer Support Phone Number USA Toll-Free 1-800-213-8289 UK @+44-800-046-5291(toll-free) to receive immediate and instant solution. The trained technicians are present 24*7 to deliver you high speed printing printer machine.
Epson Printer Customer Support Phone Number 18002138289 Help
Feb 11, 2015 | Epson Stylus Office Equipment & Supplies
Slow printing
Check that the default setting for print quality on your printer driver hasn't been set to "Fine".
In your Opertaing System, find your printer (in XP it's under Control Panel / Printers and Faxes) and select Properties. This should then bring up the settings for the driver.
Fine printing quality takes over double the time "Normal" quality takes so would considerably slow your printing.
Apr 10, 2014 | Brother MFC 210C All-In-One InkJet Printer
Printing in color on my Lexmark printer is very slow. This is a wireless printer and is not so slow on black and white printing.
Printing in color is always slow vs. printing in B/W. If your printing color with the highest resolution setting, it will print really slow. You can adjust the resolution settings in Printer Properties for the Lexmark. If you want faster print, select a lower resolution.
Mar 03, 2011 | Lexmark X7675 Wireless All-in-One Printer
Extremely slow printing
The printer is an inkjet printer. Inkjet printers are slow printers compared to laser printers.
Also the print speed depends on the size of the document printed.
If it is a large photo or file, it will take longer than small notepad file.
Speed also depends on coverage. A page with a lot of it covered in ink, will take longer than a page which is only coverd in ink on a small part.
Also the print speed depends on computer memory and USB cable. Fast cable and a lot of memory mean fast transmission of data to the printer.
Slow cable and small amount of memory (512Mb, or 256Mb or less) mean slow transmission of data to printer
Sep 17, 2010 | HP Deskjet D4260 Printer
Printer is running very slow
Good day!Try some tests..like replacing power cord,printer cable and reinstall driver..if nothing happens..then try to see if the belt on the assembly is already weak..cause it can slow down your printing..or the film like inside is dirty..if you can open it much better..i
regards,
mastergani
Mar 26, 2010 | HP Photosmart C6280 Printer
Slow printing time
Hello, Thais can come from: - Your connexion to the printer that gets slow (USB, WIFI or ethernet) - Your computer that doesn't send data fast (slow hard drive) - Your printer settings are for high quality printing (the higher the quality is, the slower the printer is) Best regards
Jun 10, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
THIS PRINTER IS SOOOO SLOW.
ALL ink-jets are slow. I have the same series printer.
Dec 29, 2008 | HP Deskjet 6940 InkJet Printer
It is slow on xp x64
plz try by reinstalling the drivers and check for viruses
Jul 02, 2008 | HP LaserJet 1150 Printer
13 people viewed this question
Seeker5211
Seeker5211
